Beginner
In Rommon mode, how to erase flash????
Hi,cisco.
I have a problem about ERASE flash contents.
I entered ROMmon mode.
But I didn't search anything else ; erase, delete commands...
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of motherboard cookie PROM in hex
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
dnld                serial download a program module
frame               print out a selected stack frame
gioshow             show the gio version
help                monitor builtin command help
history             monitor command history
iomemset            set IO memory percent
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
rommon-pref         Select ROMMON
set                 display the monitor variables
showmon             display currently selected ROM monitor
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
tftpdnld            tftp image download
unalias             unset an alias
unset               unset a monitor variable
xmodem              x/ymodem image download
I could see these commands.
As you see those, which command is that I find?
plz recommend one!
Content for Community-Ad
August's Community Spotlight Awards
