need help with weirdly broken 2512
garnet.ulrich
I had a fully functional 2512 (old token ring terminal server) yesterday but today after a cold reboot it hangs at (with the config register set to 0x2102):
System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1997 by cisco Systems
2500 processor with 2048 Kbytes of main memory
<<<hung at this point>>>
With the config register set to 0x141 to boot from ROM image, it goes a little further before hanging:
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Wed 10-Sep-97 13:06 by phester
Image text-base: 0x01010000, data-base: 0x00001000
Anyone have any ideas whether I should be searching out replacement bootroms, dram, flash or anything else? Ever seen this before?
Thanks.
garnet
rfroom
Seen this before as a hardware failure. Not sure of component, but a replacement fixed it.
Thank you! I was fairly sure it is hardware but anything helps. Anyone else have any idea?
Here is some more output that might give someone a clue?
o/r 0xa102
>i
Exiting boot state - setting bus error vector...[OK]
Sizing RAM and ROM...16 bit wide EPROM...8 Mbit EPROMs...32 bit wide CPU RAM...Found 4 MB CPU RAM...[OK]
Testing low memory...0's...1's...address+1...[OK]
Sizing memory...writing...reading...4096 pages...memsize() returned 0x00400000[OK]
Setting cookie...[OK]
Setting memory to all ones...[OK]
Setting up exception vectors...[OK]
Enabling processor caches...set CACR to 0x2101...[OK]
Processor type is: 2500[OK]
Enabling timers...[OK]
Enabling Watchdog timer...[OK]
Sizing NVRAM...found 32K bytes of NVRAM[OK]
Searching for system code...found at 1010000, magic number = 4E56...[OK]
Setting up monitor variables...
found 2048 total Kbytes of DRAM, iomem_base set to 200000[OK]
Reading hardware revision register...
2500 processor, hardware revision = 14
Parity Logic tests...[OK]
Exiting to monitor command level
t m
Memory/Bus diagnostic
Starting Address [0x1000]?
Ending Address [0x1FF000]?
Hex argument for variable tests [0xFFFF]?
Select Tests [all]?
Number of passes to run [2]?
Trigger word for hardare debugging [0]?
Message Level (0=silence, 1=summary, 2=normal)[2]?
Testing addresses between 0x1000 and 0x1FF000
Begin pass 0, test 0 1
