01-28-2003 01:49 PM - last edited on 03-25-2019 02:44 PM by ciscomoderator
I am trying to format the bootflash from rommon using a 4000 switch. The switch complains that the bootflash must be formated first.
Chad
01-28-2003 10:21 PM
What command did you use at the rommon prompt?
I don't think you can "format" the flash from rommon but you can "delete" the
files and perform "squeeze" operation to recover the bootflash space.
rommon 1> del bootflash:cat4000.6-1-1.bin
rommon 2> squeeze bootflash:
Hope this helps.
01-29-2003 08:57 AM
When I try to squeeze the flash I get and error. RMA??
