05-11-2021 01:22 AM
I have a 8 Port 2960G switch. I tried to replace the boot flash yesterday, but the verion I have got doesnt seem to work. I can reboot to previous flash, but dont know how to make this the default. Any suggestions, The flash is in a subdirectory.
The boot flash in in root folder
05-11-2021 01:36 AM
"boot flash"? You mean the chip or the IOS?
05-11-2021 03:12 AM
ios.
05-11-2021 03:47 AM
Console into the switch and reboot.
Post the entire boot-up.
05-11-2021 05:17 AM
- In the running-config enter : boot system flash:/c2960-image-name.bin then save configuration and reboot, of course do not enter literally but replace by the intended image (binary) you want to boot.
M.
05-11-2021 07:50 AM
HI, THanks for the information, I have now reloaded new iso and seems to work OK, however when i browse to it, I can't get to web console. says 404 not found?
05-11-2021 09:47 AM
- When you download software distribution from Cisco make sure to include web based tar file (not simple bin).
M.
05-12-2021 12:38 AM
Thanks everyone, So I have now installed a tar version. I can get the the Web Interface, and expand the contents to see the options available, however when I click on any one of them nothing happen !!
See attached screen shot. If I click on restart / reset nothing happens. Any suggestions?
05-12-2021 12:46 AM
- As a sanity check try a few other browsers
M.
05-12-2021 12:50 AM
Thanks, I thought I had tried other browsers. I did try Edge and Chrome where it doesnt work, but it works in IE, I think its to do with Java.
Any further suggestions most welcome.
