11-16-2011 12:24 PM - edited 03-03-2019 06:25 AM
Hello, I have a question if I Stack a Catalyst 3750 L3 with a Catalyst just L2, will we able to use all L3 capabilities?
Switches are
WS-C3750G-24TS-E1U
WS-C3750V2-24PS-S
11-16-2011 12:44 PM
The switch models are not indicative. You need to provide the output of the "sh version" to determine what feature set is being used. The rule-of-thumb is for all stack members to run the same IOS version and the same feature set.
11-16-2011 01:39 PM
The switches are not connected yet, they are in their box, it will be a new implemntation. And we just would like to know if is possible using L3 capabilities in a Stack with one Layer 3 Switch and the rest of them just L2.
11-16-2011 01:47 PM
The answer is NO.
11-17-2011 05:29 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unless the V2 is different from the original 3750s, you could mix feature sets within the same stack. Stack election takes into account feature set. You do want all switches to have the same installed version.
