Interconnecting Catalyst 3750 and 2948G-L3
tironevi
I am trying to interconnect a Catalyst 3750 and a 2948G-L3 using fiber GBIC. The interfaces where the GBIC and fiber are attached show up as physically down. I have tried different ports and also changed both switches. No Luck. If I connect a 3524 to the 3750 using the same connection it works.
Are 2948G-L3 switches compatible with the 3750?
VT
Roberto Salazar
Level 8
Level 8
Should have no problem. Can you try the following on the 3750's gig interface:
speed nonegotiate
See of the link comes up.
Please rate all posts.
Roberto Salazar
Level 8
Level 8
speed nonegotiate
It works!!! Not sure how I overlooked this setting.
Thank you so much for your help.
VT
