Router Re-configuration Help
mindmelt1
Need some advise / help.  A client moved locations and running a Cisco 831 router, which is hooked up to a new internet connection. I have not much experience with Cisco Routing commands and the  command panel. I attempted to configure the router with new ip and DNS, but still unable to get an internet connection.  Wa
I have attached two configuration files - assume the changes were saved but also not sure if need to reset or reboot the Router.
Appreciate any help.
thank you!
-jon
Joseph W. Doherty
Could you post straight text versions?
I bet you fixed the issue by this time, but it appears that the default route statement (ip route 0.0.0.0 0.0.0.0 <  >) is missing in new config.
hth
MS
