Highlighted
Explorer
Requirement for CCNP and CCVP recertification
My CCNP / CCVP is about to expire. Am I write to say that I will be recertified in BOTH - CCNP and CCVP -  if I pass anyone of the following exam?
642-902 ROUTE Implementing Cisco IP Routing (ROUTE)  or
642-813 SWITCH Implementing Cisco IP Switched Networks (SWITCH)  or
642-832 TSHOOT Troubleshooting and Maintaining Cisco IP Networks (TSHOOT)
Are the above new or obsolete?
Another question?
I have posted this Under Other Network Infrastructur eSubject Location.
I thought there used to be Certification Location to paste these type of questions, but can't seem to find it now at the Cisco Forum HOME page today.
1 REPLY 1
Highlighted
Hall of Fame Guru
According to the Cisco web site the exams that you mention are still the current versions of the exams. See this link for additional details:
http://www.cisco.com/web/learning/le3/le2/le37/le10/learning_certification_type_home.html
And according to that site passing any current 642 level professional exam should re-certify the CCNP and CCVP (which now apparently will be identified as CCNP-Voice).
You are correct that there used to be forums within the Support Forums for Certification related discussion. A while back Cisco reorganized the forums and moved the Certification discussion to the Cisco Learning Network. See this link for details
https://learningnetwork.cisco.com/community/certifications
Rick
Rick
