Is Cisco WS-C2950G-48-EI 48-Port Switch a layer 3 device?
IsaiasPerez1977
I just bought one from Ebay and i can seem to find the IP routing command anywhere in the global configuration menu? I can t seem to find how to turn on SSH V2 either? its so weird. I am a beginner with CCNA and have been studying but cant seem to find certain commands. Do I need to update the version of the IOS?
14 Replies 14
Sandeep Choudhary
Hi Isaias,
Which Image u r running on switch ?
May be u r running Enhanced image running on the swicth ??
It works as layer 2 device.
The whole Catalyst 2950 platform does not support routing, they are solely layer-2 switches.
If you want to use cryptographic functions like SSH, you have to use an "IOS Crypto Image":
http://software.cisco.com/download/release.html?mdfid=275935124&flowid=2399&softwareid=280805680&release=12.1.22-EA14&relind=AVAILABLE&rellifecycle=ED&reltype=latest
(On more recent platforms, a Crypto IOS has a "k9" in it's name)
Rolf
Thank you very much. This was advertised as a L3 switch on ebay. What would be your recommendation for me to buy a cheap layer 3 switch that i can practice my CCNA Studies with? I have been looking in ebay.
Leo Laohoo
No.  2950-series switches is purely a Layer 2 appliance (switch).
Message was edited by: Leo Laohoo Duhhhh ... Type-o in my part.  I meant a 2950.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
As the other posters have noted, the 2950G is a L2 switch, not a L3 switch.  However, the -EI (enhanced) version does offer some commands not available on the -SI (standard) image version, and later IOS versions will offer some (new) commands (features).  For example, I recall rapid-STP is supported only in the later IOS versions.  Keep in mind, though, the 2950 series has been EoL for some time, so you'll likely not to find some features available in later series switches.  This may be the case for SSH v2.
As the others have already mentioned, you won't get IP routing on that device. But SSHv2 will work with the right image. The image you have to look for is a "c2950-i6k2l2q4-mz.version" and this will support SSHv2.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
isaiasperez77
Thank you very much guys. This was advertised as a L3 switch on ebay. What would be your recommendation for me to buy a cheap layer 3 switch that i can practice my CCNA Studies with? I have been looking in ebay.
HI Isaias,
Buy 3560  with 9 ports, its cheap.and works as layer 3 swicth
Reagrds
Dont forget to rate helpful posts
thank you very much.
HI Isaias,
Please mark this question as answered, it may help others.
How do you do that? I have searched all over the page and dont see where to mark the question as answered?
Have a look here:
I posted a question, how do I mark a reply as 'Correct Answer'?
Rolf
WS-C2960-8TC-L is a Layer2 Switch with limited L3 functionality. For studying it should be a nice device.
Perhaps bit late but the WS-C3550-24-EMI are cheaper then the 3560/2960 series , these WS-C3550-24-EMI are L3 also they are EOS in 2006 but are still used for CCNA/CCNP/CCIE labs. Around 90 euro on ebay .
Good luck !
