Cisco Community Designated VIP Class of 2020
2224
Beginner
Help on VxLAN EVPN Configuration on Catalyst 9500-32C
Attempting to configure VxLAN EVPN on a pair of Catalyst 9500-32C's for a Proof of concept. No joy so far. Been referencing these links:
https://community.cisco.com/t5/data-center-blogs/vxlan-evpn-configuration-example-n9k-p2p/ba-p/3663830
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-10/configuration_guide/lyr2/b_1610_lyr2_9500_cg/configuring_vxlan_bgp_evpn.html
BRKDCT-2949.
Any suggestions?
Main goal is to bridge a single VLAN and have 2 hosts communicate across the VTEPs.
18 REPLIES 18
VIP Mentor
Re: Help on VxLAN EVPN Configuration on Catalyst 9500-32C
is this a partial config ? I don't see interface Loopback 0, which is bound to the NVE...
Beginner
I've attached a more complete configuration for review. Thanks
Highlighted
dal Participant
Participant
Hi.
Did you find an answer to this?
I'm facing the same situation my self, and would love to see some working configs betweeen Catalyst switches.
All examples I have found involves Nexus switches, which I don't have.
Thank you
Beginner
Official answer we received from Cisco was that at this time the 9k is not supported in the Spine function. We have put in a feature request for this role and are awaiting and *hoping* for support in a future release. If you put in a feature request as well this may help...;)
Aaron
dal Participant
Participant
Thank you for your answer.
So it's not possible to set up between 2 Catalyst switches?
Beginner
Not according to the last conversation we had with the BU about a month and a half ago.
Beginner
i have configured vxlan between two catalyst 9300 acting as leaf switch.
it works.
dal Participant
Participant
Very nice!
Would you mind sharing your config on those two switches?
Beginner
@dal wrote:
Very nice!
Please find attached the config of one device the second is also similar,
Please let me know if you still have issues
Beginner
This config is not have multicast, its work?
Beginner
the config is working based on ingress replication and not with multicast,
please mark helpful if it helped.
Beginner
Here also attached tested configs for 2 leaf switches.
My goal was just to do a POC for extending the VLAN across an IP network using EVPN on C9500.
The switches are directly connected but you can easily amend the BGP for multihop.
I hope that helps.
Everyone's tags (4)
Beginner
Glad to help
regards,
I just wanted to know about 10.0.41.1 and 10.0.41.252 IPs in your configs configured as BGP neighbor IPs. Are these the layer-3 interfaces connecting both the switches?
Thanks.
Content for Community-Ad
FusionCharts will render here
