03-11-2004 06:47 AM - edited 03-12-2019 04:32 PM
who is it possible to read the serial number of a 2611XM by CLI(online)
Processor board ID (sh ver) isn't the serial number
os the Router (here 2611XM) !!!
is there a undocumented command ?
any tips
r-e-g-a-r-d-s
03-11-2004 07:39 AM
you cannot get the serial number from the command line, you have to physically look at the device.
GP
07-08-2014 01:59 AM
I can't find serial number at the device, in case in some device i can get the serial number from CLI but in another device i can't
07-08-2014 03:10 PM
Depending on the IOS you are using, you can check with the following commands:
1. sh version; and
2. sh inventory
07-16-2014 03:55 PM
I am pretty sure that 2600 is old enough that the show inventory command does not work on it. If you use the command it may not return a value or it may return a value - but my experience is that value returned does not match the value on the label on the router.
rICK
