IOS upgrade issue 3550
i'm trying to upgrade to c3560-ipbasek9-mz.122-55.SE12.bin. The update went well but it would not boot automatically. I have tried to boot manually without secsses. The bin file is in the flash directory but I've noticed that there is no directory for it.
drwx         192
 I have tried to boot from flash but it puts out lots of short cuts that are uknown to me:  usage: boot [-n|-j] [-p] [-c] [-f] [-i] [-m] [-notnd] [-notni] [-post] [-skip_post] [-asic_post] [-reserve_mem <1-15>] [-no_esp_keepalive] [<filename>]
Please see my log below:
[OK - 11775204 bytes]
11775204 bytes copied in 288.716 secs (40785 bytes/sec)
Access1#dir flash:
Directory of flash:/
2 -rwx 342 May 25 2005 12:54:58 +00:00 system_env_vars
3 -rwx 162 Sep 28 2005 13:18:20 +00:00 layout.text
4 -rwx 736 Mar 01 1993 00:10:29 +00:00 vlan.dat.renamed
5 -rwx 2352 Mar 01 1993 00:41:54 +00:00 config.text
6 -rwx 5 Mar 01 1993 00:41:54 +00:00 private-config.text
8 -rwx 11775204 Mar 01 1993 04:15:46 +00:00 c3560-ipbasek9-mz.122-55.SE12.bin
9 -rwx 0 May 25 2005 12:54:58 +00:00 env_vars
7 -rwx 8808 Sep 19 2016 08:42:23 +00:00 config.text.renamed
10 -rwx 25 Sep 19 2016 08:42:23 +00:00 private-config.text.renamed
15998976 bytes total (4207104 bytes free)
Access1#show ver
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(22)EA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 12-Jul-04 09:21 by madison
Image text-base: 0x00003000, data-base: 0x0083AEF4
ROM: Bootstrap program is C3550 boot loader
Access1 uptime is 4 hours, 21 minutes
System image file is "flash:c3550-i5q3l2-mz.121-22.EA1/c3550-i5q3l2-mz.121-22.EA1.bin"
cisco WS-C3550-24 (PowerPC) processor (revision C0) with 65526K/8192K bytes of memory.
Processor board ID CAT0619X00C
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Access1#delete /force /recursive flash:c3550-i5q3l2-mz.121-22.EA1
Delete filename [c3550-i5q3l2-mz.121-22.EA1]?
Access1#dir flash:
Access1#verify flash:c3560-ipbasek9-mz.122-55.SE12.bin
Verified flash:c3560-ipbasek9-mz.122-55.SE12.bin
Access1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Access1(config)#boot sys
Access1(config)#boot system fla
Access1(config)#boot system flash:c3560-ipbasek9-mz.122-55.SE12.bin
Access1(config)#end
Access1#
04:28:40: %SYS-5-CONFIG_I: Configured from console by console
Access1#
Access1#show boot
BOOT path-list: flash:c3560-ipbasek9-mz.122-55.SE12.bin
Config file: flash:/config.text
Private Config file: flash:/private-config.text
Enable Break: no
Manual Boot: no
HELPER path-list:
NVRAM/Config file
buffer size: 393216
Access1#write mem
Access1#write memory
Building configuration...
[OK]
Access1#reload
Proceed with reload? [confirm]
04:30:39: %SYS-5-RELOAD: Reload requestedBase ethernet MAC Address: 00:09:b7:47:bf:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 9 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 11791872
flashfs[0]: Bytes available: 4207104
flashfs[0]: flashfs fsck took 19 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Loading "flash:c3560-ipbasek9-mz.122-55.SE12.bin"...uncompress: Unknown mzip segment type: 2
Error loading "flash:c3560-ipbasek9-mz.122-55.SE12.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560-ipbasek9-mz.122-55.SE12.bin"...uncompress: Unknown mzip segment type: 2
Error loading "flash:/c3560-ipbasek9-mz.122-55.SE12.bin"
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
I would appriciate if someone could have a look at my log and point me in the right direction.
Many thanks in advance
Chris
Leo Laohoo
Not going to work.
You are forcing a 3550 switch to load an IOS meant for a 3560.
6 Replies 6
Leo Laohoo
Not going to work.
Many thanks,
So Ive downloaded the wrong image!!
I'm looking for this image (c3550-ipbasek9-mz.122-44.SE6.bin) but I cant find it on the download page only 3560 and how do I revert back to my original IOS. I do have a back up in my TFTP folder.
thanks again.
If the firmware for the 3550 is backed up then copy it back to the switch using TFTP.
The issue I have now is that my swit is only displaying switch: promt I'm not sure how to start the TFTP in this mode and which comnds to issue.
This might be a longshot but does anyone have a copy of :c3550-ipbasek9-mz.122-44.SE6.bin
