10-01-2006 09:26 PM - edited 03-03-2019 05:19 AM
I searched around, but couldn't find an answer to my question so I am going to have to ask everyone.
After a bit of a mix up here with a coworker the complete flash file system on my 3560 Switch was deleted before I could make a full backup of it. The only thing that I do have is the original .bin image file, but that does not contain the Web Console files. How do I go about getting the Web Concole files back?
10-02-2006 12:57 AM
If you have another 3560, you can copy the required files from the 3560 onto this
Alternatively you can download the entire suite from the cisco website. (CCO required)
http://tools.cisco.com/support/downloads/pub/MDFTree.x?butype=switches
Narayan
10-02-2006 09:35 AM
Thanks! I had no clue that I could do it through the download area.
10-02-2006 08:13 PM
If you feel that your case has been resolved please mark it as resolved as it helps others
cheers
Narayan
