07-16-2006 05:03 AM - edited 03-03-2019 04:04 AM
Hi Expert
I Want to setup the HSRP Between the 2 Dist 6509-SUP1.PS Have a look to all my config in the Attachment!ps focus in the etherchannel config(L2)!etherchannel Config(L3) TOward the core!the HSRP Config in all VLANs!also the root primary & the root secondery!ps find where my mistake?advise to the optimum config!what u advise me!My config its correct?PS Help!PS HAVE A LOOK TO THE the Attachment!
10xs for ur time to help.
07-20-2006 04:29 AM
Do i need to assign an ip default-gateway in each access switch(Vlan)if so which ip address so i assign to each access switch?
10xs
07-20-2006 04:51 AM
hi ali...
as you are going to have loadbalancing here... so you are using the two different virual ip address. DHCP solve your issue to assing the Default gateway to clients...but in switch you are having some problem... if you are having layer 3 switch then you can configure the access-list for few client and can have route map or you can use the static route to route the traffic... to different virtual ip address... means you can configure static route for few client which point to the one virtual ip address and other static route point to the other virtual ip address...
but if you have the layer 2 switch then you can do like this:::on one switch you can have the one virtual ip address as default gateway and on other switch you can have the other virtual ip address as the default gateway... so client of switch 1 go to the default gateway of the virtual ip address and switch 2 client's go to the other virtual ip address...
reply me if it works so i can understand...
hope this will clear your idea
rate this post if it helps
regards
Devang
07-20-2006 05:05 PM
Ali, please check this article for the operation of HSRP load-sharing.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094e90.shtml
If you want to speed the convergence, you can to change the timer, your current timer is 3 for hello and 9 for hold time. Ths HSRP will wait for three times of hold time expired and change the state. So fine tune the timer to smaller.
e.g. standby 10 timers 3 6
Please read below for more information.
http://www.cisco.com/en/US/tech/tk1330/technologies_design_guide_chapter09186a008066670b.html
07-21-2006 10:15 PM
Hi Jacky!
if i tune the timer to smaller (Standby 10 timres 3 6) make unNecessary hello in the network.
10xs
07-23-2006 04:39 PM
Yes, of course, there will be more hello packet in the network due to smaller interval between hellos. You can to decide yourself to have fast change-over or less hello in the network.
07-23-2006 10:17 PM
Hi Jacky
i reuduced the time out to 6 time out.the hello timere still 3 9.how can i reduced to 3 time out without the decrease of timeres?
10xs for ur help
07-23-2006 10:30 PM
There is no way to decrease the number of times to send out the hellos......
The standby 1 timer 3 9 <--- 3 is hello in sec and 9 is hold time in sec. Both ranges are 1 to 255.
Normally, the hold time is 3 times of hello timer. Try to setup standby 1 timer 2 6 to determine it.
Check below for details. Please do read the article that tells more details than what I said.
07-21-2006 10:11 PM
Hi Devang
10xs for ur reply!i need only to reduce the time out(30 TIME OUT) when the Active switch goes Down,
Standby 3 6 make a lot of hello in the network.
10xs
