We use PRTG to monitor our firewalls. We recently installed ASA a 5516x and an ASA 5508x in our 2 offices. On the 5516x I am constantly seeing "discards in" no matter on the level of traffic. We are seeing none on the 5508x. I looked at the interfaces on the ASA's and both show a good level of dropped packets so I am assuming that this stat is not from that parameter. Anyone have experience with this? Is this something I should be concerned about or am I chasing a red herring?
You can see the traffic and drops graph for the last 2 hours below and the show interface results form the 2 devices.
5508x# sho interface external1
Interface GigabitEthernet1/8 "external1", is up, line protocol is up
Hardware is Accelerator rev01, BW 1000 Mbps, DLY 10 usec
Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
Input flow control is unsupported, output flow control is off
MAC address x.x.x, MTU 1500
IP address x.x.x.x, subnet mask x.x.x.x
1352099182 packets input, 1248181988665 bytes, 0 no buffer
Received 26121380 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
840821495 packets output, 303886304208 bytes, 0 underruns
0 pause output, 0 resume output
0 late collisions, 0 deferred
0 input reset drops, 12 output reset drops
input queue (blocks free curr/low): hardware (1996/1821)
output queue (blocks free curr/low): hardware (2047/1936)
Traffic Statistics for "external1":
1350539267 packets input, 1223808333580 bytes
840821495 packets output, 288537872740 bytes
3367201 packets dropped
1 minute input rate 213 pkts/sec, 64501 bytes/sec
1 minute output rate 193 pkts/sec, 54109 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 208 pkts/sec, 57302 bytes/sec
5 minute output rate 192 pkts/sec, 54577 bytes/sec
5 minute drop rate, 0 pkts/sec
5516x# show interface external1 detail
Description: External
38689714 packets input, 28912915454 bytes, 0 no buffer
Received 32680 broadcasts, 0 runts, 0 giants
0 L2 decode drops
34143951 packets output, 14431674256 bytes, 0 underruns
0 input reset drops, 0 output reset drops
input queue (blocks free curr/low): hardware (1949/1820)
output queue (blocks free curr/low): hardware (2047/1668)
38660025 packets input, 28185464932 bytes
34143951 packets output, 13766201049 bytes
105959 packets dropped
1 minute input rate 179 pkts/sec, 59164 bytes/sec
1 minute output rate 182 pkts/sec, 53321 bytes/sec
1 minute drop rate, 1 pkts/sec
5 minute input rate 206 pkts/sec, 75914 bytes/sec
5 minute output rate 204 pkts/sec, 62180 bytes/sec
5 minute drop rate, 1 pkts/sec
Control Point Interface States:
Interface number is 9
Interface config status is active
Interface state is active
