Not able to change auto to trunk mode on switch
aksher
SW-B-TOP(config-if)#switchport mode trunk
When trying to execute the above command am getting the following error.
Command rejected: An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
29 Replies 29
glen.grant
You have to specifically set the encapsulation type first "switchport encapsulation dot1q" then try youir command...
it's not accepting.
SW-B-TOP(config-if)#switchport encapsulation dot1q
% Invalid input detected at '^' marker
the model is CGESM.
You forgot the "TRUNK" portion to the command. It's SWITCHPORT TRUNK ENCAPSULATION DOT1Q
it was quick thanks for this handy command
Thanks a lot.It worked for me
Thanks for that. Sometimes I'm a dummy lol.
glen.grant
You need to specifically set the encapsulation first , "switchport encapsulation dot1q" then issue your trunk command...
specially in cisco 3500 series..
Switch (config-if) # switchport trunk encapsulation ( dot1q | isl )
If you are using cisco use command
#switchport trunk encapsulation isl
OR ( multi-vendors like hp, juniper & also for cisco)
#switchport trunk encapsulation dot1q
I hope It helps you
Thank you kindly, you helped in finding a solution to my problem.  :)
glen.grant
can you post the config...
Hi All,
The command which he need to enter first is
"switchport trunk encapsulation dot1q " and then he can confgigure the interface in trunk mode.
So try this command
switch(config)#interface fa0/1
switch(config-if)#switchport trunk encapsulation dot1q
switch(config-if)#switchport mode trunk
and you will be good to go.
HTH, if yes please rate the post.
Ankur
