Highlighted
Beginner
INTEGRATION WITH HP OPENVIEW
I installled ciscowork2000 on NT4.0 and HP Openview on Windows2000 server. Now I wan't to integrate ciscoworks and Openview which is running on different system. I am using the same latest script, but When I am trying to install Integration utility on HP openview system, it's gives me following error in starting phase.
" Cannot create the install dependency file".
After gives that error it's terminate the installtion.Before installing
Integration utility on Windows2000 server which is running HP Openview, I
stopped Openview.
Please help me..
2 REPLIES 2
Highlighted
Collaborator
Re: INTEGRATION WITH HP OPENVIEW
What version of CW2000 are you using?. You can download the Integration Utility + HPOV Adapter from: http://www.cisco.com/kobayashi/sw-center/cw2000/cmc3rd.shtml and install it on the HPOV server to complete the integration.
Highlighted
Beginner
I am using Ciscoworks 4th Edition on P||| nt 4.0 based macine and Openview 6.2 on P IV macine. I am using the same integration utility and latest script.
