10-03-2004 03:32 PM - edited 03-02-2019 06:57 PM
I just installed 2 Sup720s. After configuring the first Sup, during configuration of the 2nd Sup, the console locked up. Probably because of TACACS statements. I switched the console cable to the 1st Sup while it was locked up to see if that switch had also locked up. I could not get anything on terminal screen. I rebooted both switches, but I still cannot get the console port to work on the first switch. I've tried rebooting the switches, press Ctrl C 3 times, in case it was in "switch console mode" and also issued the command to disconnect the user that was attached to the console. Also tried setting the timesout low, so if something was left logged in, it would time out.
I still am unable to connect to the console port on the 2nd switch. All other things seem to be working fine. I can telnet to the switch with no problem.
Any suggestions would be appreciated.
10-04-2004 12:46 AM
it looks like the normal behaviour. When you have two sups installed and they reboot. You have access to both sups via console. But when they are up, the backup sup closed the console access. This sup, which is ready with the boot process first is the active supervisor engine and on this module you have console access.
Peter
10-04-2004 09:19 AM
Sorry I wasn't clear. The sups are in separate 6509's. I also forgot to mention, I running Cat OS on the switches.
10-04-2004 11:32 AM
Please do this activity, shutdown the PC on which you are using the Hyperterminal, reboot, also, power down the switch, wait for 2 minutes and then power this back on, you should get the console back.
Sriharshaa Prabhakar
