Problem of pinging server
ljywm19
I cant ping the server from pc and I have attached my packet tracer below. Really appreciate if someone can help. Thank you.
Filip Po
you have wrong IPs configured on Server-PT to Router11 link.
On Server side:
C:\>ipconfig
FastEthernet0 Connection:(default port)
Connection-specific DNS Suffix..:
Link-local IPv6 Address.........: FE80::230:A3FF:FE9C:E567
IPv6 Address....................: 2001:DB8:CAFE:1::10
IPv4 Address....................: 64.100.1.254
Subnet Mask.....................: 255.255.255.0
Default Gateway.................: FE80::1
                                           64.100.1.254
On router side this segment has
interface GigabitEthernet0/1
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
So, correct the IPs on that Server-PT to Router11 segment and would be able to ping your server from PC.
And you can't have same IP of gateway and Server-PT (64.100.1.254).
Filip Po
On Server side:
C:\>ipconfig
                                           64.100.1.254
duplex auto
speed auto
I see. Thanks for your help.
