11-05-2015 11:37 AM - edited 03-03-2019 08:02 AM
Hello fellow Cisco enthusiasts.
I am trying to stack the following two switches together:
WS-C3750X-12S-S
WS-C3750X-48P-L
I have used the following IOS's on both switches:
c3750e-ipbasek9-mz.150-2.SE8.bin
c3750e-universalk9-mz.152-4.E.bin
I made sure that each switch had the same IOS, but these two switches do not seem to recognize each other.
Am I missing an incompatibility? When I used the c3750e-universalk9-mz.152-4.E.bin IOS, I received a "major version mismatch" error.
Any thoughts?
Thank you.
Solved! Go to Solution.
11-06-2015 11:45 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Your "-L" is a LANBase switch. If so, that license, I believe, will only stack with other LANBase stack members.
11-05-2015 12:01 PM
No they are not. One switch is running IOS version 15.0(2)SE8 and the other is 15.2(4)E.
Both have to run either 15.0(2)SE8 OR 15.2(4)E.
11-05-2015 02:29 PM
Thank you for the reply. Both switches ran the 15.0(2)SE8 and failed.
I upgraded both switches to the 15.2(4)E and the stack failed.
Both switches are running the same IOS, but still fail to stack.
Any other ideas?
11-05-2015 05:27 PM
Post the complete output to the command "sh version" from both appliances.
11-06-2015 02:12 PM
I have attached the sh ver outputs from both switches.
sh ver
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 15.0(2)SE8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 13-May-15 23:01 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
Switch uptime is 1 day, 2 hours, 29 minutes
System image file is "flash:c3750e-ipbasek9-mz.150-2.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-12S (PowerPC405) processor (revision N0) with 524288K bytes of memory.
Processor board ID FDO1833P07R
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : F0:7F:06:56:2D:80
Motherboard assembly number : 73-13329-06
Motherboard serial number : FDO1833086H
Model revision number : N0
Motherboard revision number : B0
Model number : WS-C3750X-12S-S
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO18321JT8
System serial number : FDO1833P07R
Top Assembly Part Number : 800-35090-06
Top Assembly Revision Number : D0
Version ID : V05
CLEI Code Number : CMMPL00DRA
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 2 18 WS-C3750X-12S 15.0(2)SE8 C3750E-IPBASEK9-M
Configuration register is 0xF
Switch#
sh ver
Switch uptime is 1 day, 5 hours, 12 minutes
export@cisco.com.
License Level: lanbase
Next reload license Level: lanbase
cisco WS-C3750X-48P (PowerPC405) processor (revision Q0) with 262144K bytes of memory.
Processor board ID FDO1838R3EX
52 Gigabit Ethernet interfaces
Base ethernet MAC Address : 88:1D:FC:0D:29:00
Motherboard assembly number : 73-12553-11
Motherboard serial number : FDO183812ZD
Model revision number : Q0
Model number : WS-C3750X-48P-L
Daughterboard serial number : FDO18380YF3
System serial number : FDO1838R3EX
Top Assembly Part Number : 800-31324-09
Top Assembly Revision Number : E0
Version ID : V06
CLEI Code Number : CMMPS00DRA
* 1 54 WS-C3750X-48P 15.0(2)SE8 C3750E-IPBASEK9-M
Switch#
11-06-2015 06:25 PM
I believe I have found the answer. Please see below.
From the Cisco Catalyst 3750-X and 3560-X Series Switches Data Sheet:
The Cisco Catalyst 3750-X Series Switches with LAN Base feature set can only stack with other Cisco Catalyst 3750‑X Series LAN Base switches. A mixed stack of LAN Base switch with IP Base or IP Services features set is not supported.
11-06-2015 11:45 AM
Disclaimer
Posting
