12-03-2003 04:08 PM - edited 03-02-2019 12:07 PM
When I use eigrp to route ipx why do I have to explicitly turn off the networks in ipx router rip and explicitly configure those same networks in eigrp. Since ipx routing enables ipx rip and sap services and redistributes automatically into eigrp, that should be the end of it. Why do I need ipx router rip configured on all my routers?
12-03-2003 07:30 PM
It is just the way it has been implemented. If you don't do it, RIP updates will also propagate across the WAN links and EIGRP updated will be sent onto the LAN interfaces which is not what you want.
12-03-2003 09:27 PM
With version 12 of the IOS couldn't I just configure no ipx router rip and be done with it?
12-04-2003 01:43 PM
By default, when IPX routing is enabled, RIP is enabled as well. When you add IPX EIGRP, both RIP/EIGRP run at the same time and automatically redistributes. You have to selectively add the IPX networks under EIGRP. This way, you can control who is part of the IPX EIGRP domain.
