ROUTER ON A STICK WITH 2 SWITCHES
fb_webuser
Level 6
Level 6
which topoplogy is the right one? 2 switches connected to a router or a switch connected to the router and the other switch connect to the switch?
Posted by WebUser Charalampos Skeleton C'trattou from Cisco Support Community App
Sandeep Choudhary
You can connect 2 swicth to router:
When you create vlans, you are essentially creating seperate broadcast domains.  Generally when you create seperate broadcast domains, you are creating different subnets.  A layer 2 switch doesn't know how to forward traffic destined for a different broadcast domain.  You need a layer 3 device to route traffic between your vlans(broadcast domains).  I would think that ROAS is just the implementation of intervlan routing when there is no layer 3 switch available.
see the example:If you are configuring on Router
Create sub-interfaces, set 802.1Q trunking protocol and ip address on each sub-interface
Router(config)#interface f0/0
Router(config-if)#no shutdown
(Note: The main interface f0/0 doesn’t need an IP address but it must be turned on)
Router(config)#interface f0/0.0
Router(config-subif)#encapsulation dot1q 15
Router(config-subif)#ip address 192.168.15.1 255.255.255.0
Router(config-subif)#interface f0/0.1
Router(config-subif)#encapsulation dot11 20
Router(config-subif)#ip address 192.168.20.1 255.255.255.0
(Note: In the “encapsulation dot1q 15″ command, 15 is the VLAN ID this interface operates in)
Configure VLAN
Switch(config)#vlan 15
Switch(config-vlan)#name SALES
Switch(config-vlan)#vlan 20
Switch(config-vlan)#name TECH
Set ports to access mode & assign ports to VLAN
Switch(config)#interface range fa0/1
Switch(config-if)#no shutdown
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 15
Switch(config-if)#interface range fa0/3
Switch(config-if)#switchport mode access
Switch(config-if)# switchport access vlan 20
Hope it helps.
Dont forget to rate helpful posts.
Sandeep Choudhary
Configure VLAN
Hope it helps.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Not enough information to say which is "right".  Either could work, much depends on capabilities of switches and router, what you're trying to do, and perhaps physical topology issues.
Everything else being equal, the router connected to both switches might allow for better performance.
I'm hoping for a bit of advise relating to the above topic.
I have been tasked to reconfigure 2 switches( 2x2960) and 1 router (ASR1001) that are currently connected with a ROAS config with only one trunk between the ASR and SW1 and another trunk between SW1 and SW2. Each SW has multiple vlans and the connected devices need to be able to communicate with each other in different vlans.
i would like to be able to connect a second trunk from SW2 to the router and maintain the trunk between SW1&2 and implement spanning tree to avoid any L2 loops.
The problem i am running into is the ip addressing for the sub-int of the second trunk. researching it on the cisco forums suggest that bridging would be a better option.
I have looked at creating a bridge group but the ASR will not accept the following code.
bridge irb
interface GigabitEthernet0/0.20
  bridge-group 20
interface GigabitEthernet0/1.20
  bridge-group 20
It says that the sub-int bridge-group cmd is unrecognised.
Is it the router or me.
Any suggestions welcome.
