ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Not getting CPU utilization info for CISCO ASA 5520
Device config is shown as follows in application doing the discovery.
# Cisco ASA 5520
.1.3.6.1.4.1.9.1.670 {
    TYPE = Firewall
    VENDOR = Cisco
    MODEL =  ASA 5520
    CERTIFICATION = CERTIFIED
    CONT = Cisco-Router
    HEALTH = Cisco-Entity
    NEIGHBOR = Cisco-Cdp
INSTRUMENTATION:
    CPU/Memory                          = CiscoSwitch:DeviceID
    Interface-Fault                     = MIB2
    Interface-Performance               = MIB2
    Interface-Ethernet-Performance      = CiscoRouter_Ethernet
Cisco ASA version is:   Cisco Adaptive Security Appliance Version 8.2(5)13
Per Cisco Support website that this OID .1.3.6.1.4.1.9.9.109.1.1.1.1.5  has been  deprecated
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
for CPU we need ".1.3.6.1.4.1.9.9.109.1.1.1.1.8 "  but snmp walk does not return this value and still shows the old OID ending with 1.5
snippet from the walk file shows:
.1.3.6.1.4.1.9.9.109.1.1.1.1.4.1|4|
.1.3.6.1.4.1.9.9.109.1.1.1.1.4.2|4|
.1.3.6.1.4.1.9.9.109.1.1.1.1.5.1|2|
.1.3.6.1.4.1.9.9.109.1.1.1.1.5.2|2|
.1.3.6.1.4.1.9.9.117.1.3.1.0|2|
.1.3.6.1.4.1.9.9.147.1.1.1.1.0|0|
.1.3.6.1.4.1.9.9.147.1.1.2.1.0|0|
.1.3.6.1.4.1.9.9.147.1.2.1.1.1.2.4|4661696C6F766572204C414E20496E74657266616365|
Is there any new updated agent available for Cisco ASA 5520 that contains the oid  ".1.3.6.1.4.1.9.9.109.1.1.1.1.8 "
1 ACCEPTED SOLUTION
Highlighted
Beginner
Just to add some strangeness ...
We have an ASA 5585-X SSP10 running 8.4(2) . I did an snmpwalk -v2c -Ofn . The 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1 OID was not found in the output.
But, I fed that OID to our Zenoss monitor, and guess what! It works, we are getting an accurate CPU graph that matches what I see in the ASDM!
Preparing Command...
Executing command snmpwalk -cTry2GuessThis -v2c 10.0.0.1    1.3.6.1.4.1.9.9.109.1.1.1.1.5.1 against pantsonFirewall.bubba.com
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.5.1 = Gauge32: 41
DONE in 0 seconds
So ... what does this mean?!?
Steve
4 REPLIES 4
Highlighted
Frequent Contributor
Re: Not getting CPU utilization info for CISCO ASA 5520
I do use mrtg for CPU ASA 5510 ver 8.2
1.3.6.1.4.1.9.9.109.1.1.1.1.4.1&1.3.6.1.4.1.9.9.109.1.1.1.1.5.1
it shows the same as sh cpu
plz rate post if it helped
Highlighted
Beginner
The application I am using don't use cpmCPUTotal5min (.1.3.6.1.4.1.9.9.109.1.1.1.1.5) to get CPU utilization for cisco devices.
The cisco site states that cpmCPUTotal5min is deprecated by cpmCPUTotal5minRev (.1.3.6.1.4.1.9.9.109.1.1.1.1.8)
It would make sense to have Customer upgrade the ASA version but I just need to confirm with Cisco Support that the
latest 5520 ASA CISCO-PROCESSOR-MIB contains this mib (.1.3.6.1.4.1.9.9.109.1.1.1.1.8)
Johnny
Highlighted
Hello guys!
I want to create many scripts to check many things..
I have some doubts, like:
what is OID?
what is MIB?
Is the above the same thing?
How can I get the OID or MIB??
Example. I want to check vpn.. so I can use the command:
sh vpn-sessiondb
How can I use the OID or MIB to get that result?
Thanks!
Highlighted
Beginner
DONE in 0 seconds
Steve
