06-01-2004 04:36 AM - edited 03-02-2019 04:03 PM
I have a copy of the config that Cisco provides stating that as of IOS 12.2(2)T the SAA application performance monitor feature was introduced from the 2600 router platform & above.
I have a 2610 router that has IOS 12.3 loaded but cannot issue any SAA cmds. The only cmd that the router knows about SAA is the 'debug SAA' cmd but issuing this cmd also comes up as un-supported.
I need to configure SAA on a 2610 & 3640 router. Can anybody shed some light as to the way forward ...
Lincoln
06-01-2004 04:56 AM
The commands are still listed under the old name for SAA, RTR. Here is the Cisco website that links to many documents on how to use and configure SAA. http://www.cisco.com/warp/public/732/Tech/nmp/saa/
06-02-2004 10:24 PM
Thanks Gray, there is a lot of info here which I am sure will be of benefit to my configuration ...
Lincoln
