Join Customer Connection to register!
1556
ramkumar62
Beginner
NIC Card redundancy with Cisco UCS C220 + P81E Virtual Interface Card/ 2-port 10Gbps
Hi Guys,
UCS C220 supports only a single dualport  P81E nic card due to limited availability of pcie slots, Is dual port NIC card has same reliability as dual NIC card or what is the chance or probability of failure of NIC cards. HA being  my important goal should I choose a different chasis.
3 REPLIES 3
Marwan ALshawi
Advisor
Well dual ports of one card is less redundant from dual ports from different cards from HW point of view
If you are concerned about thus pick a chassis of ucs c that has the built-in nic card and additional slot where you can order another nic card too for higher HW redundancy
Hope this help
If helpful rate
HI ,
Due to rackspace constraints I need to stick with c220(1 RU server) it has one full height Pcie and half-height pcie
when I create configuration I am not able to select 2 nos  P81E but I can choose 1 p81E and one
Qlogic QLE8242-CU Dual Port 10 GbE FCoE CNA will it serve the purpose.
Marwan ALshawi
Advisor
If you have dual port nic U can configure software redundancy on the esxi nic teaming
However from hardware point of view your using one nic module
Hope this help
If helpful rate
Content for Community-Ad
