11-17-2014 02:42 AM - edited 03-03-2019 07:39 AM
Hi there
i have a serious problem in my network that i need an urgent solution for
i have got an 2811 router and a 3560 Cisco catalyst switch
the 2811 router has two interfaces (f0/0 & f0/1)
f0/1 is connected to the Wan and f0/0 is connected to the 3560 switch through f0/2 port in the switch
i made f0/2 in the switch as no switch port
i created an SVI for Vlan 1 and i have given an IP address to INT Vlan 1 , when i am trying to give f0/2 an ip address from the same subnet of int vlan 1 , it tells me that there is an overlapping with Vlan 1 subnet
how can i solve this problem
11-17-2014 04:53 AM
Because the made fa0/2 on the switch a routed port (no switchport); vlan1 and the link between the switch and the router now resides in different broadcast domains and should therefore have IP addresses from different subnets.
You can either make fa0/2 on the switch a switchport again, or make the link between the router and the switch reside in the same subnet, that is different from the subnet of vlan1 on the switch.
11-17-2014 06:04 AM
On the switch, you assign ip address to the vlan interface. You do not have to add an IP address on the individual switch port.
