Highlighted
Beginner
Problem with setting up etherchannel.
I am trying to create an etherchannel between two switches 2970G and a 3750G
The configuration of the interfaces is as follows :
interface Port-channel3
 switchport mode access
 macro description 3750G-16TD
interface GigabitEthernet2/0/1
 switchport mode trunk
 switchport nonegotiate
 channel-group 3 mode active
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
When I connect the switches i get this message :
%EC-5-CANNOT_BUNDLE2: Gi2/0/4 is not compatible with Po3 and will be suspended (dtp mode of Gi2/0/4 is on, Po3 is off)
%EC-5-CANNOT_BUNDLE2: Gi2/0/3 is not compatible with Po3 and will be suspended (dtp mode of Gi2/0/3 is on, Po3 is off)
any idea how to fix the etherchannel ?
Everyone's tags (5)
3 REPLIES 3
Beginner
Issue seems with interface attribute, please check duplex and speed of both interfaces.
Error Message    EC-5-CANNOT_BUNDLE2: [chars] is not compatible with [chars] and will
be suspended ([chars]).
Explanation    This message means that the interface has different interface attributes than other ports in the EtherChannel. For the interface to join the bundle (EtherChannel), change the interface attributes to match the EtherChannel attributes. The first [chars] is the interface to be bundled, the second [chars] is the physical interface that is already in the bundle, and the third [chars] is the reason for the incompatibility.
Recommended Action    Change the interface attributes to match the EtherChannel attributes.
Beginner
Not sure if that was because
Not sure if that was because the port-channel 3 configured as access port but the members port were configured as trunk port.
Beginner
 I am talking about Gi2/0/4
I am talking about Gi2/0/4 and Gi2/0/3, check duplex and speed of both interfaces same as GigabitEthernet 2/0/2 setting.
Sajid Ali Pathan
Content for Community-Ad
July's Community Spotlight Awards
