Stuck in ROMMON mode with my ASA5505 Firewall
Krishna Babu
I, in an effort to erase my flash memory, has ended up and is left stranded in ROMMON mode. Iam new to this environment and has been trying literally every suggestion available on the internet to resolve the same.
Primarily my firewall is searching for an image file (Iam not sure about the extension of it; but I think it is looking for a .bin)
As it isnt able to trace the image, Iam in ROMMON. Further, I tried using a TFTP server (setup using SOLARWINDS) for the same.
Now, as it says, File does not exist wherein I've put the .bin in the TFTP root folder.
Could anyone advice me? Where am I going wrong?
Eventhough I mentioned the image as .bin, is the firewall looking for some other extension?
Vibhor Amrodia
Hi Krishna,
From the Snap , I think you need to make these changes:-
1)Unset the Gateway as it is not required.
2) This is not an error with the File Extension but with the TFTP server or the PC. Can you try a different PC to boot up the ASA device.
3) Verify the Filename:- I think it should be
asa831-k8.bin
4) You can use this TFTP server:-
http://tftpd32.jounin.net/tftpd32_download.html
Thanks and Regards,
Vibhor
5 Replies 5
Vibhor Amrodia
Hi Krishna,
asa831-k8.bin
Thanks and Regards,
Vibhor
Vibhor,
Thanks a lot man.
Finally Iam out of the dark and the image had been loaded. The issue was with the image file and after many iterations, your 3rd point made me search again. Finally got it and things are turning out for the good.
Thanks once again.
Hi Krishna,
Nice to hear that..TFTP can be a pain sometimes
Thanks and Regards,
Vibhor
Vibhor,
          You are absolutely right. It had been a horrendous last week for me.. Stuck in ROMMON, which was sort of a limbo. And, once the tftp was through, I did my own R&D and thanks to all, the device is back to normal with its upgrades incorporated. Feels great.
          Once again thanks to all.
Thanks and regards,
Krishna
This discussion has been reposted from CSC Helps Teachers Without Borders to the Other Network Infrastructure Subjects community.
