85
Beginner
I have a problem about SG 300-28 switch.
Hello.
I am a Korean engineer.
Today, all day, I worked "SG 300-28" switch.
But, I didn't connect it to the PC using console cable(it is NULL MODEM CABLE)
I did 2 method.
First,
When I connected it, in the monitor, did not  any other respond. ( I used PuTTY )
So, I searched database, I performed followed steps.
(such as setting console speed 115200, stop bit and so on...)
Finally I failed it connecting to the PC.
Second,
Therefore, at this time, I used telnet.
( its default IP = 192.168.1.254 )
However, in the cmd, I input "ping 192.168.1.254" <- respond.
                                                   "telnet 192.168.1.254" <- NOT respond.
Hmmm....
And now ... finally I register my word in this site...
Please help me how to connect switch.
Thank you for reading my word.
1 ACCEPTED SOLUTION
VIP Mentor
You have the right cable it
You have the right cable it does not support standard blue console , have you tried baud rate 9600-8-n-1-None-None it should have took 115200 as well that's its default  , telnet may be disabled try ssh that may be configured depending on the setup, also keep pressing enter when connected it can wake up the serial connection , also try hyperterminal
Try web to that address .254 see if you can setup telnet/ssh if not enabled
2 REPLIES 2
VIP Mentor
Beginner
Thank you so muchI connected
Thank you so much
I connected switch to the PC using LAN cable.
And I tried accessing the Web.
It is correct method following your steps.
Anyway I completed it!
Thank you again and have a nice day:]
Content for Community-Ad
August's Community Spotlight Awards
