12-19-2018 12:38 PM - edited 03-03-2019 08:58 AM
I have VMware Player installed on Ubuntu 18.0 OS. '
I installed VIRL and started the 2 node topology that comes OOB with Maestro.
Only the management IP comes up as Reachable.
None of the Nodes do (they all have 172 addresses as Shared Network).
After the initial installation I did have to set the network cards to Bridged (they did not automatically do this).
Anyone ever have a similar issue running on Ubuntu . ?
I had this running on Windows - but everytime I rebooted Windows VIRL would never come back up.
Bob
12-19-2018 12:58 PM
I belive this is too nested, what is the reason for 2 nested ?
12-19-2018 02:44 PM
12-19-2018 02:27 PM
The Ubuntu 18 box is a physical box with VMware Player running on it.
It is not nested.
Thank you !
Bob
12-20-2018 06:39 AM
Here are some additional Logs:
Maestro Log:
(INFO) [Dec/20/2018 14:10:13] Node "iosvl2-2" state changed from ABSENT to BUILDING
(INFO) [Dec/20/2018 14:10:14] Node "~mgmt-lxc" state changed from ABSENT to ACTIVE
(INFO) [Dec/20/2018 14:10:15] Reachability status of node "~mgmt-lxc" changed from UNREACHABLE to REACHABLE
(ERROR) [Dec/20/2018 14:10:33] Node "iosvl2-1" state changed from BUILDING to ERROR with message: Could not contact redis at localhost:6379.
Cause: Error 111 connecting to localhost:6379. ECONNREFUSED.: File "/usr/lib/python2.7/dist-packages/nova/compute/manager.py", line 1926, in _do_build_and_run_instance
(ERROR) [Dec/20/2018 14:10:33] Node "iosvl2-2" state changed from BUILDING to ERROR with message: Could not contact redis at localhost:6379.
(WARNING) [Dec/20/2018 14:13:54] Skipped configuration extraction for node "iosvl2-1" in state ERROR
(WARNING) [Dec/20/2018 14:13:54] Skipped configuration extraction for node "iosvl2-2" in state ERROR
VMware Log:
2018-12-20T09:19:47.267-05:00| vmx| I125: Log for VMware Player pid=27356 version=15.0.2 build=build-10952284 option=Release
2018-12-20T09:19:47.267-05:00| vmx| I125: The process is 64-bit.
2018-12-20T09:19:47.267-05:00| vmx| I125: Host codepage=UTF-8 encoding=UTF-8
2018-12-20T09:19:47.267-05:00| vmx| I125: Host is Linux 4.15.0-42-generic Ubuntu 18.04.1 LTS
2018-12-20T09:19:47.258-05:00| vmx| I125: VTHREAD 140635307898816 "vmx" tid 27356
2018-12-20T09:19:47.258-05:00| vmx| I125: DictionaryLoad: Cannot open file "/etc/vmware/vsphereFeatures/vsphereFeatures.cfg": No such file or directory.
2018-12-20T09:19:47.258-05:00| vmx| I125: [msg.dictionary.load.openFailed] Cannot open file "/etc/vmware/vsphereFeatures/vsphereFeatures.cfg": No such file or directory.
2018-12-20T09:19:47.258-05:00| vmx| I125: FeatureStateLib: Error while loading feature config file: /etc/vmware/vsphereFeatures/vsphereFeatures.cfg, using default feature state values.
2018-12-20T09:19:47.258-05:00| vmx| I125: LOCALE en_US.UTF-8 -> NULL
2018-12-20T09:19:47.258-05:00| vmx| I125: Msg_SetLocaleEx: HostLocale=UTF-8 UserLocale=NULL
2018-12-20T09:19:47.259-05:00| vmx| I125: DictionaryLoad: Cannot open file "/usr/lib/vmware/settings": No such file or directory.
2018-12-20T09:19:47.259-05:00| vmx| I125: Msg_Reset:
2018-12-20T09:19:47.259-05:00| vmx| I125: [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": No such file or directory.
2018-12-20T09:19:47.259-05:00| vmx| I125: ----------------------------------------
2018-12-20T09:19:47.259-05:00| vmx| I125: ConfigDB: Failed to load /usr/lib/vmware/settings
2018-12-20T09:19:47.259-05:00| vmx| I125: DictionaryLoad: Cannot open file "/home/drc/.vmware/config": No such file or directory.
2018-12-20T09:19:47.259-05:00| vmx| I125: [msg.dictionary.load.openFailed] Cannot open file "/home/drc/.vmware/config": No such file or directory.
2018-12-20T09:19:47.259-05:00| vmx| I125: ConfigDB: Failed to load ~/.vmware/config
2018-12-20T09:19:47.259-05:00| vmx| I125: OBJLIB-LIB: Objlib initialized.
2018-12-20T09:19:47.259-05:00| vmx| I125: PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values.
2018-12-20T09:19:47.259-05:00| vmx| I125: PREF Optional preferences file not found at /home/drc/.vmware/config. Using default values.
2018-12-20T09:19:47.259-05:00| vmx| I125: Fail to realpath: /usr/lib/vmware/lib/libcrypto.so.1.0.2-x86-64/libcrypto.so.1.0.2, errno=2
2018-12-20T09:19:47.259-05:00| vmx| I125: Denied library: /usr/lib/vmware/lib/libcrypto.so.1.0.2-x86-64/libcrypto.so.1.0.2
2018-12-20T09:19:47.261-05:00| vmx| I125: lib/ssl: OpenSSL using FIPS_drbg for RAND
2018-12-20T09:19:47.261-05:00| vmx| I125: lib/ssl: protocol list tls1.2
2018-12-20T09:19:47.261-05:00| vmx| I125: lib/ssl: protocol list tls1.2 (openssl flags 0x17000000)
2018-12-20T09:19:47.261-05:00| vmx| I125: lib/ssl: cipher list !aNULL:kECDH+AESGCM:ECDH+AESGCM:RSA+AESGCM:kECDH+AES:ECDH+AES:RSA+AES
2018-12-20T09:19:47.311-05:00| vmx| I125: Hostname=drcvirl
2018-12-20T09:19:47.311-05:00| vmx| I125: IP=127.0.0.1 (lo)
2018-12-20T09:19:47.311-05:00| vmx| I125: IP=10.150.160.140 (enp3s0)
2018-12-20T09:19:47.311-05:00| vmx| I125: IP=192.168.122.1 (virbr0)
2018-12-20T09:19:47.311-05:00| vmx| I125: IP=192.168.87.1 (vmnet1)
2018-12-20T09:19:47.311-05:00| vmx| I125: IP=172.16.18.1 (vmnet8)
2018-12-20T09:19:47.311-05:00| vmx| I125: System uptime 66723649999 us
2018-12-20T09:19:47.311-05:00| vmx| I125: Command line: "/usr/lib/vmware/bin/vmware-vmx" "-ssnapshot.numRollingTiers=0" "-s" "vmx.stdio.keep=TRUE" "-#" "product=4;name=VMware Player;version=15.0.2;buildnumber=10952284;licensename=VMware Player;licenseversion=15.0;" "-@" "duplex=3;msgs=ui" "/home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc.vmx"
2018-12-20T09:19:47.311-05:00| vmx| I125: Msg_SetLocaleEx: HostLocale=UTF-8 UserLocale=NULL
2018-12-20T09:19:47.311-05:00| vmx| I125: Duplex socket: 3
2018-12-20T09:19:47.330-05:00| vmx| I125: WQPoolAllocPoll : pollIx = 1, signalHandle = 9
2018-12-20T09:19:47.330-05:00| vmx| I125: WQPoolAllocPoll : pollIx = 2, signalHandle = 11
2018-12-20T09:19:47.330-05:00| vmx| I125: VigorTransport listening on fd 12
2018-12-20T09:19:47.330-05:00| vmx| I125: Vigor_Init 1
2018-12-20T09:19:47.330-05:00| vmx| I125: Connecting 'ui' to fd '3' with user '(null)'
2018-12-20T09:19:47.330-05:00| vmx| I125: VmdbAddConnection: cnxPath=/db/connection/#1/, cnxIx=1
2018-12-20T09:19:47.346-05:00| vmx| I125: /home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc.vmx: Setup symlink /var/run/vmware/3d33487442a89765691b92cef38bebfe -> /var/run/vmware/1000/66723649999_27356
2018-12-20T09:19:47.346-05:00| vmx| I125: Vix: [mainDispatch.c:482]: VMAutomation: Initializing VMAutomation.
2018-12-20T09:19:47.346-05:00| vmx| I125: Vix: [mainDispatch.c:745]: VMAutomationOpenListenerSocket() listening
2018-12-20T09:19:47.348-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1870, success=1 additionalError=0
2018-12-20T09:19:47.348-05:00| vmx| I125: Transitioned vmx/execState/val to poweredOff
2018-12-20T09:19:47.349-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2018-12-20T09:19:47.349-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1877, success=1 additionalError=0
2018-12-20T09:19:47.349-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=3, newAppState=1881, success=1 additionalError=0
2018-12-20T09:19:47.349-05:00| vmx| I125: FeatureCompat: No EVC masks.
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID vendor: GenuineIntel
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID family: 0x6 model: 0x2a stepping: 0x7
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID codename: Sandy Bridge
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000000, 0: 0x0000000d 0x756e6547 0x6c65746e 0x49656e69
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000001, 0: 0x000206a7 0x05100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000002, 0: 0x76035a01 0x00f0b2ff 0x00000000 0x00ca0000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000004, 0: 0x1c004121 0x01c0003f 0x0000003f 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000004, 1: 0x1c004122 0x01c0003f 0x0000003f 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000004, 2: 0x1c004143 0x01c0003f 0x000001ff 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000004, 3: 0x1c03c163 0x03c0003f 0x00001fff 0x00000006
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000004, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000005, 0: 0x00000040 0x00000040 0x00000003 0x00001120
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000006, 0: 0x00000077 0x00000002 0x00000009 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000007, 0: 0x00000000 0x00000000 0x00000000 0x9c000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000a, 0: 0x07300403 0x00000000 0x00000000 0x00000603
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000005
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000005
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000005
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000d, 0: 0x00000007 0x00000340 0x00000340 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000d, 1: 0x00000001 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 0000000d, 2: 0x00000100 0x00000240 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000000, 0: 0x80000008 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000001, 0: 0x00000000 0x00000000 0x00000001 0x28100800
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000002, 0: 0x20202020 0x49202020 0x6c65746e 0x20295228
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000003, 0: 0x65726f43 0x294d5428 0x2d376920 0x30303632
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000004, 0: 0x5043204b 0x20402055 0x30342e33 0x007a4847
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000005, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000006, 0: 0x00000000 0x00000000 0x01006040 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000007, 0: 0x00000000 0x00000000 0x00000000 0x00000100
2018-12-20T09:19:47.367-05:00| vmx| I125: hostCPUID level 80000008, 0: 0x00003024 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID differences from hostCPUID.
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[1] level 00000001, 0: 0x000206a7 0x07100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[1] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000007
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[1] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000007
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[1] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000007
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[2] level 00000001, 0: 0x000206a7 0x04100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[2] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000004
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[2] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000004
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[2] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000004
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[3] level 00000001, 0: 0x000206a7 0x06100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[3] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000001
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[3] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000001
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[3] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000001
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[4] level 00000001, 0: 0x000206a7 0x02100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[4] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000003
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[4] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000003
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[4] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000003
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[5] level 00000001, 0: 0x000206a7 0x03100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[5] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[5] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[5] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[6] level 00000001, 0: 0x000206a7 0x01100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[6] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000002
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[6] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000002
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[6] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000002
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[7] level 00000001, 0: 0x000206a7 0x00100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[7] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000006
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[7] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000006
2018-12-20T09:19:47.367-05:00| vmx| I125: CPUID[7] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000006
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x3a = 0x5
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x480 = 0xda040000000010
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x481 = 0x7f00000016
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x482 = 0xfff9fffe0401e172
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x483 = 0x7fffff00036dff
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x484 = 0xffff000011ff
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x485 = 0x100401e5
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x486 = 0x80000021
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x487 = 0xffffffff
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x488 = 0x2000
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x489 = 0x627ff
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x48a = 0x2a
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x48b = 0xff00000000
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x48c = 0xf0106114141
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x48d = 0x7f00000016
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x48e = 0xfff9fffe04006172
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x48f = 0x7fffff00036dfb
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x490 = 0xffff000011fb
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0x491 = 0
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0xc0010114 = 0
2018-12-20T09:19:47.367-05:00| vmx| I125: Common: MSR 0xce = 0x100070012200
2018-12-20T09:19:47.367-05:00| vmx| I125: UTIL: Change file descriptor limit from soft 4096,hard 4096 to soft 16384,hard 16384.
2018-12-20T09:19:47.367-05:00| vmx| I125: VMMon_GetkHzEstimate: Calculated 3410014 kHz
2018-12-20T09:19:47.367-05:00| vmx| I125: TSC kHz estimates: vmmon 3410014, cpuinfo 3795232, cpufreq 3800000. Using 3410014 kHz
2018-12-20T09:19:47.367-05:00| vmx| I125: TSC first measured delta 56
2018-12-20T09:19:47.367-05:00| vmx| I125: TSC min delta 35
2018-12-20T09:19:47.367-05:00| vmx| I125: PTSC: RefClockToPTSC 0 @ 1000000Hz -> 0 @ 3410014000Hz
2018-12-20T09:19:47.367-05:00| vmx| I125: PTSC: RefClockToPTSC ((x * 3575658840) >> 20) + -4762874460198
2018-12-20T09:19:47.367-05:00| vmx| I125: PTSC: tscOffset -227599021559868
2018-12-20T09:19:47.367-05:00| vmx| I125: PTSC: using TSC
2018-12-20T09:19:47.367-05:00| vmx| I125: PTSC: hardware TSCs are synchronized.
2018-12-20T09:19:47.367-05:00| vmx| I125: PTSC: current PTSC=79303
2018-12-20T09:19:47.367-05:00| vmx| I125: WQPoolAllocPoll : pollIx = 3, signalHandle = 17
2018-12-20T09:19:47.368-05:00| vmx| I125: MKSXlib: Initialized thread-safe Xlib
2018-12-20T09:19:47.368-05:00| vmx| I125: [0x55EACCF7C000-0x55EACDC961D0): /usr/lib/vmware/bin/vmware-vmx
2018-12-20T09:19:47.391-05:00| vmx| I125: ConfigCheck: No rules file found. Checks are disabled.
2018-12-20T09:19:47.391-05:00| vmx| I125: changing directory to /home/drc/vmware/virl.1.5.145.pc/.
2018-12-20T09:19:47.391-05:00| vmx| I125: Config file: /home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc.vmx
2018-12-20T09:19:47.391-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2018-12-20T09:19:47.391-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1878, success=1 additionalError=0
2018-12-20T09:19:47.405-05:00| vmx| I125: VMXVmdbCbVmVmxExecState: Exec state change requested to state poweredOn without reset, soft, softOptionTimeout: 0.
2018-12-20T09:19:47.405-05:00| vmx| I125: Tools: sending 'OS_PowerOn' (state = 3) state change request
2018-12-20T09:19:47.405-05:00| vmx| I125: Tools: Delaying state change request to state 3.
2018-12-20T09:19:47.405-05:00| vmx| W115: PowerOn
2018-12-20T09:19:47.405-05:00| vmx| I125: VMX_PowerOn: VMX build 10952284, UI build 10952284
2018-12-20T09:19:47.451-05:00| vmx| I125: libnuma.so found and in use.
2018-12-20T09:19:47.452-05:00| vmx| I125: NUMA topology found.
2018-12-20T09:19:47.452-05:00| vmx| I125: NUMA node 0: 31851MB, cpus 0x000000ff 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:47.458-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1871, success=1 additionalError=0
2018-12-20T09:19:47.458-05:00| vmx| I125: HOST sysname Linux, nodename drcvirl, release 4.15.0-42-generic, version #45-Ubuntu SMP Thu Nov 15 19:32:57 UTC 2018, machine x86_64
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- GLOBAL SETTINGS /usr/lib/vmware/settings
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- NON PERSISTENT (null)
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- USER PREFERENCES /home/drc/.vmware/preferences
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pref.lastUpdateCheckSec = "1545314228"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pref.keyboardAndMouse.vmHotKey.enabled = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pref.keyboardAndMouse.vmHotKey.count = "0"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pref.vmplayer.firstRunDismissedVersion = "15.0.2"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- USER DEFAULTS /home/drc/.vmware/config
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- HOST DEFAULTS /etc/vmware/config
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT VMCI_CONFED = "yes"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT NETWORKING = "yes"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT initscriptdir = "/etc/init.d"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT VMBLOCK_CONFED = "yes"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT authd.fullpath = "/usr/sbin/vmware-authd"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT gksu.rootMethod = "su"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT VSOCK_CONFED = "yes"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT libdir = "/usr/lib/vmware"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT bindir = "/usr/bin"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT installerDefaults.componentDownloadEnabled = "yes"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT hostUUID = "f82a920a-045e-11e9-a377-60a44c579497"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled.epoch = "2707291802"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT vix.config.version = "1"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT player.product.version = "15.0.2"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled.epoch = "4653577562"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled = "no"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT installerDefaults.transferVersion = "1"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled = "no"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT product.buildNumber = "10952284"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- SITE DEFAULTS /usr/lib/vmware/config
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.help = "introduction.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.configurationEditor = "config_editor_newvm.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.ideConfig = "devices_virtualdrive.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.floppyConfig = "devices_floppy.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.mouseConfig = "devices_mouse.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.netConfig = "devices_netadapter.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.parallelConfig = "devices_parallel.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.serialConfig = "devices_serial.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.soundConfig = "devices_sound.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.memConfig = "configvm_memory.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.miscConfig = "configvm.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.usbConfig = "devices_usb.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.displayConfig = "configvm_display-problems.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tag.tools = "vmtools.htm"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- NONPERSISTENT
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT snapshot.numRollingTiers = "0"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT vmx.stdio.keep = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT gui.available = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- COMMAND LINE
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- RECORDING
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT --- CONFIGURATION /home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc.vmx
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT displayname = "virl.1.5.145.pc"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT guestos = "ubuntu-64"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT bios.bootorder = "cdrom"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT virtualhw.version = "10"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT config.version = "8"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT numvcpus = "4"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT cpuid.coresPerSocket = "1"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT memsize = "16384"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge0.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge4.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge4.virtualDev = "pcieRootPort"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge4.functions = "8"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge5.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge5.virtualDev = "pcieRootPort"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge5.functions = "8"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge6.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge6.virtualDev = "pcieRootPort"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge6.functions = "8"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge7.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge7.virtualDev = "pcieRootPort"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT pciBridge7.functions = "8"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT vmci0.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT floppy0.present = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ide1:0.clientDevice = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ide1:0.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ide1:0.deviceType = "cdrom-raw"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ide1:0.autodetect = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ide1:0.startConnected = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ide1:0.exclusive = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ide1:0.allowguestconnectioncontrol = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT svga.autodetect = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT mks.enable3d = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT mks.use3dRenderer = "automatic"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT svga.vramSize = "4194304"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0:0.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0:0.deviceType = "disk"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0:0.fileName = "virl.1.5.145.pc-disk1.vmdk"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0:0.allowguestconnectioncontrol = "false"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0:0.writeThrough = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0:0.mode = "persistent"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0.virtualDev = "lsilogic"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT scsi0.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT vmci0.pciSlotNumber = "32"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT vmci0.unrestricted = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.virtualDev = "e1000"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.connectionType = "bridged"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.startConnected = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.addressType = "generated"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.pciSlotNumber = "33"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.wakeonpcktrcv = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet0.allowguestconnectioncontrol = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet1.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet1.virtualDev = "e1000"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet1.addressType = "generated"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet1.pciSlotNumber = "34"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet1.wakeonpcktrcv = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet1.allowguestconnectioncontrol = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet2.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet2.virtualDev = "e1000"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet2.addressType = "generated"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet2.pciSlotNumber = "35"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet2.wakeonpcktrcv = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet2.allowguestconnectioncontrol = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet3.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet3.virtualDev = "e1000"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet3.addressType = "generated"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet3.pciSlotNumber = "37"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet3.wakeonpcktrcv = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet3.allowguestconnectioncontrol = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet4.present = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet4.virtualDev = "e1000"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet4.addressType = "generated"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet4.pciSlotNumber = "38"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet4.wakeonpcktrcv = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT ethernet4.allowguestconnectioncontrol = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT vcpu.hotadd = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT vcpu.hotremove = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT firmware = "bios"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT tools.syncTime = "FALSE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT toolscripts.afterpoweron = "TRUE"
2018-12-20T09:19:47.458-05:00| vmx| I125: DICT toolscripts.afterresume = "TRUE"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT toolscripts.beforepoweroff = "TRUE"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT toolscripts.beforesuspend = "TRUE"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tools.upgrade.policy = "upgradeAtPowerCycle"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT powerType.powerOff = "soft"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT powerType.reset = "soft"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT powerType.suspend = "soft"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT vhv.enable = "TRUE"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT chipset.onlineStandby = "FALSE"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT nvram = "virl.1.5.145.pc-file1.nvram"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT virtualhw.productcompatibility = "hosted"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT extendedConfigFile = "virl.1.5.145.pc.vmxf"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT numa.autosize.cookie = "40001"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT numa.autosize.vcpu.maxPerVirtualNode = "4"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT uuid.bios = "56 4d cc 85 6f f0 f7 a1-5d 92 fa 13 96 63 71 ef"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT uuid.location = "56 4d cc 85 6f f0 f7 a1-5d 92 fa 13 96 63 71 ef"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT scsi0:0.redo = ""
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT pciBridge0.pciSlotNumber = "17"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT pciBridge4.pciSlotNumber = "21"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT pciBridge5.pciSlotNumber = "22"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT pciBridge6.pciSlotNumber = "23"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT pciBridge7.pciSlotNumber = "24"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT scsi0.pciSlotNumber = "16"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT vmotion.checkpointFBSize = "4194304"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet0.generatedAddress = "00:0c:29:63:71:ef"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet0.generatedAddressOffset = "0"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet1.generatedAddress = "00:0c:29:63:71:f9"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet1.generatedAddressOffset = "10"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet2.generatedAddress = "00:0c:29:63:71:03"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet2.generatedAddressOffset = "20"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet3.generatedAddress = "00:0c:29:63:71:0d"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet3.generatedAddressOffset = "30"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet4.generatedAddress = "00:0c:29:63:71:17"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT ethernet4.generatedAddressOffset = "40"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT vmci0.id = "-1771867665"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT monitor.phys_bits_used = "40"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT cleanShutdown = "TRUE"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT softPowerOff = "TRUE"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT --- USER DEFAULTS ~/.vmware/config
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT --- HOST DEFAULTS /etc/vmware/config
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT VMCI_CONFED = "yes"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT NETWORKING = "yes"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT initscriptdir = "/etc/init.d"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT VMBLOCK_CONFED = "yes"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT authd.fullpath = "/usr/sbin/vmware-authd"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT gksu.rootMethod = "su"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT VSOCK_CONFED = "yes"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT libdir = "/usr/lib/vmware"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT bindir = "/usr/bin"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT installerDefaults.componentDownloadEnabled = "yes"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT hostUUID = "f82a920a-045e-11e9-a377-60a44c579497"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled.epoch = "2707291802"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT vix.config.version = "1"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT player.product.version = "15.0.2"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled.epoch = "4653577562"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT installerDefaults.dataCollectionEnabled = "no"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT installerDefaults.transferVersion = "1"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT installerDefaults.autoSoftwareUpdateEnabled = "no"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT product.buildNumber = "10952284"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT --- SITE DEFAULTS /usr/lib/vmware/config
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.help = "introduction.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.configurationEditor = "config_editor_newvm.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.ideConfig = "devices_virtualdrive.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.floppyConfig = "devices_floppy.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.mouseConfig = "devices_mouse.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.netConfig = "devices_netadapter.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.parallelConfig = "devices_parallel.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.serialConfig = "devices_serial.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.soundConfig = "devices_sound.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.memConfig = "configvm_memory.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.miscConfig = "configvm.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.usbConfig = "devices_usb.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.displayConfig = "configvm_display-problems.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT tag.tools = "vmtools.htm"
2018-12-20T09:19:47.459-05:00| vmx| I125: DICT --- GLOBAL SETTINGS /usr/lib/vmware/settings
2018-12-20T09:19:47.459-05:00| vmx| I125: ToolsISO: open of /usr/lib/vmware/isoimages/isoimages_manifest.txt.sig failed: Could not find the file
2018-12-20T09:19:47.459-05:00| vmx| I125: ToolsISO: Unable to read signature file '/usr/lib/vmware/isoimages/isoimages_manifest.txt.sig', ignoring.
2018-12-20T09:19:47.459-05:00| vmx| I125: ToolsISO: Updated cached value for imageName to 'linux.iso'.
2018-12-20T09:19:47.459-05:00| vmx| I125: ToolsISO: Selected Tools ISO 'linux.iso' for 'ubuntu-64' guest.
2018-12-20T09:19:47.459-05:00| vmx| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2018-12-20T09:19:47.487-05:00| vmx| I125: OvhdMem_PowerOn: initial admission: paged 77088 nonpaged 11264 anonymous 35368
2018-12-20T09:19:47.487-05:00| vmx| I125: VMMEM: Initial Reservation: 483MB (MainMem=16384MB)
2018-12-20T09:19:47.487-05:00| vmx| I125: MemSched_PowerOn: balloon minGuestSize 13107 (80% of min required size 16384)
2018-12-20T09:19:47.487-05:00| vmx| I125: MemSched: reserved mem (in MB) min 128 max 27888 recommended 27888
2018-12-20T09:19:47.487-05:00| vmx| I125: MemSched: pg 77088 np 11264 anon 35368 mem 4194304
2018-12-20T09:19:47.487-05:00| vmx| I125: MemSched: numvm 1 locked pages: num 0 max 7131136
2018-12-20T09:19:47.487-05:00| vmx| I125: MemSched: locked Page Limit: host 8086366 config 7139328 dynam -1
2018-12-20T09:19:47.487-05:00| vmx| I125: MemSched: minmempct 50 minalloc 0 admitted 1
2018-12-20T09:19:47.488-05:00| vmx| I125: Host: Disabling thread priority boosting to work around Linux SMP bug.
2018-12-20T09:19:47.488-05:00| vmx| I125: LICENSE: Running unlicensed VMX (VMware Player)
2018-12-20T09:19:47.488-05:00| vthread-27375| I125: VTHREAD 140635213977344 "vthread-27375" tid 27375
2018-12-20T09:19:47.488-05:00| vmx| I125: PolicyVMXFindPolicyKey: policy file does not exist.
2018-12-20T09:19:47.488-05:00| vmx| W115: VProbes facility is disabled.
2018-12-20T09:19:47.489-05:00| vmx| I125: ToolsISO: Refreshing imageName for 'ubuntu-64' (refreshCount=1, lastCount=1).
2018-12-20T09:19:47.489-05:00| vmx| I125: ToolsISO: open of /usr/lib/vmware/isoimages/isoimages_manifest.txt.sig failed: Could not find the file
2018-12-20T09:19:47.489-05:00| vmx| I125: ToolsISO: Unable to read signature file '/usr/lib/vmware/isoimages/isoimages_manifest.txt.sig', ignoring.
2018-12-20T09:19:47.489-05:00| vmx| I125: ToolsISO: Updated cached value for imageName to 'linux.iso'.
2018-12-20T09:19:47.489-05:00| vmx| I125: ToolsISO: Selected Tools ISO 'linux.iso' for 'ubuntu-64' guest.
2018-12-20T09:19:47.489-05:00| vmx| I125: Host VT-x Capabilities:
2018-12-20T09:19:47.489-05:00| vmx| I125: Basic VMX Information (0x00da040000000010)
2018-12-20T09:19:47.489-05:00| vmx| I125: VMCS revision ID 16
2018-12-20T09:19:47.489-05:00| vmx| I125: VMCS region length 1024
2018-12-20T09:19:47.489-05:00| vmx| I125: VMX physical-address width natural
2018-12-20T09:19:47.489-05:00| vmx| I125: SMM dual-monitor mode yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Advanced INS/OUTS info yes
2018-12-20T09:19:47.489-05:00| vmx| I125: True VMX MSRs yes
2018-12-20T09:19:47.489-05:00| vmx| I125: VMCS memory type WB
2018-12-20T09:19:47.489-05:00| vmx| I125: True Pin-Based VM-Execution Controls (0x0000007f00000016)
2018-12-20T09:19:47.489-05:00| vmx| I125: External-interrupt exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: NMI exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Virtual NMIs {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Activate VMX-preemption timer {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Process posted interrupts { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: True Primary Processor-Based VM-Execution Controls (0xfff9fffe04006172)
2018-12-20T09:19:47.489-05:00| vmx| I125: Interrupt-window exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Use TSC offsetting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: HLT exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: INVLPG exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: MWAIT exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: RDPMC exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: RDTSC exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: CR3-load exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: CR3-store exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: CR8-load exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: CR8-store exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Use TPR shadow {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: NMI-window exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: MOV-DR exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Unconditional I/O exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Use I/O bitmaps {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Monitor trap flag {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Use MSR bitmaps {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: MONITOR exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: PAUSE exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Activate secondary controls {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Secondary Processor-Based VM-Execution Controls (0x000000ff00000000)
2018-12-20T09:19:47.489-05:00| vmx| I125: Virtualize APIC accesses {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Enable EPT {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Descriptor-table exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Enable RDTSCP {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Virtualize x2APIC mode {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Enable VPID {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: WBINVD exiting {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Unrestricted guest {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: APIC-register virtualization { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Virtual-interrupt delivery { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: PAUSE-loop exiting { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: RDRAND exiting { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Enable INVPCID { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Enable VM Functions { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Use VMCS shadowing { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: ENCLS exiting { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: RDSEED exiting { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Enable PML { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: EPT-violation #VE { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Enable XSAVES/XRSTORS { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Mode-based execute control for EPT { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: Use TSC scaling { 0 }
2018-12-20T09:19:47.489-05:00| vmx| I125: True VM-Exit Controls (0x007fffff00036dfb)
2018-12-20T09:19:47.489-05:00| vmx| I125: Save debug controls {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Host address-space size {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Load IA32_PERF_GLOBAL_CTRL {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Acknowledge interrupt on exit {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Save IA32_PAT {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Load IA32_PAT {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Save IA32_EFER {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Load IA32_EFER {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Save VMX-preemption timer {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: True VM-Entry Controls (0x0000ffff000011fb)
2018-12-20T09:19:47.489-05:00| vmx| I125: Load debug controls {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: IA-32e mode guest {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Entry to SMM {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: Deactivate dual-monitor mode {0,1}
2018-12-20T09:19:47.489-05:00| vmx| I125: VPID and EPT Capabilities (0x00000f0106114141)
2018-12-20T09:19:47.489-05:00| vmx| I125: R=0/W=0/X=1 yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Page-walk length 3 yes
2018-12-20T09:19:47.489-05:00| vmx| I125: EPT memory type WB yes
2018-12-20T09:19:47.489-05:00| vmx| I125: 2MB super-page yes
2018-12-20T09:19:47.489-05:00| vmx| I125: 1GB super-page no
2018-12-20T09:19:47.489-05:00| vmx| I125: INVEPT support yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Access & Dirty Bits no
2018-12-20T09:19:47.489-05:00| vmx| I125: Advanced VM exit information for EPT violations no
2018-12-20T09:19:47.489-05:00| vmx| I125: Type 1 INVEPT yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Type 2 INVEPT yes
2018-12-20T09:19:47.489-05:00| vmx| I125: INVVPID support yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Type 0 INVVPID yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Type 1 INVVPID yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Type 2 INVVPID yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Type 3 INVVPID yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Miscellaneous VMX Data (0x00000000100401e5)
2018-12-20T09:19:47.489-05:00| vmx| I125: TSC to preemption timer ratio 5
2018-12-20T09:19:47.489-05:00| vmx| I125: VM-Exit saves EFER.LMA yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Activity State HLT yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Activity State shutdown yes
2018-12-20T09:19:47.489-05:00| vmx| I125: Activity State wait-for-SIPI yes
2018-12-20T09:19:47.490-05:00| vmx| I125: CR3 targets supported 4
2018-12-20T09:19:47.490-05:00| vmx| I125: Maximum MSR list size 512
2018-12-20T09:19:47.490-05:00| vmx| I125: Allow all VMWRITEs no
2018-12-20T09:19:47.490-05:00| vmx| I125: Allow zero instruction length no
2018-12-20T09:19:47.490-05:00| vmx| I125: MSEG revision ID 0
2018-12-20T09:19:47.490-05:00| vmx| I125: Processor trace in VMX no
2018-12-20T09:19:47.490-05:00| vmx| I125: VMX-Fixed Bits in CR0 (0x0000000080000021/0x00000000ffffffff)
2018-12-20T09:19:47.490-05:00| vmx| I125: Fixed to 0 0xffffffff00000000
2018-12-20T09:19:47.490-05:00| vmx| I125: Fixed to 1 0x0000000080000021
2018-12-20T09:19:47.490-05:00| vmx| I125: Variable 0x000000007fffffde
2018-12-20T09:19:47.490-05:00| vmx| I125: VMX-Fixed Bits in CR4 (0x0000000000002000/0x00000000000627ff)
2018-12-20T09:19:47.490-05:00| vmx| I125: Fixed to 0 0xfffffffffff9d800
2018-12-20T09:19:47.490-05:00| vmx| I125: Fixed to 1 0x0000000000002000
2018-12-20T09:19:47.490-05:00| vmx| I125: Variable 0x00000000000607ff
2018-12-20T09:19:47.490-05:00| vmx| I125: VMCS Enumeration (0x000000000000002a)
2018-12-20T09:19:47.490-05:00| vmx| I125: Highest index 0x15
2018-12-20T09:19:47.490-05:00| vmx| I125: VM Functions (0x0000000000000000)
2018-12-20T09:19:47.490-05:00| vmx| I125: Monitor_PowerOn: hostedVSMPMaxSkew is 1500 us (5115021 cycles)
2018-12-20T09:19:47.490-05:00| vmx| I125: Loaded crosspage: .crosspage. Size = 4096 bytes.
2018-12-20T09:19:47.490-05:00| vmx| I125: vmm64-modules: [vmm.vmm64, vprobe-none.vmm64, hv-vt.vmm64, gphys-ept.vmm64, callstack-none.vmm64, vmce-none.vmm64, viommu-none.vmm64, gi-none.vmm64, !e1000Shared=0x0, !theIOSpace=0x4980, !ttGPPerVcpu=0x9d40, {UseUnwind}=0x0, numVCPUsAsAddr=0x4, {SharedAreaReservations}=0x9d80, {rodataSize}=0x1e425, {textAddr}=0xfffffffffc000000, {textSize}=0x7d77f, <MonSrcFile>]
2018-12-20T09:19:47.490-05:00| vmx| I125: vmm64-vcpus: 4
2018-12-20T09:19:47.499-05:00| vmx| I125: KHZEstimate 3410014
2018-12-20T09:19:47.499-05:00| vmx| I125: MHZEstimate 3410
2018-12-20T09:19:47.499-05:00| vmx| I125: NumVCPUs 4
2018-12-20T09:19:47.499-05:00| vmx| I125: MonTimer: host does not have high resolution timers.
2018-12-20T09:19:47.500-05:00| vmx| I125: UUID: Unable to open /sys/firmware/efi/systab: No such file or directory
2018-12-20T09:19:47.500-05:00| vmx| I125: UUID: Found _DMI_ signature.
2018-12-20T09:19:47.500-05:00| vmx| I125: UUID: SMBIOS UUID is reported as '40 4f ee 1d da d7 dd 11-b7 57 60 a4 4c 57 94 97'.
2018-12-20T09:19:47.500-05:00| vmx| I125: AIOGNRC: numThreads=18 ide=0, scsi=1, passthru=1
2018-12-20T09:19:47.500-05:00| vmx| I125: WORKER: Creating new group with numThreads=18 (18)
2018-12-20T09:19:47.500-05:00| WT| I125: VTHREAD 140635202311936 "WT" tid 27376
2018-12-20T09:19:47.541-05:00| vmx| I125: WORKER: Creating new group with numThreads=1 (19)
2018-12-20T09:19:47.541-05:00| vmx| I125: MainMem: CPT Host WZ=0 PF=16384 D=0
2018-12-20T09:19:47.541-05:00| vmx| I125: MainMem: CPT PLS=1 PLR=1 BS=1 BlkP=32 Mult=4 W=50
2018-12-20T09:19:47.541-05:00| vmem| I125: VTHREAD 140635160364800 "vmem" tid 27377
2018-12-20T09:19:49.070-05:00| vmx| I125: MainMem: Opened paging file, '/tmp/vmware-drc/564dcc85-6ff0-f7a1-5d92-fa13966371ef/vmem' (swap).
2018-12-20T09:19:49.070-05:00| vmx| I125: MStat: Creating Stat vm.uptime
2018-12-20T09:19:49.070-05:00| vmx| I125: MStat: Creating Stat vm.suspendTime
2018-12-20T09:19:49.070-05:00| vmx| I125: MStat: Creating Stat vm.powerOnTimeStamp
2018-12-20T09:19:49.070-05:00| vmx| I125: VMXAIOMGR: Using: simple=Generic
2018-12-20T09:19:49.071-05:00| vmx| I125: WORKER: Creating new group with numThreads=1 (20)
2018-12-20T09:19:49.072-05:00| vmx| I125: WORKER: Creating new group with numThreads=16 (36)
2018-12-20T09:19:49.072-05:00| vmx| I125: FeatureCompat: No VM masks.
2018-12-20T09:19:49.072-05:00| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation begins.
2018-12-20T09:19:49.072-05:00| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation completes.
2018-12-20T09:19:49.072-05:00| vmx| I125: TimeTracker host to guest rate conversion 5813121497 @ 3410014000Hz -> 0 @ 3410014000Hz
2018-12-20T09:19:49.072-05:00| vmx| I125: TimeTracker host to guest rate conversion ((x * 2147483648) >> 31) + -5813121497
2018-12-20T09:19:49.072-05:00| vmx| I125: Disabling TSC scaling since host does not support it.
2018-12-20T09:19:49.072-05:00| vmx| I125: TSC offsetting enabled.
2018-12-20T09:19:49.072-05:00| vmx| I125: timeTracker.globalProgressMaxAllowanceMS: 2000
2018-12-20T09:19:49.072-05:00| vmx| I125: timeTracker.globalProgressToAllowanceNS: 1000
2018-12-20T09:19:49.072-05:00| vmx| A100: ConfigDB: Setting scsi0:0.redo = ""
2018-12-20T09:19:49.072-05:00| vmx| I125: DISK: OPEN scsi0:0 '/home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc-disk1.vmdk' persistent R[]
2018-12-20T09:19:49.073-05:00| vmx| I125: DISKLIB-DSCPTR: Opened [0]: "virl.1.5.145.pc-disk1.vmdk" (0xa)
2018-12-20T09:19:49.073-05:00| vmx| I125: DISKLIB-LINK : Opened '/home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc-disk1.vmdk' (0xa): monolithicSparse, 143360000 sectors / 68.4 GB.
2018-12-20T09:19:49.073-05:00| vmx| I125: DISKLIB-LIB : Opened "/home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc-disk1.vmdk" (flags 0xa, type monolithicSparse).
2018-12-20T09:19:49.073-05:00| vmx| I125: DISKLIB-LIB_MISC : DiskLib_GetStorageBlockSizes: Failed to get storage block sizes, The virtual disk requires a feature not supported by this program.
2018-12-20T09:19:49.073-05:00| vmx| I125: DiskGetGeometry: Reading of disk partition table
2018-12-20T09:19:49.073-05:00| vthread-27378| I125: VTHREAD 140635160364800 "vthread-27378" tid 27378
2018-12-20T09:19:49.073-05:00| vmx| I125: DISK: Disk '/home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc-disk1.vmdk' has UUID '60 00 c2 9d 22 52 8f 34-b4 f3 43 e4 1e 91 30 72'
2018-12-20T09:19:49.073-05:00| vmx| I125: DISK: OPEN '/home/drc/vmware/virl.1.5.145.pc/virl.1.5.145.pc-disk1.vmdk' Geo (8923/255/63) BIOS Geo (8923/255/63)
2018-12-20T09:19:49.074-05:00| vmx| I125: DISK: Opening disks took 1 ms.
2018-12-20T09:19:49.074-05:00| vmx| I125: VUsb powered on, but no USB controllers.
2018-12-20T09:19:49.074-05:00| vmx| I125: MKS PowerOn
2018-12-20T09:19:49.075-05:00| mks| I125: VTHREAD 140635151972096 "mks" tid 27379
2018-12-20T09:19:49.075-05:00| mks| I125: MKS thread is alive
2018-12-20T09:19:49.075-05:00| mks| I125: MKS-RenderMain: PowerOn allowed MKSBasicOps
2018-12-20T09:19:49.075-05:00| mks| I125: MKS-RenderMain: Started MKSBasicOps
2018-12-20T09:19:49.075-05:00| mks| I125: MKS-RenderMain: Stopping MKSBasicOps
2018-12-20T09:19:49.075-05:00| mks| I125: MKS-RenderMain: Collecting RenderOps caps from MKSBasicOps
2018-12-20T09:19:49.075-05:00| mks| I125: MKS-RenderMain: Found Full Renderer: MKSBasicOps
2018-12-20T09:19:49.075-05:00| mks| I125: MKS-RenderMain: MinimalCaps: maxTextureSize=32768
2018-12-20T09:19:49.076-05:00| mks| I125: SOCKET creating new socket listening on /tmp/vmware-drc/mksctrl/mksctrl-0000027356-000-4db4e566
2018-12-20T09:19:49.076-05:00| mks| I125: SOCKET 1 (85) creating new listening socket on port -1
2018-12-20T09:19:49.076-05:00| mks| I125: KHBKL: Unable to parse keystring at: ''
2018-12-20T09:19:49.076-05:00| mks| I125: MKSRemoteMgr: Set default display name: virl.1.5.145.pc
2018-12-20T09:19:49.076-05:00| mks| I125: MKSRemoteMgr: Loading VNC Configuration from VM config file
2018-12-20T09:19:49.077-05:00| vmx| I125: VLANCE: send cluster threshold is 80, size = 2 recalcInterval is 20000 us
2018-12-20T09:19:49.077-05:00| vmx| I125: VMXNET: send cluster threshold is 80, size = 2 recalcInterval is 20000 ticks, dontClusterSize is 128
2018-12-20T09:19:49.077-05:00| vmx| I125: Chipset version: 0x13
2018-12-20T09:19:49.078-05:00| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "-1"
2018-12-20T09:19:49.078-05:00| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "-1"
2018-12-20T09:19:49.078-05:00| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "-1"
2018-12-20T09:19:49.078-05:00| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "-1"
2018-12-20T09:19:49.079-05:00| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "21"
2018-12-20T09:19:49.079-05:00| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "22"
2018-12-20T09:19:49.079-05:00| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "23"
2018-12-20T09:19:49.079-05:00| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "24"
2018-12-20T09:19:49.125-05:00| vmx| I125: SCSI DEVICE (ide1:0): Computed value of ide1:0.useBounceBuffers: default
2018-12-20T09:19:49.125-05:00| vmx| I125: DISKUTIL: ide1:0 : capacity=0 logical sector size=2048
2018-12-20T09:19:49.125-05:00| vmx| I125: DISKUTIL: ide1:0 : geometry=0/0/0
2018-12-20T09:19:49.125-05:00| vmx| I125: SCSI: scsi0: intr coalescing: on period=50msec cifTh=4 iopsTh=2000 hlt=0
2018-12-20T09:19:49.125-05:00| vmx| I125: SCSI0: UNTAGGED commands will be converted to ORDER tags.
2018-12-20T09:19:49.125-05:00| vmx| I125: SCSI DEVICE (scsi0:0): Computed value of scsi0:0.useBounceBuffers: default
2018-12-20T09:19:49.125-05:00| vmx| I125: DISKUTIL: scsi0:0 : capacity=143360000 logical sector size=512
2018-12-20T09:19:49.125-05:00| vmx| I125: DISKUTIL: scsi0:0 : geometry=8923/255/63
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA-GFB: Config settings: autodetect=0, numDisplays=1, maxWidth=2560, maxHeight=1600
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA-GFB: Desired maximum display topology: wh(2560, 1600)
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA-GFB: Autodetected target gfbSize = 268435456
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA-GFB: Using Initial gfbSize = 4194304
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA-GFB: Truncated maximum resolution for register modes to VRAM size: VRAM=4194304 bytes, max wh(1176, 885)
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA-GFB: Max wh(1176, 885), number of displays: 1
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA-GFB: Allocated gfbSize=4194304
2018-12-20T09:19:49.126-05:00| vmx| A100: ConfigDB: Setting vmotion.checkpointFBSize = "4194304"
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGACaps: Device caps : 0x01ff83e2
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGACaps: Device caps2: 0x00000000
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA: FIFO capabilities 0x0000077f
2018-12-20T09:19:49.126-05:00| vmx| I125: SVGA3dCaps: host, at power on: 3d disabled
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 0]: 0x00000000 (3D)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 1]: 0x00000000 (MAX_LIGHTS)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 2]: 0x00000000 (MAX_TEXTURES)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 3]: 0x00000000 (MAX_CLIP_PLANES)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 4]: 0x00000000 (VERTEX_SHADER_VERSION)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 5]: 0x00000000 (VERTEX_SHADER)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 6]: 0x00000000 (FRAGMENT_SHADER_VERSION)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 7]: 0x00000000 (FRAGMENT_SHADER)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 8]: 0x00000000 (MAX_RENDER_TARGETS)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 9]: 0x00000000 (S23E8_TEXTURES)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 10]: 0x00000000 (S10E5_TEXTURES)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 11]: 0x00000000 (MAX_FIXED_VERTEXBLEND)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 12]: 0x00000000 (D16_BUFFER_FORMAT)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 13]: 0x00000000 (D24S8_BUFFER_FORMAT)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 14]: 0x00000000 (D24X8_BUFFER_FORMAT)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 15]: 0x00000000 (QUERY_TYPES)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 16]: 0x00000000 (TEXTURE_GRADIENT_SAMPLING)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 17]: 0.000000 (MAX_POINT_SIZE)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 18]: 0x00000000 (MAX_SHADER_TEXTURES)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 19]: 0x00000000 (MAX_TEXTURE_WIDTH)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 20]: 0x00000000 (MAX_TEXTURE_HEIGHT)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 21]: 0x00000000 (MAX_VOLUME_EXTENT)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 22]: 0x00000000 (MAX_TEXTURE_REPEAT)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 23]: 0x00000000 (MAX_TEXTURE_ASPECT_RATIO)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 24]: 0x00000000 (MAX_TEXTURE_ANISOTROPY)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 25]: 0x00000000 (MAX_PRIMITIVE_COUNT)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 26]: 0x00000000 (MAX_VERTEX_INDEX)
2018-12-20T09:19:49.126-05:00| vmx| I125: cap[ 27]: 0x00000000 (MAX_VERTEX_SHADER_INSTRUCTIONS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 28]: 0x00000000 (MAX_FRAGMENT_SHADER_INSTRUCTIONS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 29]: 0x00000000 (MAX_VERTEX_SHADER_TEMPS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 30]: 0x00000000 (MAX_FRAGMENT_SHADER_TEMPS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 31]: 0x00000000 (TEXTURE_OPS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 32]: 0x00000000 (SURFACEFMT_X8R8G8B8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 33]: 0x00000000 (SURFACEFMT_A8R8G8B8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 34]: 0x00000000 (SURFACEFMT_A2R10G10B10)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 35]: 0x00000000 (SURFACEFMT_X1R5G5B5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 36]: 0x00000000 (SURFACEFMT_A1R5G5B5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 37]: 0x00000000 (SURFACEFMT_A4R4G4B4)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 38]: 0x00000000 (SURFACEFMT_R5G6B5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 39]: 0x00000000 (SURFACEFMT_LUMINANCE16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 40]: 0x00000000 (SURFACEFMT_LUMINANCE8_ALPHA8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 41]: 0x00000000 (SURFACEFMT_ALPHA8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 42]: 0x00000000 (SURFACEFMT_LUMINANCE8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 43]: 0x00000000 (SURFACEFMT_Z_D16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 44]: 0x00000000 (SURFACEFMT_Z_D24S8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 45]: 0x00000000 (SURFACEFMT_Z_D24X8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 46]: 0x00000000 (SURFACEFMT_DXT1)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 47]: 0x00000000 (SURFACEFMT_DXT2)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 48]: 0x00000000 (SURFACEFMT_DXT3)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 49]: 0x00000000 (SURFACEFMT_DXT4)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 50]: 0x00000000 (SURFACEFMT_DXT5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 51]: 0x00000000 (SURFACEFMT_BUMPX8L8V8U8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 52]: 0x00000000 (SURFACEFMT_A2W10V10U10)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 53]: 0x00000000 (SURFACEFMT_BUMPU8V8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 54]: 0x00000000 (SURFACEFMT_Q8W8V8U8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 55]: 0x00000000 (SURFACEFMT_CxV8U8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 56]: 0x00000000 (SURFACEFMT_R_S10E5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 57]: 0x00000000 (SURFACEFMT_R_S23E8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 58]: 0x00000000 (SURFACEFMT_RG_S10E5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 59]: 0x00000000 (SURFACEFMT_RG_S23E8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 60]: 0x00000000 (SURFACEFMT_ARGB_S10E5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 61]: 0x00000000 (SURFACEFMT_ARGB_S23E8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 62]: 0x00000000 (MISSING62)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 63]: 0x00000000 (MAX_VERTEX_SHADER_TEXTURES)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 64]: 0x00000000 (MAX_SIMULTANEOUS_RENDER_TARGETS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 65]: 0x00000000 (SURFACEFMT_V16U16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 66]: 0x00000000 (SURFACEFMT_G16R16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 67]: 0x00000000 (SURFACEFMT_A16B16G16R16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 68]: 0x00000000 (SURFACEFMT_UYVY)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 69]: 0x00000000 (SURFACEFMT_YUY2)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 70]: 0x00000000 (DEAD4)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 71]: 0x00000000 (DEAD5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 72]: 0x00000000 (DEAD7)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 73]: 0x00000000 (DEAD6)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 74]: 0x00000000 (AUTOGENMIPMAPS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 75]: 0x00000000 (SURFACEFMT_NV12)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 76]: 0x00000000 (SURFACEFMT_AYUV)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 77]: 0x00000000 (MAX_CONTEXT_IDS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 78]: 0x00000000 (MAX_SURFACE_IDS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 79]: 0x00000000 (SURFACEFMT_Z_DF16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 80]: 0x00000000 (SURFACEFMT_Z_DF24)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 81]: 0x00000000 (SURFACEFMT_Z_D24S8_INT)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 82]: 0x00000000 (SURFACEFMT_ATI1)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 83]: 0x00000000 (SURFACEFMT_ATI2)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 84]: 0x00000000 (DEAD1)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 85]: 0x00000000 (VIDEO_DECODE)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 86]: 0x00000000 (VIDEO_PROCESS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 87]: 0x00000000 (LINE_AA)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 88]: 0x00000000 (LINE_STIPPLE)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 89]: 0.000000 (MAX_LINE_WIDTH)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 90]: 0.000000 (MAX_AA_LINE_WIDTH)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 91]: 0x00000000 (SURFACEFMT_YV12)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 92]: 0x00000000 (DEAD3)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 93]: 0x00000000 (TS_COLOR_KEY)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 94]: 0x00000000 (DEAD2)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 95]: 0x00000000 (DXCONTEXT)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 96]: 0x00000000 (MAX_TEXTURE_ARRAY_SIZE)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 97]: 0x00000000 (DX_MAX_VERTEXBUFFERS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 98]: 0x00000000 (DX_MAX_CONSTANT_BUFFERS)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[ 99]: 0x00000000 (DX_PROVOKING_VERTEX)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[100]: 0x00000000 (DXFMT_X8R8G8B8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[101]: 0x00000000 (DXFMT_A8R8G8B8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[102]: 0x00000000 (DXFMT_R5G6B5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[103]: 0x00000000 (DXFMT_X1R5G5B5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[104]: 0x00000000 (DXFMT_A1R5G5B5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[105]: 0x00000000 (DXFMT_A4R4G4B4)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[106]: 0x00000000 (DXFMT_Z_D32)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[107]: 0x00000000 (DXFMT_Z_D16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[108]: 0x00000000 (DXFMT_Z_D24S8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[109]: 0x00000000 (DXFMT_Z_D15S1)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[110]: 0x00000000 (DXFMT_LUMINANCE8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[111]: 0x00000000 (DXFMT_LUMINANCE4_ALPHA4)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[112]: 0x00000000 (DXFMT_LUMINANCE16)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[113]: 0x00000000 (DXFMT_LUMINANCE8_ALPHA8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[114]: 0x00000000 (DXFMT_DXT1)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[115]: 0x00000000 (DXFMT_DXT2)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[116]: 0x00000000 (DXFMT_DXT3)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[117]: 0x00000000 (DXFMT_DXT4)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[118]: 0x00000000 (DXFMT_DXT5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[119]: 0x00000000 (DXFMT_BUMPU8V8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[120]: 0x00000000 (DXFMT_BUMPL6V5U5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[121]: 0x00000000 (DXFMT_BUMPX8L8V8U8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[122]: 0x00000000 (DXFMT_FORMAT_DEAD1)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[123]: 0x00000000 (DXFMT_ARGB_S10E5)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[124]: 0x00000000 (DXFMT_ARGB_S23E8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[125]: 0x00000000 (DXFMT_A2R10G10B10)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[126]: 0x00000000 (DXFMT_V8U8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[127]: 0x00000000 (DXFMT_Q8W8V8U8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[128]: 0x00000000 (DXFMT_CxV8U8)
2018-12-20T09:19:49.127-05:00| vmx| I125: cap[129]: 0x00000000 (DXFMT_X8L8V8U8)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[130]: 0x00000000 (DXFMT_A2W10V10U10)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[131]: 0x00000000 (DXFMT_ALPHA8)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[132]: 0x00000000 (DXFMT_R_S10E5)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[133]: 0x00000000 (DXFMT_R_S23E8)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[134]: 0x00000000 (DXFMT_RG_S10E5)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[135]: 0x00000000 (DXFMT_RG_S23E8)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[136]: 0x00000000 (DXFMT_BUFFER)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[137]: 0x00000000 (DXFMT_Z_D24X8)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[138]: 0x00000000 (DXFMT_V16U16)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[139]: 0x00000000 (DXFMT_G16R16)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[140]: 0x00000000 (DXFMT_A16B16G16R16)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[141]: 0x00000000 (DXFMT_UYVY)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[142]: 0x00000000 (DXFMT_YUY2)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[143]: 0x00000000 (DXFMT_NV12)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[144]: 0x00000000 (DXFMT_AYUV)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[145]: 0x00000000 (DXFMT_R32G32B32A32_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[146]: 0x00000000 (DXFMT_R32G32B32A32_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[147]: 0x00000000 (DXFMT_R32G32B32A32_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[148]: 0x00000000 (DXFMT_R32G32B32_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[149]: 0x00000000 (DXFMT_R32G32B32_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[150]: 0x00000000 (DXFMT_R32G32B32_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[151]: 0x00000000 (DXFMT_R32G32B32_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[152]: 0x00000000 (DXFMT_R16G16B16A16_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[153]: 0x00000000 (DXFMT_R16G16B16A16_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[154]: 0x00000000 (DXFMT_R16G16B16A16_SNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[155]: 0x00000000 (DXFMT_R16G16B16A16_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[156]: 0x00000000 (DXFMT_R32G32_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[157]: 0x00000000 (DXFMT_R32G32_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[158]: 0x00000000 (DXFMT_R32G32_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[159]: 0x00000000 (DXFMT_R32G8X24_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[160]: 0x00000000 (DXFMT_D32_FLOAT_S8X24_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[161]: 0x00000000 (DXFMT_R32_FLOAT_X8X24)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[162]: 0x00000000 (DXFMT_X32_G8X24_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[163]: 0x00000000 (DXFMT_R10G10B10A2_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[164]: 0x00000000 (DXFMT_R10G10B10A2_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[165]: 0x00000000 (DXFMT_R11G11B10_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[166]: 0x00000000 (DXFMT_R8G8B8A8_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[167]: 0x00000000 (DXFMT_R8G8B8A8_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[168]: 0x00000000 (DXFMT_R8G8B8A8_UNORM_SRGB)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[169]: 0x00000000 (DXFMT_R8G8B8A8_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[170]: 0x00000000 (DXFMT_R8G8B8A8_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[171]: 0x00000000 (DXFMT_R16G16_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[172]: 0x00000000 (DXFMT_R16G16_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[173]: 0x00000000 (DXFMT_R16G16_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[174]: 0x00000000 (DXFMT_R32_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[175]: 0x00000000 (DXFMT_D32_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[176]: 0x00000000 (DXFMT_R32_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[177]: 0x00000000 (DXFMT_R32_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[178]: 0x00000000 (DXFMT_R24G8_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[179]: 0x00000000 (DXFMT_D24_UNORM_S8_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[180]: 0x00000000 (DXFMT_R24_UNORM_X8)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[181]: 0x00000000 (DXFMT_X24_G8_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[182]: 0x00000000 (DXFMT_R8G8_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[183]: 0x00000000 (DXFMT_R8G8_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[184]: 0x00000000 (DXFMT_R8G8_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[185]: 0x00000000 (DXFMT_R8G8_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[186]: 0x00000000 (DXFMT_R16_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[187]: 0x00000000 (DXFMT_R16_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[188]: 0x00000000 (DXFMT_R16_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[189]: 0x00000000 (DXFMT_R16_SNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[190]: 0x00000000 (DXFMT_R16_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[191]: 0x00000000 (DXFMT_R8_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[192]: 0x00000000 (DXFMT_R8_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[193]: 0x00000000 (DXFMT_R8_UINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[194]: 0x00000000 (DXFMT_R8_SNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[195]: 0x00000000 (DXFMT_R8_SINT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[196]: 0x00000000 (DXFMT_P8)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[197]: 0x00000000 (DXFMT_R9G9B9E5_SHAREDEXP)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[198]: 0x00000000 (DXFMT_R8G8_B8G8_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[199]: 0x00000000 (DXFMT_G8R8_G8B8_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[200]: 0x00000000 (DXFMT_BC1_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[201]: 0x00000000 (DXFMT_BC1_UNORM_SRGB)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[202]: 0x00000000 (DXFMT_BC2_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[203]: 0x00000000 (DXFMT_BC2_UNORM_SRGB)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[204]: 0x00000000 (DXFMT_BC3_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[205]: 0x00000000 (DXFMT_BC3_UNORM_SRGB)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[206]: 0x00000000 (DXFMT_BC4_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[207]: 0x00000000 (DXFMT_ATI1)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[208]: 0x00000000 (DXFMT_BC4_SNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[209]: 0x00000000 (DXFMT_BC5_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[210]: 0x00000000 (DXFMT_ATI2)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[211]: 0x00000000 (DXFMT_BC5_SNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[212]: 0x00000000 (DXFMT_R10G10B10_XR_BIAS_A2_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[213]: 0x00000000 (DXFMT_B8G8R8A8_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[214]: 0x00000000 (DXFMT_B8G8R8A8_UNORM_SRGB)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[215]: 0x00000000 (DXFMT_B8G8R8X8_TYPELESS)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[216]: 0x00000000 (DXFMT_B8G8R8X8_UNORM_SRGB)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[217]: 0x00000000 (DXFMT_Z_DF16)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[218]: 0x00000000 (DXFMT_Z_DF24)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[219]: 0x00000000 (DXFMT_Z_D24S8_INT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[220]: 0x00000000 (DXFMT_YV12)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[221]: 0x00000000 (DXFMT_R32G32B32A32_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[222]: 0x00000000 (DXFMT_R16G16B16A16_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[223]: 0x00000000 (DXFMT_R16G16B16A16_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[224]: 0x00000000 (DXFMT_R32G32_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[225]: 0x00000000 (DXFMT_R10G10B10A2_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[226]: 0x00000000 (DXFMT_R8G8B8A8_SNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[227]: 0x00000000 (DXFMT_R16G16_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[228]: 0x00000000 (DXFMT_R16G16_UNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[229]: 0x00000000 (DXFMT_R16G16_SNORM)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[230]: 0x00000000 (DXFMT_R32_FLOAT)
2018-12-20T09:19:49.128-05:00| vmx| I125: cap[231]: 0x00000000 (DXFMT_R8G8_SNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[232]: 0x00000000 (DXFMT_R16_FLOAT)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[233]: 0x00000000 (DXFMT_D16_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[234]: 0x00000000 (DXFMT_A8_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[235]: 0x00000000 (DXFMT_BC1_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[236]: 0x00000000 (DXFMT_BC2_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[237]: 0x00000000 (DXFMT_BC3_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[238]: 0x00000000 (DXFMT_B5G6R5_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[239]: 0x00000000 (DXFMT_B5G5R5A1_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[240]: 0x00000000 (DXFMT_B8G8R8A8_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[241]: 0x00000000 (DXFMT_B8G8R8X8_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[242]: 0x00000000 (DXFMT_BC4_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[243]: 0x00000000 (DXFMT_BC5_UNORM)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[244]: 0x00000000 (SM41)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[245]: 0x00000000 (MULTISAMPLE_2X)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[246]: 0x00000000 (MULTISAMPLE_4X)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[247]: 0x00000000 (LOGIC_BLENDOPS)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[248]: 0x00000000 (ALLOW_D16_L16_COPY)
2018-12-20T09:19:49.129-05:00| vmx| I125: cap[249]: 0x00000000 (LOGICOPS)
2018-12-20T09:19:49.129-05:00| vmx| I125: SVGA3dCaps: guest, compatibility level: No-Clamping
2018-12-20T09:19:49.129-05:00| svga| I125: VTHREAD 140617759848192 "svga" tid 27380
2018-12-20T09:19:49.129-05:00| vmx| I125: Ethernet0 MAC Address: 00:0c:29:63:71:ef
2018-12-20T09:19:49.132-05:00| vmx| I125: Ethernet1 MAC Address: 00:0c:29:63:71:f9
2018-12-20T09:19:49.132-05:00| vmx| I125: Ethernet2 MAC Address: 00:0c:29:63:71:03
2018-12-20T09:19:49.133-05:00| vmx| I125: Ethernet3 MAC Address: 00:0c:29:63:71:0d
2018-12-20T09:19:49.134-05:00| vmx| I125: Ethernet4 MAC Address: 00:0c:29:63:71:17
2018-12-20T09:19:49.135-05:00| vmx| A100: ConfigDB: Setting vmci0.id = "-1771867665"
2018-12-20T09:19:49.144-05:00| vmx| I125: SOUNDLIB: SoundLib_CreatePulseBackend: waiting for connection to Pulse server
2018-12-20T09:19:49.145-05:00| vmx| I125: WORKER: Creating new group with numThreads=1 (37)
2018-12-20T09:19:49.145-05:00| vmx| I125: DISKUTIL: scsi0:0 : max toolsVersion = 10247, type = 4
2018-12-20T09:19:49.145-05:00| vmx| I125: TOOLS setting legacy tools version to '10247' type 4, manifest status is 9
2018-12-20T09:19:49.145-05:00| worker-27378| I125: ToolsVersionGetStatusWorkerThread: Tools status 8 derived from environment
2018-12-20T09:19:49.145-05:00| vmx| I125: TOOLS INSTALL initializing state to IDLE on power on.
2018-12-20T09:19:49.145-05:00| vmx| I125: HgfsServerManagerVigorInit: Initialize: dev api
2018-12-20T09:19:49.146-05:00| vmx| I125: DEPLOYPKG: ToolsDeployPkgPublishState: state=0, code=0, message=(null)
2018-12-20T09:19:49.184-05:00| vmx| I125: MonPmc: ctrBase 0x4c1 selBase 0x186/1 PGC 1/1 SMM 1 drain 1 AMD 0
2018-12-20T09:19:49.184-05:00| vmx| I125+ MonPmc: gen counters num: 4 width 48 write width 48
2018-12-20T09:19:49.184-05:00| vmx| I125+ MonPmc: fix counters num: 3 width 48
2018-12-20T09:19:49.184-05:00| vmx| I125+ MonPmc: unavailable counters: 0x200000000
2018-12-20T09:19:49.185-05:00| vmx| I125: CPUID Maximum Physical Address Bits supported across all CPUs: 36
2018-12-20T09:19:49.188-05:00| vmx| A100: ConfigDB: Setting monitor.phys_bits_used = "40"
2018-12-20T09:19:49.188-05:00| vmx| I125: Full guest CPUID with differences from hostCPUID highlighted.
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest vendor: GenuineIntel
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest family: 0x6 model: 0x2a stepping: 0x7
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest codename: Sandy Bridge
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID level eaxIn, ecxIn: eax ebx ecx edx
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000000, 0: 0x0000000d 0x756e6547 0x6c65746e 0x49656e69
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000001, 0: 0x000206a7 0x00010800 0x96ba2223 0x0f8bfbff
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 00000001, 0: 0x000206a7 0x05100800 0x1f9ae3bf 0xbfebfbff
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000002, 0: 0x76035a01 0x00f0b2ff 0x00000000 0x00ca0000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000004, 0: 0x00000121 0x01c0003f 0x0000003f 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 00000004, 0: 0x1c004121 0x01c0003f 0x0000003f 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000004, 1: 0x00000122 0x01c0003f 0x0000003f 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 00000004, 1: 0x1c004122 0x01c0003f 0x0000003f 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000004, 2: 0x00000143 0x01c0003f 0x000001ff 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 00000004, 2: 0x1c004143 0x01c0003f 0x000001ff 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000004, 3: 0x00000163 0x03c0003f 0x00001fff 0x00000006
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 00000004, 3: 0x1c03c163 0x03c0003f 0x00001fff 0x00000006
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000004, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000004, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000004, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000006, 0: 0x00000004 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 00000006, 0: 0x00000077 0x00000002 0x00000009 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000007, 0: 0x00000000 0x00000000 0x00000000 0xbc000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 00000007, 0: 0x00000000 0x00000000 0x00000000 0x9c000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000a, 0: 0x07300401 0x0000007f 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 0000000a, 0: 0x07300403 0x00000000 0x00000000 0x00000603
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000b, 0: 0x00000000 0x00000001 0x00000100 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000005
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000b, 1: 0x00000000 0x00000001 0x00000201 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000005
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 0: 0x00000007 0x00000340 0x00000340 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID *host level 0000000d, 1: 0x00000001 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2: 0x00000100 0x00000240 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 7: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 8: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 9: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, f: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 10: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 11: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 12: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 13: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 14: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 15: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 16: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 17: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 18: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 19: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 1f: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 20: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 21: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 22: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 23: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 24: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 25: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 26: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 27: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 28: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 29: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 2f: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 30: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 31: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 32: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 33: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 34: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 35: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 36: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 37: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 38: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 39: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000d, 3f: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.188-05:00| vmx| I125: guest vs. host CPUID guest level 0000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 0000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 0000000f, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000010, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000017, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000017, 2: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 00000017, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000000, 0: 0x40000010 0x61774d56 0x4d566572 0x65726177
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000001, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000004, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000005, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000006, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000007, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 4000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 4000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 4000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 4000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 4000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 4000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 40000010, 0: 0x0034085e 0x000101d0 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000000, 0: 0x80000008 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000001, 0: 0x00000000 0x00000000 0x00000001 0x28100800
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000002, 0: 0x20202020 0x49202020 0x6c65746e 0x20295228
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000003, 0: 0x65726f43 0x294d5428 0x2d376920 0x30303632
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000004, 0: 0x5043204b 0x20402055 0x30342e33 0x007a4847
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000005, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000006, 0: 0x00000000 0x00000000 0x01006040 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000007, 0: 0x00000000 0x00000000 0x00000000 0x00000100
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000008, 0: 0x00003028 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID *host level 80000008, 0: 0x00003024 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000014, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000018, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 80000019, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 2: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.189-05:00| vmx| I125: guest vs. host CPUID guest level 8000001f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-12-20T09:19:49.190-05:00| vmx| I125: Minimum ucode level: 0x0000002e
2018-12-20T09:19:49.190-05:00| vmx| I125: VPMC: events will use hybrid freeze.
2018-12-20T09:19:49.190-05:00| vmx| I125: VPMC: gen counters: num 4 mask 0xffffffffffff
2018-12-20T09:19:49.190-05:00| vmx| I125: VPMC: fix counters: num 0 mask 0; version 1
2018-12-20T09:19:49.190-05:00| vmx| I125: VPMC: hardware counters: 0
2018-12-20T09:19:49.190-05:00| vmx| I125: VPMC: perf capabilities: 0x2000
2018-12-20T09:19:49.190-05:00| vmx| I125: SVGA-PCI: BAR gfbSize=134217728, fifoSize=8388608
2018-12-20T09:19:49.190-05:00| vmx| I125: SVGA: SVGA_REG_MEMORY_SIZE=809500672
2018-12-20T09:19:49.190-05:00| vmx| I125: SVGA: SVGA_REG_VRAM_SIZE=4194304
2018-12-20T09:19:49.190-05:00| vmx| I125: BusMemSampleSetUpStats: touched: initPct 75 pages 3145728 : dirtied: initPct 75 pages 3145728
2018-12-20T09:19:49.190-05:00| vmx| I125: MemSched: caller 0 numvm 1 locked pages: num 8973 max 7131136
2018-12-20T09:19:49.190-05:00| vmx| I125: MemSched: locked Page Limit: host 8086330 config 7139328 dynam -1
2018-12-20T09:19:49.190-05:00| vmx| I125: MemSched: minmempct 50 timestamp 1398
2018-12-20T09:19:49.190-05:00| vmx| I125: MemSched: VM 0 min 2143784 max 4240936 shares 4194304 paged 77088 nonpaged 11264 anonymous 35368 locked 8973 touchedPct 75 dirtiedPct 75 timestamp 1398 vmResponsive is 1
2018-12-20T09:19:49.190-05:00| vmx| I125: MemSched: locked 8973 target 4240936 balloon 0 0 0 swapped 0 0 allocd 0 512 state 0 100
2018-12-20T09:19:49.190-05:00| vmx| I125: MemSched: states: 0 1 : 1 0 : 2 0 : 3 0
2018-12-20T09:19:49.190-05:00| vmx| I125: MemSched: Balloon enabled 1 guestType 0 maxSize 0
2018-12-20T09:19:49.190-05:00| vmx| I125: FeatureCompat: Capabilities:
2018-12-20T09:19:49.190-05:00| vmx| I125: Capability Found: cpuid.sse3 = 1
2018-12-20T09:19:49.190-05:00| vmx| I125: Capability Found: cpuid.pclmulqdq = 1
2018-12-20T09:19:49.190-05:00| vmx| I125: Capability Found: cpuid.mwait = 1
2018-12-20T09:19:49.190-05:00| vmx| I125: Capability Found: cpuid.vmx = 1
2018-12-20T09:19:49.190-05:00| vmx| I125: Capability Found: cpuid.ssse3 = 1
2018-12-20T09:19:49.190-05:00| vmx| I125: Capability Found: cpuid.cmpxchg16b = 1
2018-12-20T09:19:49.190-05:00| vmx| I125: Capability Found: cpuid.pcid = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.sse41 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.sse42 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.popcnt = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.aes = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.xsave = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.avx = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.ds = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.ss = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.stibp = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.fcmd = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.ssbd = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.xcr0_master_sse = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.xcr0_master_ymm_h = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.xsaveopt = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.lahf64 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.nx = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.rdtscp = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.lm = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.intel = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.ibrs = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: cpuid.ibpb = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: hv.capable = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vt.realmode = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.microarchitecture.sandybridge = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.numgenctrs = 4
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.numfixedctrs = 3
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.genwidth = 0x30
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.fixedwidth = 0x30
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.version = 3
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.genctr.0 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.genctr.1 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.genctr.2 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.genctr.3 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.fixctr.0 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: Capability Found: vpmc.fixctr.2 = 1
2018-12-20T09:19:49.191-05:00| vmx| I125: FeatureCompat: Requirements:
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.sse3 - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.pclmulqdq - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.vmx - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.ssse3 - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.cmpxchg16b - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.pcid - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.sse41 - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.sse42 - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.popcnt - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.aes - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.xsave - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.avx - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.ss - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.stibp - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.fcmd - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.ssbd - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.xcr0_master_sse - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.xcr0_master_ymm_h - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.lahf64 - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.nx - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.rdtscp - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.lm - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.intel - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.ibrs - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: cpuid.ibpb - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: hv.capable - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: VM Features Required: vt.realmode - Bool:Min:1
2018-12-20T09:19:49.191-05:00| vmx| I125: TOOLS received request in VMX to set option 'enableDnD' -> '1'
2018-12-20T09:19:49.193-05:00| vmx| I125: Active HV capabilities
2018-12-20T09:19:49.193-05:00| vmx| I125: Address space identifiers
2018-12-20T09:19:49.193-05:00| vmx| I125: Flush by ASID
2018-12-20T09:19:49.193-05:00| vmx| I125: Full decode
2018-12-20T09:19:49.193-05:00| vmx| I125: MSR permission bitmap
2018-12-20T09:19:49.193-05:00| vmx| I125: Next RIP
2018-12-20T09:19:49.193-05:00| vmx| I125: Real-address mode
2018-12-20T09:19:49.193-05:00| vmx| I125: Skip debug state
2018-12-20T09:19:49.193-05:00| vmx| I125: Virtual NMI
2018-12-20T09:19:49.193-05:00| vmx| I125: X2APIC virtualization
2018-12-20T09:19:49.193-05:00| vmx| I125: INVEPT single-context
2018-12-20T09:19:49.193-05:00| vmx| I125: Guest VT-x Capabilities:
2018-12-20T09:19:49.193-05:00| vmx| I125: Basic VMX Information (0x00d8100000000001)
2018-12-20T09:19:49.193-05:00| vmx| I125: VMCS revision ID 1
2018-12-20T09:19:49.193-05:00| vmx| I125: VMCS region length 4096
2018-12-20T09:19:49.193-05:00| vmx| I125: VMX physical-address width natural
2018-12-20T09:19:49.193-05:00| vmx| I125: SMM dual-monitor mode no
2018-12-20T09:19:49.193-05:00| vmx| I125: Advanced INS/OUTS info yes
2018-12-20T09:19:49.193-05:00| vmx| I125: True VMX MSRs yes
2018-12-20T09:19:49.193-05:00| vmx| I125: VMCS memory type WB
2018-12-20T09:19:49.193-05:00| vmx| I125: True Pin-Based VM-Execution Controls (0x0000003f00000016)
2018-12-20T09:19:49.193-05:00| vmx| I125: External-interrupt exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: NMI exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Virtual NMIs {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Activate VMX-preemption timer { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Process posted interrupts { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: True Primary Processor-Based VM-Execution Controls (0xfff9fffe04006172)
2018-12-20T09:19:49.193-05:00| vmx| I125: Interrupt-window exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Use TSC offsetting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: HLT exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: INVLPG exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: MWAIT exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: RDPMC exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: RDTSC exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: CR3-load exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: CR3-store exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: CR8-load exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: CR8-store exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Use TPR shadow {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: NMI-window exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: MOV-DR exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Unconditional I/O exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Use I/O bitmaps {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Monitor trap flag {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Use MSR bitmaps {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: MONITOR exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: PAUSE exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Activate secondary controls {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Secondary Processor-Based VM-Execution Controls (0x000000fe00000000)
2018-12-20T09:19:49.193-05:00| vmx| I125: Virtualize APIC accesses { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Enable EPT {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Descriptor-table exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Enable RDTSCP {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Virtualize x2APIC mode {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Enable VPID {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: WBINVD exiting {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Unrestricted guest {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: APIC-register virtualization { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Virtual-interrupt delivery { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: PAUSE-loop exiting { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: RDRAND exiting { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Enable INVPCID { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Enable VM Functions { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Use VMCS shadowing { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: ENCLS exiting { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: RDSEED exiting { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Enable PML { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: EPT-violation #VE { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Enable XSAVES/XRSTORS { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Mode-based execute control for EPT { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Use TSC scaling { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: True VM-Exit Controls (0x0033ffff00036dfb)
2018-12-20T09:19:49.193-05:00| vmx| I125: Save debug controls {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Host address-space size {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Load IA32_PERF_GLOBAL_CTRL {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Acknowledge interrupt on exit {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Save IA32_PAT { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Load IA32_PAT { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Save IA32_EFER {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Load IA32_EFER {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Save VMX-preemption timer { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: True VM-Entry Controls (0x0000b3ff000011fb)
2018-12-20T09:19:49.193-05:00| vmx| I125: Load debug controls {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: IA-32e mode guest {0,1}
2018-12-20T09:19:49.193-05:00| vmx| I125: Entry to SMM { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: Deactivate dual-monitor mode { 0 }
2018-12-20T09:19:49.193-05:00| vmx| I125: VPID and EPT Capabilities (0x00000f0106114041)
2018-12-20T09:19:49.193-05:00| vmx| I125: R=0/W=0/X=1 yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Page-walk length 3 yes
2018-12-20T09:19:49.193-05:00| vmx| I125: EPT memory type WB yes
2018-12-20T09:19:49.193-05:00| vmx| I125: 2MB super-page yes
2018-12-20T09:19:49.193-05:00| vmx| I125: 1GB super-page no
2018-12-20T09:19:49.193-05:00| vmx| I125: INVEPT support yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Access & Dirty Bits no
2018-12-20T09:19:49.193-05:00| vmx| I125: Advanced VM exit information for EPT violations no
2018-12-20T09:19:49.193-05:00| vmx| I125: Type 1 INVEPT yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Type 2 INVEPT yes
2018-12-20T09:19:49.193-05:00| vmx| I125: INVVPID support yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Type 0 INVVPID yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Type 1 INVVPID yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Type 2 INVVPID yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Type 3 INVVPID yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Miscellaneous VMX Data (0x00000000000401e0)
2018-12-20T09:19:49.193-05:00| vmx| I125: TSC to preemption timer ratio 0
2018-12-20T09:19:49.193-05:00| vmx| I125: VM-Exit saves EFER.LMA yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Activity State HLT yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Activity State shutdown yes
2018-12-20T09:19:49.193-05:00| vmx| I125: Activity State wait-for-SIPI yes
2018-12-20T09:19:49.193-05:00| vmx| I125: CR3 targets supported 4
2018-12-20T09:19:49.193-05:00| vmx| I125: Maximum MSR list size 512
2018-12-20T09:19:49.193-05:00| vmx| I125: Allow all VMWRITEs no
2018-12-20T09:19:49.193-05:00| vmx| I125: Allow zero instruction length no
2018-12-20T09:19:49.193-05:00| vmx| I125: MSEG revision ID 0
2018-12-20T09:19:49.193-05:00| vmx| I125: Processor trace in VMX no
2018-12-20T09:19:49.193-05:00| vmx| I125: VMX-Fixed Bits in CR0 (0x0000000080000021/0x00000000ffffffff)
2018-12-20T09:19:49.193-05:00| vmx| I125: Fixed to 0 0xffffffff00000000
2018-12-20T09:19:49.193-05:00| vmx| I125: Fixed to 1 0x0000000080000021
2018-12-20T09:19:49.193-05:00| vmx| I125: Variable 0x000000007fffffde
2018-12-20T09:19:49.193-05:00| vmx| I125: VMX-Fixed Bits in CR4 (0x0000000000002000/0x00000000000627ff)
2018-12-20T09:19:49.193-05:00| vmx| I125: Fixed to 0 0xfffffffffff9d800
2018-12-20T09:19:49.193-05:00| vmx| I125: Fixed to 1 0x0000000000002000
2018-12-20T09:19:49.193-05:00| vmx| I125: Variable 0x00000000000607ff
2018-12-20T09:19:49.193-05:00| vmx| I125: VMCS Enumeration (0x000000000000005a)
2018-12-20T09:19:49.193-05:00| vmx| I125: Highest index 0x2d
2018-12-20T09:19:49.193-05:00| vmx| I125: VM Functions (0x0000000000000000)
2018-12-20T09:19:49.193-05:00| vmx| I125+ OvhdMem: Static (Power On) Overheads
2018-12-20T09:19:49.193-05:00| vmx| I125: reserved | used
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem excluded cur max avg | cur max avg
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_MainMem : 4194304 4194304 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxText : 7168 7168 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxTextLibs : 15360 15360 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem Total excluded : 4216832 4216832 - | - - -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem Actual maximum : 4216832 | -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem paged cur max avg | cur max avg
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_KSTATS_vmm : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_STATS_vmm : 8 8 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_KSTATS_device : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_STATS_device : 4 4 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_KSTATS_migrate : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_IOFiltersMalloc : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_DiskLibMemUsed : 3075 3075 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaSurfaceTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaBESurfaceTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaHBTables : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaHBMobListTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaHBShaderTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaSDirtyCache : 48 48 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaShaderTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaShaderText : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaContextCache : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaMobCache : 296 296 - | 24 24 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXRTViewTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXDSViewTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXSRViewTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXUAViewTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXBlendStateTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXElementLayoutTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXDepthStencilTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXRasterizerStateTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXSamplerTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXContextTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXShaderTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXShaderText : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXStreamOutTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaDXQueryTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaVAProcessorTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SvgaVADecoderTable : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxAllocTrack : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxASAN : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxCallStackProf : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxGlobals : 10240 10240 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxGlobalsLibs : 3584 3584 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxHeap : 8704 8704 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxHeapFreeList : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMks : 33 33 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksRenderOps : 399 399 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMks3d : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksHBMobs : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksGLRenderer : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksGLTransient : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksLLVM : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksScreenTemp : 5378 5378 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksVnc : 2682 2682 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksScreen : 2051 2051 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksSVGAVO : 4096 4096 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxMksVMVA : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxPhysMemRingBuf : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxPhysMemErrPages : 10 10 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxFTCptOutputBuf : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxSLEntryBuf : 128 128 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VmxThreads : 36352 36352 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem Total paged : 77088 77088 - | 24 24 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem Actual maximum : 77088 | 24
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem nonpaged cur max avg | cur max avg
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SharedArea : 126 126 - | 107 107 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_BusMemTraceBitmap : 131 131 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_PFrame : 8341 8546 - | 8341 8341 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VProbe : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VIDE_KSEG : 16 16 - | 16 16 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VGA : 64 64 - | 64 64 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_BalloonMPN : 1 1 - | 1 1 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_P2MUpdateBuffer : 3 3 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_ServicesMPN : 2 2 - | 2 2 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_LocalApic : 4 4 - | 4 4 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_BusError : 1 1 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VBIOS : 8 8 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VnicGuest : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VnicMmap : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_TestDev : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_LSIBIOS : 4 4 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_LSIRings : 4 4 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_PCIPBIOS : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_PVSCSIBIOS : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_PVSCSIKickReg : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SAS1068BIOS : 4 4 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SBIOS : 16 16 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_AHCIBIOS : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_NVMEBIOS : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_FlashRam : 128 128 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_IOFiltersMMap : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_IOFiltersGlobal : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SMM : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SVGAFB : 1024 1024 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_SVGAMEM : 512 512 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_HDAudioReg : 3 3 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_EHCIRegister : 1 1 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_XhciRegister : 1 1 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_PhysMemDebug : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_HyperV : 2 2 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_ExtCfg : 3 3 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_HV : 8 8 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_HVIOBitmap : 3 3 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_HVMSRBitmap : 2 2 - | 1 1 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_VHVGuestMSRBitmap : 2 2 - | 1 1 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_vhvCachedVMCS : 4 4 - | 4 4 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_vhvNestedAPIC : 4 4 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_PCIP : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_MigrateCpt : 0 0 - | 0 0 -
2018-12-20T09:19:49.193-05:00| vmx| I125: OvhdMem OvhdUser_MonBootstrap : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_MonWired : 124 124 - | 92 92 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_MonWiredNuma : 68 68 - | 40 40 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_MonNuma : 308 308 - | 285 285 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_MonOther : 136 136 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_FTCpt : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_NVDC : 1 1 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_NVDIMM : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdUser_EPC : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem Total nonpaged : 11059 11264 - | 8958 8958 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem Actual maximum : 11264 | 8958
2018-12-20T09:19:49.194-05:00| vmx| I125+
2018-12-20T09:19:49.194-05:00| vmx| I125: reserved | used
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem anonymous cur max avg | cur max avg
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_Alloc : 392 392 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_BusMemFrame : 4163 4171 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_BusMem2MInfo : 64 64 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_BusMem1GInfo : 1 1 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_BusMemZapListMPN : 1 1 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_MonAS : 8 8 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_GuestMem : 96 96 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_TC : 2052 2052 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_Island : 16 16 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_BusMemMonAS : 12 12 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_PlatformMonAS : 19 19 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_HVNuma : 8 8 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_HV : 4 4 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_VHV : 12 12 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_VNPTShadow : 9080 9080 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_VNPTShadowCache : 73 73 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_VNPTBackmap : 8214 8359 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_SVMIDT : 4 4 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_CallStackProfAnon : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_Numa : 42 42 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_NumaTextRodata : 180 180 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_NumaDataBss : 128 128 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_NumaLargeData : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_WiredNuma : 68 68 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_Bootstrap : 3 3 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_GPhysTraced : 1673 1673 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_GPhysHWMMU : 8386 8386 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_GPhysGIM : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_GPhysNoTrace : 418 418 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_PhysMemGart : 88 88 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_PhysMemErr : 9 9 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_TraceALot : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_VIDE : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_VMXNETWake : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_BusLogic : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_Ahci : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_Nvme : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_NVMERings : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_PVSCSIShadowRing : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_LSIRings : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_FTCptMonAS : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_Hba : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_VProbe : 1 1 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem OvhdMon_PT : 0 0 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem Total anonymous : 35215 35368 - | 0 0 -
2018-12-20T09:19:49.194-05:00| vmx| I125: OvhdMem Actual maximum : 35368 | 0
2018-12-20T09:19:49.194-05:00| vmx| I125: VMMEM: Precise Reservation: 481MB (MainMem=16384MB)
2018-12-20T09:19:49.194-05:00| vmx| I125: Vix: [mainDispatch.c:1068]: VMAutomation_PowerOn. Powering on.
2018-12-20T09:19:49.194-05:00| vmx| I125: VMX_PowerOn: ModuleTable_PowerOn = 1
2018-12-20T09:19:49.194-05:00| vmx| A100: ConfigDB: Setting cleanShutdown = "FALSE"
2018-12-20T09:19:49.194-05:00| vmx| A100: ConfigDB: Setting softPowerOff = "FALSE"
2018-12-20T09:19:49.225-05:00| vcpu-0| I125: VTHREAD 140635222783744 "vcpu-0" tid 27382
2018-12-20T09:19:49.232-05:00| vmx| I125: ToolsISO: Refreshing imageName for 'ubuntu-64' (refreshCount=1, lastCount=1).
2018-12-20T09:19:49.233-05:00| vmx| I125: ToolsISO: open of /usr/lib/vmware/isoimages/isoimages_manifest.txt.sig failed: Could not find the file
2018-12-20T09:19:49.233-05:00| vmx| I125: ToolsISO: Unable to read signature file '/usr/lib/vmware/isoimages/isoimages_manifest.txt.sig', ignoring.
2018-12-20T09:19:49.233-05:00| vmx| I125: ToolsISO: Updated cached value for imageName to 'linux.iso'.
2018-12-20T09:19:49.233-05:00| vmx| I125: ToolsISO: Selected Tools ISO 'linux.iso' for 'ubuntu-64' guest.
2018-12-20T09:19:49.233-05:00| vmx| I125: TOOLS updated cached value for isoImageExists to 0.
2018-12-20T09:19:49.233-05:00| vmx| I125: VMXVmdb_SetToolsVersionStatus: status value set to 'unmanaged', 'unmanaged', install impossible
2018-12-20T09:19:49.233-05:00| vcpu-0| I125: MonTimer APIC:0/0 vec: 0
2018-12-20T09:19:49.233-05:00| vcpu-0| I125: APIC: version = 0x15, max LVT = 6, LDR = 0x40000000, DFR = 0xffffffff
2018-12-20T09:19:49.247-05:00| svga| I125: SVGA thread is alive
2018-12-20T09:19:49.247-05:00| vcpu-0| I125: CPU reset: hard (mode 0)
2018-12-20T09:19:49.247-05:00| vcpu-1| I125: VTHREAD 140617710520064 "vcpu-1" tid 27383
2018-12-20T09:19:49.247-05:00| vcpu-1| I125: MonTimer APIC:0/0 vec: 0
2018-12-20T09:19:49.247-05:00| vcpu-1| I125: APIC: version = 0x15, max LVT = 6, LDR = 0x10000000, DFR = 0xffffffff
2018-12-20T09:19:49.247-05:00| vcpu-2| I125: VTHREAD 140617162159872 "vcpu-2" tid 27384
2018-12-20T09:19:49.247-05:00| vcpu-1| I125: CPU reset: hard (mode 0)
2018-12-20T09:19:49.247-05:00| vcpu-2| I125: MonTimer APIC:0/0 vec: 0
2018-12-20T09:19:49.247-05:00| vcpu-2| I125: APIC: version = 0x15, max LVT = 6, LDR = 0x8000000, DFR = 0xffffffff
2018-12-20T09:19:49.247-05:00| vcpu-3| I125: VTHREAD 140617153767168 "vcpu-3" tid 27385
2018-12-20T09:19:49.247-05:00| vcpu-3| I125: MonTimer APIC:0/0 vec: 0
2018-12-20T09:19:49.247-05:00| vcpu-2| I125: CPU reset: hard (mode 0)
2018-12-20T09:19:49.247-05:00| vcpu-3| I125: APIC: version = 0x15, max LVT = 6, LDR = 0x2000000, DFR = 0xffffffff
2018-12-20T09:19:49.247-05:00| vcpu-3| I125: CPU reset: hard (mode 0)
2018-12-20T09:19:49.248-05:00| vcpu-0| I125: GuestRpc: Successfully created RPCI listening socket.
2018-12-20T09:19:49.248-05:00| vcpu-0| I125: GuestRpc: Using vsocket for TCLO messaging is disabled.
2018-12-20T09:19:49.248-05:00| vcpu-0| I125: memoryHotplug: Node 0: Present: 16383 MB (100 %) Size:16383 MB (100 %)
2018-12-20T09:19:49.248-05:00| vcpu-0| I125: PIIX4: PM Resuming from suspend type 0x0, chipset.onlineStandby 0
2018-12-20T09:19:49.249-05:00| vcpu-0| I125: VNET: MACVNetConnectToNetwork 'Ethernet4' notify available.
2018-12-20T09:19:49.250-05:00| vcpu-0| I125: VNET: MACVNetConnectToNetwork 'Ethernet3' notify available.
2018-12-20T09:19:49.251-05:00| vcpu-0| I125: VNET: MACVNetConnectToNetwork 'Ethernet2' notify available.
2018-12-20T09:19:49.252-05:00| vcpu-0| I125: VNET: MACVNetConnectToNetwork 'Ethernet1' notify available.
2018-12-20T09:19:49.253-05:00| vcpu-0| I125: VNET: MACVNetConnectToNetwork 'Ethernet0' notify available.
2018-12-20T09:19:49.254-05:00| vcpu-0| I125: HGFSPublish: publishing 0 shares
2018-12-20T09:19:49.254-05:00| vcpu-0| A100: ConfigDB: Unsetting "sensor.accelerometer"
2018-12-20T09:19:49.254-05:00| vcpu-0| A100: ConfigDB: Unsetting "sensor.ambientLight"
2018-12-20T09:19:49.254-05:00| vcpu-0| A100: ConfigDB: Unsetting "sensor.compass"
2018-12-20T09:19:49.254-05:00| vcpu-0| A100: ConfigDB: Unsetting "sensor.gyrometer"
2018-12-20T09:19:49.254-05:00| vcpu-0| A100: ConfigDB: Unsetting "sensor.inclinometer"
2018-12-20T09:19:49.254-05:00| vcpu-0| A100: ConfigDB: Unsetting "sensor.orientation"
2018-12-20T09:19:49.256-05:00| vcpu-0| I125: PolicyVMXFindPolicyKey: policy file does not exist.
2018-12-20T09:19:49.259-05:00| vcpu-0| I125: Vix: [mainDispatch.c:4233]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1872, success=1 additionalError=0
2018-12-20T09:19:49.259-05:00| vcpu-0| I125: Vix: [mainDispatch.c:4150]: VMAutomationReportPowerStateChange: Reporting power state change (opcode=0, err=0).
2018-12-20T09:19:49.259-05:00| vcpu-0| I125: Vix: [mainDispatch.c:4150]: VMAutomationReportPowerStateChange: Reporting power state change (opcode=2, err=0).
2018-12-20T09:19:49.259-05:00| vcpu-0| I125: Transitioned vmx/execState/val to poweredOn
2018-12-20T09:19:49.259-05:00| vcpu-0| I125: Tools: Adding Tools inactivity timer.
2018-12-20T09:19:49.259-05:00| vcpu-0| I125: Intel VT: FlexPriority disabled.
2018-12-20T09:19:49.259-05:00| vcpu-3| I125: Intel VT: FlexPriority disabled.
2018-12-20T09:19:49.259-05:00| vcpu-2| I125: Intel VT: FlexPriority disabled.
2018-12-20T09:19:49.259-05:00| vcpu-2| I125: Intel VT: VPID enabled.
2018-12-20T09:19:49.259-05:00| vcpu-0| I125: Intel VT: VPID enabled.
2018-12-20T09:19:49.259-05:00| vcpu-3| I125: Intel VT: VPID enabled.
2018-12-20T09:19:49.259-05:00| vcpu-1| I125: Intel VT: FlexPriority disabled.
2018-12-20T09:19:49.259-05:00| vcpu-1| I125: Intel VT: VPID enabled.
2018-12-20T09:19:49.261-05:00| vcpu-0| I125: Intel VT enabled.
2018-12-20T09:19:49.261-05:00| vcpu-1| I125: Intel VT enabled.
2018-12-20T09:19:49.261-05:00| vcpu-2| I125: Intel VT enabled.
2018-12-20T09:19:49.261-05:00| vcpu-3| I125: Intel VT enabled.
2018-12-20T09:19:49.359-05:00| mks| I125: MKSControlMgr: connected
2018-12-20T09:19:49.400-05:00| mks| I125: KHBKL: Unable to parse keystring at: ''
2018-12-20T09:19:49.412-05:00| mks| I125: SWBWindow: Number of MKSWindows changed: 1 rendering MKSWindow(s) of total 1.
2018-12-20T09:19:49.415-05:00| mks| I125: MKSXInput: XI major version 2, minor version 3
2018-12-20T09:19:49.415-05:00| mks| I125: XINFO X fd is 19
2018-12-20T09:19:49.415-05:00| mks| I125: XINFO depth 24 bpp 32 class 4
2018-12-20T09:19:49.415-05:00| mks| I125: XINFO ServerVendor: "The X.Org Foundation"
2018-12-20T09:19:49.415-05:00| mks| I125: XINFO VendorRelease: 11906000
2018-12-20T09:19:49.416-05:00| mks| I125: XINFO XKB available, version 1.0
2018-12-20T09:19:49.416-05:00| mks| I125: XINFO XTEST available, version 2.2
2018-12-20T09:19:49.417-05:00| mks| I125: XINFO Xinerama available
2018-12-20T09:19:49.418-05:00| mks| I125: XKeymap_PowerOn: use xkb keycode mapping.
2018-12-20T09:19:49.418-05:00| mks| I125: X11-Backend: successfully started by HWinMux to do window composition.
2018-12-20T09:19:49.418-05:00| mks| I125: X11-Backend: XINFO SHM available, version 1.2, shared pixmaps
2018-12-20T09:19:49.419-05:00| mks| I125: MKS-HWinMux: Started X11 presentation backend
2018-12-20T09:19:49.524-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0x0) and 0xfe000000(0x0)
2018-12-20T09:19:49.529-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:49.725-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:49.732-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:49.733-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:49.733-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:49.738-05:00| vcpu-0| I125: PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.739-05:00| vcpu-0| I125: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.740-05:00| vcpu-0| I125: pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.742-05:00| vcpu-0| I125: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.743-05:00| vcpu-0| I125: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.744-05:00| vcpu-0| I125: pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.746-05:00| vcpu-0| I125: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.747-05:00| vcpu-0| I125: pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.748-05:00| vcpu-0| I125: PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.749-05:00| vcpu-0| I125: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.751-05:00| vcpu-0| I125: pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.752-05:00| vcpu-0| I125: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.753-05:00| vcpu-0| I125: pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.754-05:00| vcpu-0| I125: pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.756-05:00| vcpu-0| I125: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.757-05:00| vcpu-0| I125: pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.758-05:00| vcpu-0| I125: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.759-05:00| vcpu-0| I125: pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.761-05:00| vcpu-0| I125: pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.762-05:00| vcpu-0| I125: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.763-05:00| vcpu-0| I125: pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.764-05:00| vcpu-0| I125: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.766-05:00| vcpu-0| I125: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.767-05:00| vcpu-0| I125: pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.768-05:00| vcpu-0| I125: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.770-05:00| vcpu-0| I125: pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.771-05:00| vcpu-0| I125: pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.772-05:00| vcpu-0| I125: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.773-05:00| vcpu-0| I125: pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.775-05:00| vcpu-0| I125: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.776-05:00| vcpu-0| I125: pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.777-05:00| vcpu-0| I125: pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.779-05:00| vcpu-1| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:49.780-05:00| vcpu-2| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:49.782-05:00| vcpu-3| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:49.940-05:00| vcpu-0| I125: PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.941-05:00| vcpu-0| I125: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.942-05:00| vcpu-0| I125: pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.944-05:00| vcpu-0| I125: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.945-05:00| vcpu-0| I125: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.946-05:00| vcpu-0| I125: pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.947-05:00| vcpu-0| I125: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.949-05:00| vcpu-0| I125: pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.950-05:00| vcpu-0| I125: PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.951-05:00| vcpu-0| I125: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.952-05:00| vcpu-0| I125: pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.954-05:00| vcpu-0| I125: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.955-05:00| vcpu-0| I125: pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.956-05:00| vcpu-0| I125: pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.958-05:00| vcpu-0| I125: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.959-05:00| vcpu-0| I125: pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.960-05:00| vcpu-0| I125: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.961-05:00| vcpu-0| I125: pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.963-05:00| vcpu-0| I125: pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.964-05:00| vcpu-0| I125: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.965-05:00| vcpu-0| I125: pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.966-05:00| vcpu-0| I125: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.968-05:00| vcpu-0| I125: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.969-05:00| vcpu-0| I125: pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.970-05:00| vcpu-0| I125: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.971-05:00| vcpu-0| I125: pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.973-05:00| vcpu-0| I125: pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.974-05:00| vcpu-0| I125: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.975-05:00| vcpu-0| I125: pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.976-05:00| vcpu-0| I125: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.978-05:00| vcpu-0| I125: pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.979-05:00| vcpu-0| I125: pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:49.987-05:00| vcpu-0| I125: DISKUTIL: scsi0:0 : geometry=8923/255/63
2018-12-20T09:19:49.987-05:00| vcpu-0| I125: DISKUTIL: scsi0:0 : capacity=143360000 logical sector size=512
2018-12-20T09:19:49.988-05:00| vcpu-0| I125: SCSI0: RESET BUS
2018-12-20T09:19:51.031-05:00| vcpu-1| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:51.032-05:00| vcpu-2| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:51.033-05:00| vcpu-3| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:51.051-05:00| vcpu-0| I125: BIOS-UUID is 56 4d cc 85 6f f0 f7 a1-5d 92 fa 13 96 63 71 ef
2018-12-20T09:19:51.736-05:00| vcpu-0| I125: Unknown int 10h func 0x0000
2018-12-20T09:19:51.737-05:00| svga| I125: SVGA enabling SVGA
2018-12-20T09:19:51.739-05:00| svga| I125: SVGA-ScreenMgr: Screen type changed to RegisterMode
2018-12-20T09:19:56.763-05:00| vcpu-0| I125: DDB: "longContentID" = "0ac0522c7d3d618174e482297c924cab" (was "d06adc1deb0c27849e88b7422c219eb9")
2018-12-20T09:19:57.611-05:00| svga| I125: SVGA disabling SVGA
2018-12-20T09:19:59.078-05:00| vcpu-1| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:59.079-05:00| vcpu-2| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:59.081-05:00| vcpu-3| I125: CPU reset: soft (mode 0)
2018-12-20T09:19:59.207-05:00| vcpu-0| I125: SVGA: Unregistering IOSpace at 0x1070
2018-12-20T09:19:59.207-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.208-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:59.208-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.212-05:00| vcpu-0| I125: SVGA: Unregistering IOSpace at 0x1070
2018-12-20T09:19:59.212-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.213-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:59.213-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.213-05:00| vcpu-0| I125: SVGA: Unregistering IOSpace at 0x1070
2018-12-20T09:19:59.213-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.214-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:59.214-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.214-05:00| vcpu-0| I125: SVGA: Unregistering IOSpace at 0x1070
2018-12-20T09:19:59.215-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.215-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:59.215-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.216-05:00| vcpu-0| I125: SVGA: Unregistering IOSpace at 0x1070
2018-12-20T09:19:59.216-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.216-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:59.216-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.217-05:00| vcpu-0| I125: SVGA: Unregistering IOSpace at 0x1070
2018-12-20T09:19:59.217-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.217-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:59.217-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.218-05:00| vcpu-0| I125: SVGA: Unregistering IOSpace at 0x1070
2018-12-20T09:19:59.218-05:00| vcpu-0| I125: SVGA: Unregistering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.219-05:00| vcpu-0| I125: SVGA: Registering IOSpace at 0x1070
2018-12-20T09:19:59.219-05:00| vcpu-0| I125: SVGA: Registering MemSpace at 0xe8000000(0xe8000000) and 0xfe000000(0xfe000000)
2018-12-20T09:19:59.282-05:00| vcpu-0| I125: PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.282-05:00| vcpu-0| I125: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.283-05:00| vcpu-0| I125: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.283-05:00| vcpu-0| I125: pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.283-05:00| vcpu-0| I125: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.283-05:00| vcpu-0| I125: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.284-05:00| vcpu-0| I125: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.284-05:00| vcpu-0| I125: pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.284-05:00| vcpu-0| I125: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.285-05:00| vcpu-0| I125: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.285-05:00| vcpu-0| I125: pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.285-05:00| vcpu-0| I125: PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.285-05:00| vcpu-0| I125: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.286-05:00| vcpu-0| I125: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.286-05:00| vcpu-0| I125: pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.286-05:00| vcpu-0| I125: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.287-05:00| vcpu-0| I125: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.287-05:00| vcpu-0| I125: pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.287-05:00| vcpu-0| I125: pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.287-05:00| vcpu-0| I125: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.288-05:00| vcpu-0| I125: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.288-05:00| vcpu-0| I125: pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.288-05:00| vcpu-0| I125: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.289-05:00| vcpu-0| I125: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.289-05:00| vcpu-0| I125: pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.289-05:00| vcpu-0| I125: pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.289-05:00| vcpu-0| I125: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.290-05:00| vcpu-0| I125: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.290-05:00| vcpu-0| I125: pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.290-05:00| vcpu-0| I125: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.291-05:00| vcpu-0| I125: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.291-05:00| vcpu-0| I125: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.291-05:00| vcpu-0| I125: pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.291-05:00| vcpu-0| I125: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.292-05:00| vcpu-0| I125: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.292-05:00| vcpu-0| I125: pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.292-05:00| vcpu-0| I125: pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.292-05:00| vcpu-0| I125: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.293-05:00| vcpu-0| I125: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.293-05:00| vcpu-0| I125: pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.293-05:00| vcpu-0| I125: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.294-05:00| vcpu-0| I125: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.294-05:00| vcpu-0| I125: pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.294-05:00| vcpu-0| I125: pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.294-05:00| vcpu-0| I125: PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.294-05:00| vcpu-0| I125: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.294-05:00| vcpu-0| I125: pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.294-05:00| vcpu-0| I125: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.295-05:00| vcpu-0| I125: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.296-05:00| vcpu-0| I125: pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: PCIBridge4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: pciBridge4:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: pciBridge4:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: pciBridge4:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: pciBridge4:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: pciBridge4:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: pciBridge4:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: pciBridge4:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.372-05:00| vcpu-0| I125: PCIBridge5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge5:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge5:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge5:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge5:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge5:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge5:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge5:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: PCIBridge6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge6:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.373-05:00| vcpu-0| I125: pciBridge6:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge6:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge6:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge6:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge6:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge6:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: PCIBridge7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge7:1: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge7:2: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge7:3: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge7:4: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.374-05:00| vcpu-0| I125: pciBridge7:5: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.375-05:00| vcpu-0| I125: pciBridge7:6: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:19:59.375-05:00| vcpu-0| I125: pciBridge7:7: ISA/VGA decoding enabled (ctrl 0004)
2018-12-20T09:20:00.406-05:00| vcpu-2| I125: VIDE: Already in check condition 02 3a 00
2018-12-20T09:20:00.599-05:00| vcpu-1| I125: SCSI0: RESET BUS
2018-12-20T09:20:00.600-05:00| vcpu-3| I125: VMMouse: CMD Read ID
2018-12-20T09:20:00.933-05:00| vcpu-0| I125: SCSI0: RESET BUS
2018-12-20T09:20:00.945-05:00| svga| I125: SVGA hiding SVGA
2018-12-20T09:20:00.953-05:00| svga| I125: SVGA enabling SVGA
2018-12-20T09:20:00.956-05:00| vcpu-0| I125: DISKUTIL: scsi0:0 : capacity=143360000 logical sector size=512
2018-12-20T09:20:00.956-05:00| vcpu-0| I125: SCSI DEVICE (scsi0:0): MODE SENSE(6) for unsupported page 0x8
2018-12-20T09:20:00.958-05:00| vcpu-0| I125: DISKUTIL: scsi0:0 : capacity=143360000 logical sector size=512
2018-12-20T09:20:00.958-05:00| vcpu-0| I125: SCSI DEVICE (scsi0:0): MODE SENSE(6) for unsupported page 0x8
2018-12-20T09:20:00.959-05:00| vcpu-0| I125: DISKUTIL: scsi0:0 : capacity=143360000 logical sector size=512
2018-12-20T09:20:00.959-05:00| vcpu-0| I125: SCSI DEVICE (scsi0:0): MODE SENSE(6) for unsupported page 0x8
2018-12-20T09:20:01.010-05:00| svga| I125: SVGA-ScreenMgr: Screen type changed to ScreenObject
2018-12-20T09:20:03.479-05:00| vthread-28149| I125: VTHREAD 140617145374464 "vthread-28149" tid 28149
2018-12-20T09:20:03.480-05:00| vthread-28150| I125: VTHREAD 140617136981760 "vthread-28150" tid 28150
2018-12-20T09:20:04.782-05:00| vcpu-3| I125: SCSI scsi0:0: Unsupported command *UNKNOWN (0x85)* issued. --ok
2018-12-20T09:20:04.851-05:00| vcpu-1| I125: CDROM: Emulate GET CONFIGURATION RT 0 starting feature 0
2018-12-20T09:20:04.852-05:00| vcpu-1| I125: CDROM: Emulate GET CONFIGURATION RT 0 starting feature 0
2018-12-20T09:20:05.844-05:00| vcpu-1| I125: Guest MSR write (0x49: 0x1)
2018-12-20T09:20:05.867-05:00| vmx| I125: GuestRpc: Got RPCI vsocket connection 5, assigned to channel 0.
2018-12-20T09:20:05.891-05:00| vmx| I125: Guest: toolbox: Version: build-3227872
2018-12-20T09:20:05.891-05:00| vcpu-2| W115: GuestRpc: application toolbox, changing channel 65535 -> 0
2018-12-20T09:20:05.891-05:00| vcpu-2| I125: GuestRpc: Channel 0, guest application toolbox.
2018-12-20T09:20:05.891-05:00| vcpu-2| I125: DEPLOYPKG: ToolsDeployPkg_Begin: state=0 err=0, msg=null
2018-12-20T09:20:05.891-05:00| vcpu-2| I125: Tools: [AppStatus] Last heartbeat value 0 (never received)
2018-12-20T09:20:06.229-05:00| vthread-28151| I125: VTHREAD 140617128589056 "vthread-28151" tid 28151
2018-12-20T09:20:06.367-05:00| vcpu-0| I125: Tools: Running status rpc handler: 0 => 1.
2018-12-20T09:20:06.367-05:00| vcpu-0| I125: Tools: Changing running status: 0 => 1.
2018-12-20T09:20:06.367-05:00| vcpu-0| I125: Tools: [RunningStatus] Last heartbeat value 1 (last received 0s ago)
2018-12-20T09:20:06.367-05:00| vcpu-0| I125: Tools: Removing Tools inactivity timer.
2018-12-20T09:20:06.745-05:00| vmx| I125: Tools: Changing running status: 1 => 2.
2018-12-20T09:20:06.745-05:00| vmx| I125: Tools: [RunningStatus] Last heartbeat value 1 (last received 0s ago)
2018-12-20T09:20:06.750-05:00| vmx| I125: TOOLS Received tools.set.versiontype rpc call, version = 10247, type = 4
2018-12-20T09:20:06.750-05:00| vmx| I125: TOOLS Setting toolsVersionStatus = TOOLS_STATUS_UNMANAGED
2018-12-20T09:20:06.750-05:00| vmx| I125: Tools_SetVersionAndType did nothing; new tools version (10247) and type (4) match old Tools version and type
2018-12-20T09:20:06.761-05:00| vmx| I125: TOOLS state change 3 returned status 1
2018-12-20T09:20:06.761-05:00| vmx| I125: Vix: [mainDispatch.c:4150]: VMAutomationReportPowerStateChange: Reporting power state change (opcode=2, err=0).
2018-12-20T09:20:06.761-05:00| vmx| I125: Tools: Changing running status: 2 => 1.
2018-12-20T09:20:06.761-05:00| vmx| I125: Tools: [RunningStatus] Last heartbeat value 1 (last received 0s ago)
2018-12-20T09:20:09.658-05:00| vthread-28152| I125: VTHREAD 140617120196352 "vthread-28152" tid 28152
2018-12-20T09:20:09.658-05:00| vthread-28153| I125: VTHREAD 140617111803648 "vthread-28153" tid 28153
12-20-2018 06:41 AM
(INFO) [Dec/20/2018 14:10:13] Node "iosvl2-2" state changed from ABSENT to BUILDING
(INFO) [Dec/20/2018 14:10:14] Node "~mgmt-lxc" state changed from ABSENT to ACTIVE
(INFO) [Dec/20/2018 14:10:15] Reachability status of node "~mgmt-lxc" changed from UNREACHABLE to REACHABLE
(ERROR) [Dec/20/2018 14:10:33] Node "iosvl2-1" state changed from BUILDING to ERROR with message: Could not contact redis at localhost:6379.
Cause: Error 111 connecting to localhost:6379. ECONNREFUSED.: File "/usr/lib/python2.7/dist-packages/nova/compute/manager.py", line 1926, in _do_build_and_run_instance
(ERROR) [Dec/20/2018 14:10:33] Node "iosvl2-2" state changed from BUILDING to ERROR with message: Could not contact redis at localhost:6379.
(WARNING) [Dec/20/2018 14:13:54] Skipped configuration extraction for node "iosvl2-1" in state ERROR
(WARNING) [Dec/20/2018 14:13:54] Skipped configuration extraction for node "iosvl2-2" in state ERROR
