03-12-2003 07:25 AM - edited 03-02-2019 05:48 AM
I was wondering if anyone can help me with the MIB tree for the entry to get statistics for memory and cpu usage through SNMP.
I found in a forum the following fields but no seem to work with Pix Ver 6.2(2)..
OID cpu5sec 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1
OID cpu1min 1.3.6.1.4.1.9.9.109.1.1.1.1.4.1
OID cpu5min 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1
OID mem5minUsed 1.3.6.1.4.1.9.9.48.1.1.1.5.1
OID mem5minFree 1.3.6.1.4.1.9.9.48.1.1.1.6.1
OID curNumConnections 1.3.6.1.4.1.9.9.147.1.2.2.2.1.5.40.6
OID maxNumConnections 1.3.6.1.4.1.9.9.147.1.2.2.2.1.5.40.7
Any ideas? I am using a PIX-515
03-12-2003 10:56 AM
CPU utilization info is provided in the cpmCPUTotalTable of CISCO-PROCESS-MIB from 6.2(1) and later. The objects to use are: cpmCPUTotal5minRev, cpmCPUTotal1minRev and cpmCPUTotal5secRev as the earlier ones are deprecated. For Mem related objects CISCO-MEMORY-POOL-MIB can be looked at. When you poll the objects what do you get?.
03-12-2003 11:41 PM
This are the values I get if I use the old values. Seems that the Mem and Connections are Ok.. My problem seems to be with the cpu...
MC# snmpget -c public 192.168.1.1 .1.3.6.1.4.1.9.9.109.1.1.1.1.3.1
enterprises.9.9.109.1.1.1.1.3.1 = Gauge32: 0
MC# snmpget -c public 192.168.1.1 .1.3.6.1.4.1.9.9.109.1.1.1.1.4.1
enterprises.9.9.109.1.1.1.1.4.1 = Gauge32: 0
MC# snmpget -c public 192.168.1.1 .1.3.6.1.4.1.9.9.109.1.1.1.1.5.1
enterprises.9.9.109.1.1.1.1.5.1 = Gauge32: 0
MC# snmpget -c public 192.168.1.1 .1.3.6.1.4.1.9.9.48.1.1.1.5.1
enterprises.9.9.48.1.1.1.5.1 = Gauge32: 24248320
MC# snmpget -c public 192.168.1.1 .1.3.6.1.4.1.9.9.48.1.1.1.6.1
enterprises.9.9.48.1.1.1.6.1 = Gauge32: 42860544
MC# snmpget -c public 192.168.1.1 .1.3.6.1.4.1.9.9.147.1.2.2.2.1.5.40.6
enterprises.9.9.147.1.2.2.2.1.5.0.6 = Gauge32: 408
MC# snmpget -c public 192.168.1.1 .1.3.6.1.4.1.9.9.147.1.2.2.2.1.5.40.7
enterprises.9.9.147.1.2.2.2.1.5.0.7 = Gauge32: 734
03-13-2003 10:22 AM
What does the output of 'show cpu usage' on PIX show?
