05-31-2004 06:16 PM - edited 03-02-2019 04:03 PM
I am going for my CCNA and i was wondering for frame-relay does the serial interface need a ip address? I think it would need a ip, but i came access some information that says as long as it has the dlci and lmi set it should work.
05-31-2004 07:14 PM
It requires an IP address if you wish to route IP traffic over it, which is what is done about 99% of the time. However it is not required for the link to come up so you could configure it for Novell or bridging, for example, without an IP addresss.
05-31-2004 07:32 PM
Thanks for the quick response.
Now i just hope i can pass the CCNA only 3 days left.
05-31-2004 07:23 PM
Just think the OSI model.
FrameRelay is at Layer 2
and IP is at Layer 3, You may run different layer 3 protocol over FR, like IPX, etc.
