N3K QoS problem
Does any one has any idea to do the QoS for this ?
Thank you
balaji.bandi
This is not QoS problem as per your title, this is the one you like to setup and you need guidance.
here is the document for reference  : suggest to do some config build as per you understand we can suggest tweaks.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/qos/503_u3_1/b_Cisco_Nexus_3000_QoS_Config_Guide_Release_503_U3_1/b_Cisco_Nexus_3000_QoS_Config_Guide_Release_503_U3_1_chapter_011.html
BB
 show running-config ipqos
!Command: show running-config ipqos
!Time: Tue May 28 14:12:47 2019
version 6.0(2)U6(7)
class-map type qos match-all Low
  match dscp 8
class-map type qos match-all High
  match dscp 56
class-map type qos match-all Medium
  match dscp 46
class-map type qos match-all othertraffic
  match dscp 0
policy-map type qos QoS
  class High
    set qos-group 6
  class Medium
    set qos-group 5
  class Low
    set qos-group 4
  class othertraffic
    set qos-group 3
  class class-default
system qos
  service-policy type qos input QoS
That  is my config, but I still get high latency with audio system, do you have any idea why?
