11-06-2018 07:06 AM - edited 03-03-2019 08:55 AM
I want to make sure that the special RJ45 connectors that I am considering will fit side-by-side on a Cisco switch. What is the physical distance between ports on Cisco switches, or this switch in particular?
11-06-2018 07:55 AM
distance between switch ports on most switches is about 2mm
regards, mk
11-06-2018 07:59 AM
That doesn't sound right. The backshell of my RJ45 is 14mm wide. Looking at photographs, the distance can't be much different from that, either way.
11-06-2018 08:00 AM - edited 11-06-2018 08:05 AM
you asked about the distance between the ports :)
the port itself should be 10mm wide
regards, mk
11-06-2018 10:31 AM
As you can see from the picture below the distance is about 2.10mm.
Greetings
11-06-2018 02:05 PM
precision of language when seeking assistance
not a problem though ;)
regards, mk
