05-21-2003 01:38 AM - edited 03-02-2019 07:30 AM
Hello all, while I was reading some documentation i saw the following paragraph:
"Bundling of E1 links will be achieved by using unnumbered links, multiple unnumbered links use a single IP address usually configured as loopback address. Load balancing per packet is required on the E1 bundles to allow for efficient use of available bandwidth. "
It seemed quite interesting so I proceed to a test environment:
3 back-to-back E1 lines between two 72xx routers
first i checked that each back-to-back line is working properly: channel-group unframed on the controllers, on Router1 clock source line and on Router2 clock source internal, some private IPs, and all 3 interfaces pinged the other end.
Then I created a loopback on both routers with a new IP and changed to ip unnumbered loopback on each Serial:
========== config =========
Router1:
interface Loopback10
ip address 172.18.0.13 255.255.255.252
no ip directed-broadcast
interface Serial4/5:0
ip unnumbered Loopback10
interface Serial4/6:0
interface Serial4/7:0
Router2:
ip address 172.18.0.14 255.255.255.252
interface Serial4/0:0
interface Serial4/1:0
interface Serial4/2:0
Shouldnt it just work? or do i have to use multilink in order to bundle the E1s?
Is there any documentation on the above?
Rgrds
Solved! Go to Solution.
05-21-2003 10:49 PM
Please ignore the previous mail
When using unnumbered, you are using same subnet on bothends. This wouldnt work. I tried in my test lab.
so try giving different ip address on loopback interfaces and enable routing protocol.
-Deepu
05-21-2003 11:47 AM
It should work as is. Provided you have routes added, data will be shared among these lines. How data is shared depends what switching you are using (cef etc.)
Hope this helps.
Thanks.
05-21-2003 10:14 PM
Unfortunately it didnt (work) :(
Is there any documentation with configuration examples to see whats wrong with my config? Any ideas for debugging in order to find whats wrong?
05-21-2003 10:37 PM
When you are using ip unnumbered, do you have the end-to-end connectivity.
Coz, loopback ip address on each end, even though they are in same networks/subnetworks, there should be a way for the packets to go out. Otherwise, packets wouldnt go coz, the directly connected serial interfaces dont have ip address, so fail to connect to the other end.
Please try giving a static default route giving the next hop as your outgoing interface.
-Deepu
05-21-2003 10:49 PM
-Deepu
05-22-2003 12:24 AM
Thanx! problem solved.. it was exactly that, ip address 172.18.0.10/32 on one loopback, 172.18.0.11/32 on the other, router protocol, and it worked..
Thanx for your answer!
05-23-2003 07:11 AM
You can also get it working by using same subnet IPs (the way you had) but putting static routes for the other side loopback interface e.g.
ip route 172.18.0.13 255.255.255.255 ser4/0:0
Thanks.
07-10-2003 03:18 PM
Curious... do you see a significant increase in CPU util? I've read that loopback interfaces forces the router to use process switching. If this is true, is this a reasonable solution? If you have point-to-point E1s then I would suggest PPP Multilink.
I'm looking for the same solution but I'm stuck with frame relay encapsulation and cannot find a solid answer to aggregate two T1s between two routers.
