Highlighted
Beginner
"Te12/9 Receive Power Sensor on SW-NL-EDC_eupdswcore001 ".
I am recieving this frequent warning alerts "Te12/9 Receive Power Sensor on SW-NL-EDC_eupdswcore001 ".
switch is 6513
swcore001#sh inventory
NAME: "Transceiver Te12/9", DESCR: "X2 Transceiver 10Gbase-SR Te12/9"
Can you please what all issues related to above device mentioned.How to recitfy this alerts
3 REPLIES 3
If you issue a "sh int te12/9 transceiver details" can you post your results?
Beginner
Re: "Te12/9 Receive Power Sensor on SW-NL-EDC_eupdswcore001 ".
eupdswcore001#sh int te12/9
TenGigabitEthernet12/9 is up, line protocol is up (connected)
  Hardware is C6k 10000Mb 802.3, address is a493.4c0b.fa30 (bia a493.4c0b.fa30)
  Description: Connected to EUPDENCD00
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s
  Transport mode LAN (10GBASE-R, 10.3125Gb/s), media type is 10Gbase-SR
  input flow-control is on, output flow-control is off
  Clock mode is auto
  Last input 00:00:08, output 00:00:21, output hang never
  Last clearing of "show interface" counters 6w5d
  Input queue: 0/2000/367238/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 36230000 bits/sec, 5702 packets/sec
  5 minute output rate 30438000 bits/sec, 5706 packets/sec
     13367144638 packets input, 9126136368797 bytes, 0 no buffer
     Received 6645935 broadcasts (3920984 multicasts)
     0 runts, 367238 giants, 0 throttles
     367239 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     14612403292 packets output, 10106745813442 bytes, 0 underruns
eupdswcore001#sh int te 12/9 transceiver detail
Transceiver monitoring is disabled for all interfaces.
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                            High Alarm  High Warn  Low Warn   Low Alarm
           Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Te12/9       35.3                74.0        70.0         0.0       -4.0
            Voltage            Threshold   Threshold  Threshold  Threshold
Port        (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Te12/9       N/A                   N/A         N/A         N/A        N/A
            Current            Threshold   Threshold  Threshold  Threshold
Port        (milliamperes)     (mA)        (mA)       (mA)       (mA)
Te12/9        6.9         --     N/A        N/A        N/A       N/A
            Optical            High Alarm  High Warn  Low Warn   Low Alarm
            Transmit Power     Threshold   Threshold  Threshold  Threshold
Port        (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te12/9       -2.8                 2.9        -1.0        -7.3      -11.3
            Receive Power      Threshold   Threshold  Threshold  Threshold
Te12/9      -13.0         -       2.9        -1.0        -9.9      -13.9
Hall of Fame Master
Your problem is that you're operating below the warning threshold level for optical receive power. -13.0 dBm received and the threshold is -9.9.
You need to go through the path and clean your connectors and possibly replace any marginal jumpers. If that fails, you can try moving the path to another pair of fiber with less loss. You should have OM3-rated fiber or better end to end.
Content for Community-Ad
July's Community Spotlight Awards
