190
Highlighted
Beginner
Router 7606 does not show the inventory for the Fan module
I have a issue with a router 7606, specifically with  fan module, the LC go down because it does have sufficiently cooling , I changed the Fan module, the IOS, The power supply, and I still have the same issue, Besides the Router does not show the inventory or PID  for module fan,
logg" system minor alarm on operating fan count"
Someone knows what could be happening,
2 REPLIES 2
Highlighted
Check this:
Can you try this;
7606-01#show environment status fan-tray 1
fan-tray 1:
  fan-tray 1 type: FAN-MOD-6SHS
  fan-tray 1 mode: Auto
  fan-tray 1 fan-fail: OK
7606-01#show power
Fan  Type               Watts   A @42V State
1    FAN-MOD-6SHS        180.18  4.29  OK............................ FAn try
If above doesnt work then try the below link:
https://supportforums.cisco.com/discussion/10824271/7606-s-and-fan-module-6shs-version-1
inayath
*Plz dont forget to rate if this info is helpfull.
Highlighted
thanks
 I did it, but i still have the same issue,  upgrated the ios, changed fan module,  but it is not working,
will be the chassis?
