06-08-2005 02:11 AM - edited 03-02-2019 11:02 PM
I'm new to Cisco products, so please bare with me if this sounds like an idiot of a question.
I have a Catalyst 4006, with moduels WS-X4013, WS-X4148-RJ, WS-X4232-L3 and WS-X4232-GB-RJ.
I'm trying to configure some of the ports to be able to have more than one Vlan number, i.e. Port 1 - Vlan number = 1 and 4.
Is this possible at all and with the GUI, HTTP access?
Also would anyone let me know what the latest software and firmware version are the this product?
Hope someone can help
Best regards
Scott
06-08-2005 03:04 AM
Hi Scott,
That is not possible and a port cannot be a member of multiple vlans. This is with the exception of the trunk port which is used to carry multiple vlan information from one switch to another switch.
HTH,
-amit singh
06-08-2005 03:17 AM
In answer to your second question, the latest version is 8.4(7)GLX;
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_release_note09186a00801a162e.html
Kevin Dorrell
Luxembourg
06-20-2005 06:49 AM
Can someone please let me know the lastest version of IOS I can install on this device.
Scott
06-08-2005 04:44 AM
hi Scott,
for what do u need these ports in multiple vlans?
Sebastian
06-08-2005 06:32 AM
I need 3 different Vlans to access one other Vlan.i.e 3 servers on different Vlans to access the firewall.
Is there another way to do this?
06-14-2005 12:41 AM
hi scott,
Sure there are some ways...
1. Why not routze the traffic? U might use Inter-Vlan Routing.
2. connect your switch to your Firewall with a trunk interface.
If u have a Cisco PIX refer here:
http://www.ciscotaccc.com/security/showcase?case=K10055697
hope this is of any help....
Sebastian
06-20-2005 10:37 AM
Hi ,you need to configure the VLAN on the Ethernet boards of your hosts : most can support VLAN now. And then configure a trunk to the switch. As for the InterVlan : either your switch supports ISL and you have an easy job (creating one sub-interface per VLAN) or you need one interface per VLAN!
Cheers
