01-30-2006 12:03 PM - edited 03-03-2019 01:37 AM
Hi ALL,
Hope you may be able to help me out here.We have a number of Allied 8350GB 48 PORT layer 2 switches connected via LES Circuits to our 6500.We seem to have to reset these swithes quite often 3 today! for no apparent reason.The software on the Allied has been upgraded and still noe joy,spanning tree is disabled on these switches also.
Any ideas?
01-30-2006 01:41 PM
did you hard-code the speed and duplex on both sides?
01-30-2006 02:52 PM
unless you have a specific reason I wouldn't disable spanning tree , leave it running .
01-30-2006 07:53 PM
Are your LEC's still operational on the Allied switches? Are your 6500's LANE connected also? If so are you 6500's using some or all of the same ELAN's that are on your Allied switch? Maybe you are having a LES/BUS problem. It's hard to tell from the info you gave.
01-31-2006 12:25 AM
Hope this helps
The allieds have alltheir ports tied down at both ends to 10 Full Duplex.Some of the switches are fed directly off our 6500 and some off 2950 switches via the 6500. All the allieds have trunk ports connected to them with two Vlans running. LECS not operational LANES not connected.The allieds just seem to hang and wont pass data and will not respond to pings,this can happen at any time even in the middle of the night when the traffic is minimal.
Cheers Jim
