Community Helping Community
262
Highlighted
Beginner
MSFC2 boot problems
I,m triing to boot manually the msfc2 with the procedure: "how to recover a missing msfc from the supervisor,s show module command" from cisco .
In step 10, when i issue the set command the display is :
rommon 1 > set
PS1=rommon ! >
boot=
bootldr=
?=0
but shold be
rommon 1 > set
PS1=rommon ! >
boot=
bootldr=
conf reg=0x0
The difference is the question mark in the last line.
I continue all procedure and msfc2 boot ok .
But the problem is when the chassis is power down and power up again this msfc2 boots in rommon state always and i,m sure to change the conf-register to 0x2102 and save the configuration whit this boot lines:
boot system bootflash:c6msfc2-is-mz.121-2.E
boot bootldr bootflash:c6msfc2-boot-mz.121-2.E
May be any problem in the rom ?
thanks in advance.
Nazario Villalva
Any help will be welcome
thanks.
2 REPLIES 2
Re: MSFC2 boot problems
Hi Nazario,
I'd a problem like Yours with a customers of mine.
Today I've posted a question on the forum to try to understand how interacts BOOTVAR inside SUP and MSFC.
Had You any news ?
bye
Luigi
Participant
You might want to try the confreg utility in ROMON mode. I have included an example:
rommon 5 > confreg
Configuration Summary
enabled are:
load rom after netboot fails
console baud: 9600
boot: image specified by the boot system commands
or default to: cisco2-Cat6k-MSFC
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
disable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
enable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]:
change the boot characteristics? y/n [n]: y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[2]:
enabled are:
console baud: 9600
do you wish to change the configuration? y/n [n]: n
When the MSFC has booted issue a sh boot and if you have anyting thats odd then you will run into a problem again, it should look similar to the following except for the image names:
sh boot
BOOT variable = bootflash:c6msfc-jsv-mz.121-8a.E5.bin,12
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:c6msfc-boot-mz.120-7.XE1.bin
Content for Community-Ad
FusionCharts will render here
