Community Helping Community
505
Highlighted
Beginner
Problem in accessing hotmail..
I am using 5300 access server, My uplink is connected to ISP..For security perpose I am using access lists for security.Users which are connected on local LAN can able to access any sites with ssl encreption.. But when thry are accessing hotmail, page is showing timeout after filling login information in front page of hotmail. I can using any other mail account. Is I need to open any specific port??..
Thanks..
3 REPLIES 3
Beginner
Re: Problem in accessing hotmail..
hotmail supports 128Bit encryption.May be you can permit the Hotmail web trafiic by implenting the the Hotmails IP addresses in the access list and try what happens
Beginner
Might look at SSL. Hotmail is port 443. Are you blocking that port?
Beginner
I already open a 447 port..I am using c2600-io3-mz.121-15.bin ios. also accesslists are as follow...
ccess-list 105 deny ip host 255.255.255.255 any
access-list 105 deny ip 194.23.24.0 0.0.0.255 any
access-list 105 permit icmp any any echo-reply
access-list 105 permit ip host 62.150.11.210 any
access-list 105 permit icmp any 194.23.24.0 0.0.0.255 time-exceeded
access-list 105 permit icmp any 194.23.24.0 0.0.0.255 packet-too-big
access-list 105 permit icmp any 194.23.24.0 0.0.0.255 traceroute
access-list 105 permit icmp any 194.23.24.0 0.0.0.255 unreachable
access-list 105 permit icmp 194.23.28.0 0.0.0.255 194.23.24.0 0.0.0.255
access-list 105 permit tcp any 194.23.24.0 0.0.0.255 eq smtp
access-list 105 permit tcp any host 194.23.24.6 eq www
access-list 105 permit tcp any 194.23.24.0 0.0.0.255 eq 1863
access-list 105 permit tcp any 194.23.24.0 0.0.0.255 range 3100 3199
access-list 105 permit tcp any 194.23.24.0 0.0.0.255 eq 6891
access-list 105 permit tcp any 194.23.24.0 0.0.0.255 eq sunrpc
access-list 105 permit tcp any host 194.23.24.5 eq pop3
access-list 105 permit tcp any 194.23.24.0 0.0.0.255 eq 443
access-list 105 permit tcp 194.23.28.0 0.0.0.255 194.23.24.0 0.0.0.255 eq telnet
access-list 105 permit udp 194.23.28.0 0.0.0.255 194.23.24.0 0.0.0.255 eq snmp
access-list 105 deny ip any any
Thanks..
Content for Community-Ad
FusionCharts will render here
