I have a PA-4E1G-120 balanced card in a 7500, which has DB15 connectors. The carrier has provided an RJ48 presenation. Therefore, I need an E1 balanced cable from DB15 to RJ48.
The closest match I can find is the CAB-E1-PRI/NT, DB15 to RJ48C for connecting AS5200 E1 as Network Terminal. Will this cable work? I can't find a pinout for it.
Some further information is that at http://www.cisco.com/application/pdf/en/us/guest/products/ps2033/c2001/ccmigration_09186a00800c4bcc.pdf
in table 1.4 it mentions an RJ45 pinout for this PA, but I have RJ48. What is the difference between RJ45 and RJ48?
TIA
