How to see nexus ethernet speed?
SubnetWarrior
Hi experts!
I run sh int ethx/x command to see port speed whether it is 1 gig or 10 gig. But i confused because it said "Hardware: 1000/10000 Ethernet" but it also said "full-duplex, 1000 Mb/s, media type is 1G". So it is 1 gig or 10 gig? The interface is connected to a server. Here is the sh int command ( i edited the sensitive part).
Ethernetx/x is up
admin state is up, Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: xxx
  Description: xxx
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned on
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 367week(s) 1day(s)
  Last clearing of "show interface" counters 27w1d
  0 interface resets
  30 seconds input rate 10288 bits/sec, 1 packets/sec
  30 seconds output rate 5992 bits/sec, 4 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 9.62 Kbps, 5 pps; output rate 4.97 Kbps, 9 pps
  RX
    99753068 unicast packets  0 multicast packets  0 broadcast packets
    99698228 input packets  21702029623 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    147333897 unicast packets  19450412 multicast packets  548680 broadcast packets
    167278149 output packets  12967764953 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
I also want to ask how to see the media type whether the interface can be inserted directly by utp or the interface have to use sfp.
Thank you
ilay
"Hardware" show the nexus LineCard or Nexus switch supported speed in hardware layer.
" full-duplex, 1000 Mb/s, media type is 1G" display the port real speed.
as you show above , your switch hardware support 1G/10G and this port insert a 1G SFP module
By "show interface status" you can also view the Port Speed and Media Type
N9K-1# sh int e2/14
Ethernet2/14 is up
  Belongs to Po24
  Hardware: 1000/10000 Ethernet, address: cccc.cccc.2621 (bia cccc.cccc.2621)
  Port mode is trunk
  full-duplex, 1000 Mb/s, media type is 1G  <-------
----- Omit part of the output----
N9K-1# sh int e2/15
Ethernet2/15 is up
  Belongs to Po25
  Hardware: 1000/10000 Ethernet, address: cccc.cccc.2622 (bia cccc.cccc.2622)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G  <-------
N9K-1# sh int e2/14 transceiver
Ethernet2/14
    transceiver is present
    type is 1000base-SX
    name is CISCO-AVAGO
    part number is SFBR-5766PZ-CS2
    revision is
    serial number is xxxxxxx25M
    nominal bitrate is 1300 MBit/sec
    cisco id is --
    cisco extended id number is 4
N9K-1# sh int e2/15 transceiver
Ethernet2/15
    type is 10Gbase-SR
    name is CISCO-AVAGO
    part number is SFBR-709SMZ-CS1
    revision is G4.1
    serial number is xxxxxxLBU
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM2 fiber is 82 m
    Link length supported for 62.5/125um fiber is 26 m
    Link length supported for 50/125um OM3 fiber is 300 m
    cisco id is --
N9K-1#sh int status
Port          Name               Status    Vlan      Duplex  Speed   Type
mgmt0         --                 connected routed    full    100     --
Eth1/1        --                 connected trunk     full    10G     10Gbase-SR
Eth1/2        --                 connected trunk     full    10G     10Gbase-SR
Hello sir,
Thank you for your enlighment, if i may add another question, so i just show module in my nexus and find out that my ehternet 3 is 1/10 Gbps Ethernet Module, with the module is https://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/data_sheet_c78-685394.html
Does it mean that the speed is depending on the transceiver? For example if i want to use 10 gig speed i just buy 10 gig transceiver, if i want 1 gig speed i just use 1 gig transceiver, is that correct?
Yes,you are right. real speed depends on the transceiver you used
Hello
sh interface x/x capabilities
will show you what media type/speed etc the interface supports
Kind Regards
Paul
