admin_2
Participant
How to connect two Cisco 1700s over a T1
We have a new dedicated full T1 line to another office location. That location has an internet line. We'd like to connect our two Cisco 1700s together over this T1 line so both offices have an internet connection. However, I'm having major difficulty trying to do this. The router configs are:
Office Site (without the internet connection, just the T1 line to the other location):
version 12.3
hostname office
boot-start-marker
boot-end-marker
enable secret xxxx
enable password xxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
no ftp-server write-enable
interface FastEthernet0
description Office Network
no ip route-cache
speed auto
interface Serial0
description T1 connection to other office site
ip address 10.0.0.1 255.255.255.0
encapsulation ppp
no ip route-cache
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.254
no ip http server
line con 0
line aux 0
line vty 0 4
password xxxxxxxxx
login
end
The other site, with the internet connection looks like:
version 12.3
hostname colo
boot-start-marker
boot-end-marker
enable secret xxxx
enable password xxxxxxxxxx
no mmi pvc
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
description To Internet
ip address 192.168.0.254 255.255.255.0
no ip route-cache
speed auto
interface Serial0
description T1 Line from Office Location
ip address 10.0.0.254 255.255.255.0
encapsulation ppp
no ip route-cache
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
no ip http server
line con 0
line aux 0
line vty 0 4
password xxxxxxxxxx
login
end
The two routers cannot ping each other. Any ideas why?
6 REPLIES 6
thisisshanky
Advisor
Do you use external CSU/DSU or the internal one (WIC-1DSU-T1? Do you see any alarm lights on the T1 CSU/DSUs, smartjacks ? You should set one end of the T1 line to clock source internal. (while the other end is set to the defaults -> clock source line)..
This setting can be changed on either the external CSU/DSU, or if you use a internal CSU/DSU (WIC) - this parameter can be changed using an IOS command.
Where is the internet T1 terminating at the second site ? Is it on a separate router ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
You need to enable ip routing on both of the routers. You have the command "no ip routing" entered on both of them.
I agree that turning on ip routing is important. But I would like to understand better the comment about the routers could not ping each other. I understand why the routers would not be able to ping the other routers Ethernet. But if the router can not ping the serial interface address, then it is not an ip routing issue, because you should be able to ping devices on a connected subnet.
Can we verify which addresses you were pinging when it did not work?
And can we get the results of show int on both of the routers?
Rick
The ends of the T1 are smart jacks. What is the command for changing the clock source ? I'm looking, but not finding it.
For internal CSUs:
conf t
int s0
service-module t1 clock source ?
What does sh int s0 show on both routers?
-HTH
hi
What about the cabling from the smart jack to the router?
Have you checked/replaced them
thanks
