Full BGP with Sup720-3B and Sup2u
nocsertech
I only realize Sup720-3B have the limitation of 235K route where full table now is near to 500k route. I need you guy help to answer some of question in my mind.
1) What will happen if I use Sup720-3B as my BGP router with full routing table. Will it hang or make use of CPU resources to handle the route?
2) What will happen if I use Sup2u as my BGP router with full routing table. Will it hang or make use of CPU resources to handle the route?
3) If the answer to the above is CPU resources handle the route, will it work with my bandwidth usage? I am currently have 1 up stream 50Mbps. I plan to increase my bandwidth to 2 up stream with both100Mbps.
4) I have a C7200 G1 with 1GB RAM. Will this work better in my network?
Thanks for your help
nocsertech
Comment and help appreciated. Thanks
