Netflow Generation Appliance (NGA-3240) and authentication with ACS
REUBEN CHIN
I would like to configure this appliance to use ACS authentication.  Right now I use local authentication, but would prefer ACS instead.
Both the WebUI and the console are using this local method and I would much prefer it to use ACS instead.
I get the following prompts:
root@HOSTNAME.localdomain# ip http tacacs+ enable <ACS IP ADDRESS> en-secret-key <KEY>
Failed to enable Tacacs+
REUBEN CHIN
Update...
     Secret key:
     Repeat secret key:
     Successfully enabled Tacacs+
The problem, I'm faced with now is that after entering the above the WebUI is still not accessible.
