09-27-2018 04:32 AM - edited 03-03-2019 08:54 AM
Hi! So I'm trying to figure out if it is possible to have an NTP nexus act as a server for all devices in a network and authenticate them and that same nexus act as a client to another server but without authentication, I think that's not possible but would like to confirm.
Apart from that I would like to know where in a 3 layer architecture would that nexus server be. Every device connects through an OOB management network and NTP client get their time using that network, should the nexus server be in the backbone or one of the nexus devices in the management network?
09-27-2018 05:08 AM
Yes you can have Server and client using Nexus, yes good to have authentication for the NTP client, so it will be secured.
09-28-2018 04:08 AM
I know I can have authentication on Cisco Nexus, what I want to know is if you can use the same device as a client without authentication and as a server with authentication
09-28-2018 11:58 AM
yes this is possible.
09-29-2018 04:45 AM - edited 09-29-2018 04:47 AM
No, you can't use the same device as a client without authentication and as a server with authentication.
If it is required then you can use two NTP servers in your network. One with an authentication and another without authentication.
Deepak Kumar
