IPSEC Lan to Lan to Internet
GregMc
Hi I have a requirement to implement an IP-Sec service like the attached pic. Due to a 3rd party LAN that carries traffic I would like a IPSec tunnel between two routers. The end users will need internet ( NAT  to say a 192.168.1.x).
Does anyone have a suitable config to suit or could point me in the right direction. The end internet users will need DHCP too.
GregMc
My  final solution after days on this was to use Dynamic Multipoint IPsec VPN as described in :
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/41940-dmvpn.html..
I did note that there is a LOT of OLD doco out there that will not run properly on IOS 12.3 or higher for this type of stuff.
I used a mikrotik router(static) to simulate the 3rd part wan, as well as giving me an option to see the traffic live(using routeros torch!).. Thats why there are some static IP's on the interfaces(Also note the ip route statements I added to suit the testing environment )
HUB/Internet / Internal WAN Config... ( Runs on IOS v12.4 on c1841)
hostname hub
crypto isakmp policy 1
 authentication pre-share
crypto isakmp key MYPASSWORD address 0.0.0.0 0.0.0.0
crypto ipsec transform-set trans2 esp-des esp-md5-hmac
 mode transport
crypto ipsec profile vpnprof
 set transform-set trans2
interface Loopback0
 ip address 192.168.0.1 255.255.255.0
 ip virtual-reassembly
interface Tunnel0
 bandwidth 1000
 ip address 10.0.0.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nat inside
 ip nhrp authentication test
 ip nhrp map multicast dynamic
 ip nhrp network-id 100000
 ip nhrp holdtime 600
 no ip split-horizon eigrp 1
 delay 1000
 tunnel source FastEthernet0/1
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile vpnprof
interface FastEthernet0/0
 description WAN - To Internet Connection
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 no cdp enable
interface FastEthernet0/1
 description To 3rd party WAN
 ip address 10.130.100.37 255.255.255.0
 duplex auto
 speed auto
router eigrp 1
 network 10.0.0.0 0.0.0.255
 network 192.168.0.0
 no auto-summary
ip route 10.100.100.2 255.255.255.255 10.130.100.1
ip nat inside source list NAT interface FastEthernet0/0 overload
ip access-list extended NAT
 permit ip 192.168.0.0 0.0.255.255 any
**************** SPOKE SITE(router) connected to the 3rd party WAN / TO END USERS ****************
hostname Spoke
 mode transport
interface Tunnel0
 bandwidth 1000
 ip address 10.0.0.2 255.255.255.0
 ip mtu 1400
 ip nhrp map 10.0.0.1 10.130.100.37
 ip nhrp holdtime 300
 ip nhrp nhs 10.0.0.1
 delay 1000
 tunnel source FastEthernet0/0
 tunnel destination 10.130.100.37
 tunnel key 100000
 description WAN-Network
 ip address 10.100.100.2 255.255.255.0
 duplex auto
 speed auto
 description LAN-Network to
 duplex auto
 speed auto
router eigrp 1
 network 192.168.1.0
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.130.100.37 255.255.255.255 10.100.100.1
ip dhcp pool EndUsers
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 4.4.4.4
Seb Rupik
Hi there,
If you are trying to secure all the clear traffic from the 'lower' site on you diagram from transiting the 3rd party LAN, then this is  perfect use case for a tunnel/ "frontdoor" VRF. I wrote a blog post about it here:
https://configif.wordpress.com/2017/12/21/tunnel-vrf/
cheers,
Seb.
I will further investigate the tunnel/ipsec option today. That said, as its for a production environment I need to get this exact. I haven't had to do something like this before, so its a bit of a learning curve for me !
On the basis that the external facing interface of the lower router does not have a fixed IP address (guessing due to the use of DHCP) I would tend to head for an encrypted GRE tunnel. I have done quite a few of these in the past with Internet-based hub-&-spoke solutions, where the spokes have either fixed or variable IP addresses.  I guess there could be plenty of alternative methods.
Hope this helps,
Dave
GregMc
hostname hub
 mode transport
interface Loopback0
interface Tunnel0
 bandwidth 1000
 no ip redirects
 ip mtu 1400
 ip nat inside
 delay 1000
 tunnel key 100000
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 no cdp enable
 duplex auto
 speed auto
router eigrp 1
 network 192.168.0.0
 no auto-summary
hostname Spoke
 mode transport
interface Tunnel0
 bandwidth 1000
 ip mtu 1400
 delay 1000
 tunnel key 100000
 duplex auto
 speed auto
 duplex auto
 speed auto
router eigrp 1
 network 192.168.1.0
no ip http server
 dns-server 4.4.4.4
