Highlighted
Beginner
Rate limiting on Catalyst 2950T switches
I would like to allow some users full access to internal servers, but only provide them with 2 Mbps access to the Internet. As far as I understand I cannot use the deny statement when defining the access-list for the class-map and therefore I am asking for your help. (The config below work well for rate-limiting all traffic, but I would need full access for traffic matching access-list 111):
access-list 111 remark [ Traffic not to be rate limited ]
access-list 111 permit ip 10.0.0.0 0.255.255.255 192.168.0.0 0.0.255.255
access-list 112 remark [ Traffic to be rate limited ]
access-list 112 permit ip 10.0.0.0 0.255.255.255 any
class-map match-all Internet-Class
match access-group 112
policy-map Internet
description [ Rate limit Internet access ]
class Internet-Class
police 2000000 65536 exceed-action drop
interface FastEthernet0/1
service-policy input Internet
interface FastEthernet0/24
Any help would be very appreciated!
Harald
11 REPLIES 11
Highlighted
Contributor
I'm not sure if you forgot it, but you need to call ACL 111:
class-map match-all local_traffic
match access-group 111
policy-map Internet
class local_traffic
police 98000000 65536
And in case you don't have it already:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00801cdef0.html
Hope this helps,
-Mark Turpin
-- -Mark Turpin
Highlighted
Thanks for your reply Mark!
However, when I try to add the local_traffic map to the policy map I get the following error:
Error:Class-map has a different mask than the Policymap
If I change the access-list to something like:
access-list 112 permit ip 10.0.0.0 0.255.255.255 172.16.0.0 0.0.255.255
then I am able to put both class statements in the policy-map, but I would like to use "any" since it is traffic bound for the Internet.
Is it possible to do this in some way?
Thanks again for your help!
Harald
Highlighted
Hi Harald,
As far as i understand class- maps u can use deny statements in acl's for class-maps... A deny in an acl simply tells the class-map that this kind of traffic do not match.
regards,
Sebastian
Highlighted
Thanks for your reply Sebastian!
Unfortunately, the Catalyst 2950 QoS configuration documents states that "Deny statements are not supported for QoS ACLs", which I noted when I could not define them on the switch.
Harald
Highlighted
Harald,
Can you paste your config again? It sounds as if you're trying to call two different ACP's or "masks" as your error indicates.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00801cde58.html#75868
Mark Turpin
-- -Mark Turpin
Highlighted
Thanks again for the reply!
My "working" configuration is as follows:
class-map match-all Local-Class
policy-map Internet-Policy
class Local-Class
description [ Local LAN facing interface ]
service-policy input Internet-Policy
description [ Internet facing interface ]
However, I would like to change "172.16.0.0 0.0.255.255" in access-list 112 to "any" since it should apply to all Internet traffic. If I try to do that I get the mask error I previously mentioned.
Harald
Highlighted
Just out of curiousity, tell me what "show mls masks" tells you.
I have a feeling that the 2950 is looking at the 10/8 -> 192.168/16 and 10/8 -> any statements as overlapping.
Let's assume you have 10.15.x.x as your network. What happens if you leave ACL111 as is, and rewrite ACL112 as:
access-list 112 remark [ Traffic to be rate limited]
access-list 112 permit ip 10.15.0.0 0.0.255.255 any
Let me know what you find out! :)
-Mark
-- -Mark Turpin
Highlighted
I tried to change the access-list 112 as you suggested, but I still got the "mask error" when trying to define the policy.
The "show mls masks" gives (with only Local-Class in the policy-map):
Mask1
Type : qos
Fields : ip-sa(255.0.0.0), ip-da(255.255.0.0)
Policymap : Internet-Policy
Interfaces : Fa0/1, Fa0/24
Harald
Highlighted
You will probably want to open a TAC case to confirm. I'm guessing that we're hitting a wall when we call the 'any' keyword which is mixing masks. You can't mix masks inside the same policy, and I am guessing that the any mask falls in to a system mask, and your other ACL is a user defined mask.
Only one other thing I can think of to try: put the policy only on f0/1 - your ingress interface and see if it makes a difference.
If changing the interface the policy is applied to, I'd try calling the TAC :)
Sorry I couldn't help more, here's a URL I've been referencing:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00802c31e3.html#wp1054266
-Mark
-- -Mark Turpin
Highlighted
Only applying the policy to one interface unfortunately did not solve the problem either.
I will try to find another solution to the problem.
Harald
Highlighted
Hi I have a Cisco 2950EI and while the rate limiting is good in ingress, I wanted to also blend in prioritization in the prority queue. However in the policy map I would like to make bsd10 traffic low priority, while the rest is high. I typed some stuff into the 2950 'policy-map bsd10' but I am not sure how these rules behave:
class-map match-all match-any
class-map match-all bsd10only
match access-group name bsd10
policy-map 8Mbps
class match-any
police 16000000 32768 exceed-action drop
set ip dscp 56
policy-map bsd10
class match-any
police 11000000 32768 exceed-action drop
set ip dscp 8
class bsd10
set ip dscp 8
police 17000000 32768 exceed-action drop
Content for Community-Ad
