10-27-2018 03:24 AM - edited 03-03-2019 08:55 AM
Hi, I've been trying to solve this problem for a quite long time and I gave up. I need some help ;)
I have two devices on my desk: C6500, sup720, pfc3c, msfc3 and C7600, rsp720, pfc3cxl, msfc4. Both are connected with a wire. Both ports are switchports with allowed vlan 2326. MPLS enabled. ping works
C6500 configuration:
mpls label protocol ldp mpls traffic-eng tunnels interface GigabitEthernet6/2 description to_C7600 switchport switchport trunk encapsulation dot1q switchport trunk native vlan 3425 switchport trunk allowed vlan 2326,3425 switchport mode trunk mtu 9216 ip arp inspection trust load-interval 30 no cdp enable spanning-tree vlan 3425 cost 10000 ip dhcp snooping trust interface Vlan2326 description to_C7600_vlan ip address 10.4.253.15 255.255.255.254 ip ospf mtu-ignore ip ospf 65405 area 0 mpls traffic-eng tunnels mpls bgp forwarding mpls ip ip rsvp bandwidth router ospf 65405 router-id 10.4.100.12 network 10.4.100.12 0.0.0.0 area 0 mpls ldp sync mpls traffic-eng router-id Loopback69 mpls traffic-eng area 0 mpls traffic-eng interface Vlan2327 area 0 mpls traffic-eng interface Vlan2326 area 0 interface Loopback69 ip address 10.4.100.12 255.255.255.255 #ping 10.4.8.8 source 10.4.100.12 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 10.4.8.8, timeout is 2 seconds: Packet sent with a source address of 10.4.100.12 !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms #sh mpls interfaces Interface IP Tunnel BGP Static Operational Vlan2326 Yes (ldp) Yes Yes No Yes Tunnel102 No No No No No interface Tunnel102 description tunnel_to_C7600_10_4_8_8 ip unnumbered Loopback69 tunnel source Loopback69 tunnel mode mpls traffic-eng tunnel destination 10.4.8.8 tunnel mpls traffic-eng autoroute announce tunnel mpls traffic-eng path-option 10 dynamic no routing dynamic ip rsvp bandwidth 8000 #sh mpls traffic-eng tunnels tunnel 102 Name: tunnel_to_C7600_10_4_8_8 (Tunnel102) Destination: 10.4.8.8 Status: Admin: up Oper: down Path: not valid Signalling: Down path option 10, type dynamic Config Parameters: Bandwidth: 0 kbps (Global) Priority: 7 7 Affinity: 0x0/0xFFFF Metric Type: TE (default) AutoRoute announce: enabled LockDown: disabled Loadshare: 0 [0] bw-based auto-bw: disabled Shortest Unconstrained Path Info: Path Weight: 1 (TE) Explicit Route: 10.4.253.15 10.4.253.14 10.4.8.8 History: Tunnel: Time since created: 1 hours, 12 minutes Time since path change: 7 seconds Number of LSP IDs (Tun_Instances) used: 441 Prior LSP: [ID: 441] ID: path option 10 [441] Removal Trigger: path error Last Error: RSVP:: Path Error from 10.4.253.14: Routing Problem (code 24, value 4, flags 0)
C7600 configuration:
mpls label protocol ldp mpls traffic-eng tunnels #sh ip vrf Name Default RD Interfaces MPLS_back 65203:1 Lo70 Vl2326 Tu102 interface GigabitEthernet1/1 description to_C6500 switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan 2326 switchport mode trunk mtu 9216 no cdp enable interface Vlan2326 description to_C6500 ip vrf forwarding MPLS_back ip address 10.4.253.14 255.255.255.254 ip ospf mtu-ignore ip ospf 65203 area 0 mpls ip mpls traffic-eng tunnels mpls traffic-eng administrative-weight 100 mpls bgp forwarding ip rsvp bandwidth router ospf 65203 vrf MPLS_back router-id 10.4.8.8 network 10.4.8.8 0.0.0.0 area 0 network 10.4.100.222 0.0.0.0 area 0 mpls traffic-eng router-id Loopback70 mpls traffic-eng area 0 mpls traffic-eng interface Vlan2326 area 0 ! interface Loopback70 ip vrf forwarding MPLS_back ip address 10.4.8.8 255.255.255.255 #ping vrf MPLS_back 10.4.100.12 source 10.4.8.8 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 10.4.100.12, timeout is 2 seconds: Packet sent with a source address of 10.4.8.8 !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms #sh mpls interfaces vrf MPLS_back
VRF MPLS_back:
Tunnel100 No No No No No
interface Tunnel102 description tunnel_to_C6500_10_4_100_12 ip vrf forwarding MPLS_back ip unnumbered Loopback70 tunnel mode mpls traffic-eng tunnel destination 10.4.100.12 tunnel mpls traffic-eng priority 7 7 tunnel mpls traffic-eng bandwidth 8000 tunnel mpls traffic-eng path-option 100 dynamic sh mpls traffic-eng tunnels tunnel 102 Name: tunnel_to_C6500_10_4_100_12 (Tunnel102) Destination: 10.4.100.12 Status: Admin: up Oper: down Path: not valid Signalling: Down path option 100, type dynamic Config Parameters: Bandwidth: 8000 kbps (Global) Priority: 7 7 Affinity: 0x0/0xFFFF Metric Type: TE (default) AutoRoute: disabled LockDown: disabled Loadshare: 8000 [0] bw-based auto-bw: disabled Shortest Unconstrained Path Info: Path Weight: 100 (TE) Explicit Route: 10.4.253.14 10.4.253.15 10.4.100.12 History: Tunnel: Time since created: 1 hours, 29 minutes Number of LSP IDs (Tun_Instances) used: 544
any ideas ?
